RTEMS 6.1
DFSDM channel configuration registers. More...
#include <stm32h723xx.h>
__IO uint32_t CHCFGR1
__IO uint32_t CHCFGR2
__IO uint32_t CHAWSCDR
__IO uint32_t CHWDATAR
__IO uint32_t CHDATINR
__IO uint32_t CHDLYR
Field Documentation
◆ CHAWSCDR
__IO uint32_t DFSDM_Channel_TypeDef::CHAWSCDR
DFSDM channel analog watchdog and short circuit detector register, Address offset: 0x08
◆ CHCFGR1
__IO uint32_t DFSDM_Channel_TypeDef::CHCFGR1
DFSDM channel configuration register1, Address offset: 0x00
◆ CHCFGR2
__IO uint32_t DFSDM_Channel_TypeDef::CHCFGR2
DFSDM channel configuration register2, Address offset: 0x04
◆ CHDATINR
__IO uint32_t DFSDM_Channel_TypeDef::CHDATINR
DFSDM channel data input register, Address offset: 0x10
◆ CHDLYR
__IO uint32_t DFSDM_Channel_TypeDef::CHDLYR
DFSDM channel delay register, Address offset: 0x14
◆ CHWDATAR
__IO uint32_t DFSDM_Channel_TypeDef::CHWDATAR
DFSDM channel watchdog filter data register, Address offset: 0x0C
The documentation for this struct was generated from the following files:
