RTEMS 6.1
__IO uint32_t CSR
__IO uint32_t CFR
Field Documentation
◆ CFR
__IO uint32_t DMAMUX_ChannelStatus_TypeDef::CFR
DMA Channel Clear Flag Register
◆ CSR
__IO uint32_t DMAMUX_ChannelStatus_TypeDef::CSR
DMA Channel Status Register
The documentation for this struct was generated from the following files:
