RTEMS 6.1
DMA2D Controller. More...
#include <stm32h723xx.h>
__IO uint32_t CR
__IO uint32_t ISR
__IO uint32_t IFCR
__IO uint32_t FGMAR
__IO uint32_t FGOR
__IO uint32_t BGMAR
__IO uint32_t BGOR
__IO uint32_t FGPFCCR
__IO uint32_t FGCOLR
__IO uint32_t BGPFCCR
__IO uint32_t BGCOLR
__IO uint32_t FGCMAR
__IO uint32_t BGCMAR
__IO uint32_t OPFCCR
__IO uint32_t OCOLR
__IO uint32_t OMAR
__IO uint32_t OOR
__IO uint32_t NLR
__IO uint32_t LWR
__IO uint32_t AMTCR
uint32_t RESERVED [236]
__IO uint32_t FGCLUT [256]
__IO uint32_t BGCLUT [256]
DMA2D Controller.
Field Documentation
◆ AMTCR
__IO uint32_t DMA2D_TypeDef::AMTCR
DMA2D AHB Master Timer Configuration Register, Address offset: 0x4C
◆ BGCLUT
__IO uint32_t DMA2D_TypeDef::BGCLUT
DMA2D Background CLUT, Address offset:800-BFF
◆ BGCMAR
__IO uint32_t DMA2D_TypeDef::BGCMAR
DMA2D Background CLUT Memory Address Register, Address offset: 0x30
◆ BGCOLR
__IO uint32_t DMA2D_TypeDef::BGCOLR
DMA2D Background Color Register, Address offset: 0x28
◆ BGMAR
__IO uint32_t DMA2D_TypeDef::BGMAR
DMA2D Background Memory Address Register, Address offset: 0x14
◆ BGOR
__IO uint32_t DMA2D_TypeDef::BGOR
DMA2D Background Offset Register, Address offset: 0x18
◆ BGPFCCR
__IO uint32_t DMA2D_TypeDef::BGPFCCR
DMA2D Background PFC Control Register, Address offset: 0x24
◆ CR
__IO uint32_t DMA2D_TypeDef::CR
DMA2D Control Register, Address offset: 0x00
◆ FGCLUT
__IO uint32_t DMA2D_TypeDef::FGCLUT
DMA2D Foreground CLUT, Address offset:400-7FF
◆ FGCMAR
__IO uint32_t DMA2D_TypeDef::FGCMAR
DMA2D Foreground CLUT Memory Address Register, Address offset: 0x2C
◆ FGCOLR
__IO uint32_t DMA2D_TypeDef::FGCOLR
DMA2D Foreground Color Register, Address offset: 0x20
◆ FGMAR
__IO uint32_t DMA2D_TypeDef::FGMAR
DMA2D Foreground Memory Address Register, Address offset: 0x0C
◆ FGOR
__IO uint32_t DMA2D_TypeDef::FGOR
DMA2D Foreground Offset Register, Address offset: 0x10
◆ FGPFCCR
__IO uint32_t DMA2D_TypeDef::FGPFCCR
DMA2D Foreground PFC Control Register, Address offset: 0x1C
◆ IFCR
__IO uint32_t DMA2D_TypeDef::IFCR
DMA2D Interrupt Flag Clear Register, Address offset: 0x08
◆ ISR
__IO uint32_t DMA2D_TypeDef::ISR
DMA2D Interrupt Status Register, Address offset: 0x04
◆ LWR
__IO uint32_t DMA2D_TypeDef::LWR
DMA2D Line Watermark Register, Address offset: 0x48
◆ NLR
__IO uint32_t DMA2D_TypeDef::NLR
DMA2D Number of Line Register, Address offset: 0x44
◆ OCOLR
__IO uint32_t DMA2D_TypeDef::OCOLR
DMA2D Output Color Register, Address offset: 0x38
◆ OMAR
__IO uint32_t DMA2D_TypeDef::OMAR
DMA2D Output Memory Address Register, Address offset: 0x3C
◆ OOR
__IO uint32_t DMA2D_TypeDef::OOR
DMA2D Output Offset Register, Address offset: 0x40
◆ OPFCCR
__IO uint32_t DMA2D_TypeDef::OPFCCR
DMA2D Output PFC Control Register, Address offset: 0x34
◆ RESERVED
uint32_t DMA2D_TypeDef::RESERVED
Reserved, 0x50-0x3FF
The documentation for this struct was generated from the following files:
