RTEMS 6.1
DMA_InitTypeDef Struct Reference
DMA Configuration Structure definition. More...
#include <stm32h7xx_hal_dma.h>
uint32_t Request
uint32_t Direction
uint32_t PeriphInc
uint32_t MemInc
uint32_t PeriphDataAlignment
uint32_t MemDataAlignment
uint32_t Mode
uint32_t Priority
uint32_t FIFOMode
uint32_t FIFOThreshold
uint32_t MemBurst
uint32_t PeriphBurst
Field Documentation
◆ Direction
uint32_t DMA_InitTypeDef::Direction
Specifies if the data will be transferred from memory to peripheral, from memory to memory or from peripheral to memory. This parameter can be a value of DMA Data transfer direction
◆ FIFOMode
uint32_t DMA_InitTypeDef::FIFOMode
Specifies if the FIFO mode or Direct mode will be used for the specified stream. This parameter can be a value of DMA FIFO direct mode
Note
The Direct mode (FIFO mode disabled) cannot be used if the memory-to-memory data transfer is configured on the selected stream
◆ FIFOThreshold
uint32_t DMA_InitTypeDef::FIFOThreshold
Specifies the FIFO threshold level. This parameter can be a value of DMA FIFO threshold level
◆ MemBurst
uint32_t DMA_InitTypeDef::MemBurst
Specifies the Burst transfer configuration for the memory transfers. It specifies the amount of data to be transferred in a single non interruptible transaction. This parameter can be a value of DMA Memory burst
Note
The burst mode is possible only if the address Increment mode is enabled.
◆ MemDataAlignment
uint32_t DMA_InitTypeDef::MemDataAlignment
Specifies the Memory data width. This parameter can be a value of DMA Memory data size
◆ MemInc
uint32_t DMA_InitTypeDef::MemInc
Specifies whether the memory address register should be incremented or not. This parameter can be a value of DMA Memory incremented mode
◆ Mode
uint32_t DMA_InitTypeDef::Mode
Specifies the operation mode of the DMAy Streamx. This parameter can be a value of DMA mode
Note
The circular buffer mode cannot be used if the memory-to-memory data transfer is configured on the selected Stream
◆ PeriphBurst
uint32_t DMA_InitTypeDef::PeriphBurst
Specifies the Burst transfer configuration for the peripheral transfers. It specifies the amount of data to be transferred in a single non interruptible transaction. This parameter can be a value of DMA Peripheral burst
Note
◆ PeriphDataAlignment
uint32_t DMA_InitTypeDef::PeriphDataAlignment
Specifies the Peripheral data width. This parameter can be a value of DMA Peripheral data size
◆ PeriphInc
uint32_t DMA_InitTypeDef::PeriphInc
Specifies whether the Peripheral address register should be incremented or not. This parameter can be a value of DMA Peripheral incremented mode
◆ Priority
uint32_t DMA_InitTypeDef::Priority
Specifies the software priority for the DMAy Streamx. This parameter can be a value of DMA Priority level
◆ Request
uint32_t DMA_InitTypeDef::Request
Specifies the request selected for the specified stream. This parameter can be a value of DMA Request selection
