RTEMS 6.1
#include <MIMXRT1052.h>
Data Fields | |
| __IO uint32_t | CTRL |
| __IO uint32_t | CTRL_SET |
| __IO uint32_t | CTRL_CLR |
| __IO uint32_t | CTRL_TOG |
| __IO uint32_t | STAT |
| __IO uint32_t | STAT_SET |
| __IO uint32_t | STAT_CLR |
| __IO uint32_t | STAT_TOG |
| __IO uint32_t | CHANNELCTRL |
| __IO uint32_t | CHANNELCTRL_SET |
| __IO uint32_t | CHANNELCTRL_CLR |
| __IO uint32_t | CHANNELCTRL_TOG |
| __IO uint32_t | CAPABILITY0 |
| uint8_t | RESERVED_0 [12] |
| __I uint32_t | CAPABILITY1 |
| uint8_t | RESERVED_1 [12] |
| __IO uint32_t | CONTEXT |
| uint8_t | RESERVED_2 [12] |
| __IO uint32_t | KEY |
| uint8_t | RESERVED_3 [12] |
| __IO uint32_t | KEYDATA |
| uint8_t | RESERVED_4 [12] |
| __I uint32_t | PACKET0 |
| uint8_t | RESERVED_5 [12] |
| __I uint32_t | PACKET1 |
| uint8_t | RESERVED_6 [12] |
| __I uint32_t | PACKET2 |
| uint8_t | RESERVED_7 [12] |
| __I uint32_t | PACKET3 |
| uint8_t | RESERVED_8 [12] |
| __I uint32_t | PACKET4 |
| uint8_t | RESERVED_9 [12] |
| __I uint32_t | PACKET5 |
| uint8_t | RESERVED_10 [12] |
| __I uint32_t | PACKET6 |
| uint8_t | RESERVED_11 [28] |
| __IO uint32_t | CH0CMDPTR |
| uint8_t | RESERVED_12 [12] |
| __IO uint32_t | CH0SEMA |
| uint8_t | RESERVED_13 [12] |
| __IO uint32_t | CH0STAT |
| __IO uint32_t | CH0STAT_SET |
| __IO uint32_t | CH0STAT_CLR |
| __IO uint32_t | CH0STAT_TOG |
| __IO uint32_t | CH0OPTS |
| __IO uint32_t | CH0OPTS_SET |
| __IO uint32_t | CH0OPTS_CLR |
| __IO uint32_t | CH0OPTS_TOG |
| __IO uint32_t | CH1CMDPTR |
| uint8_t | RESERVED_14 [12] |
| __IO uint32_t | CH1SEMA |
| uint8_t | RESERVED_15 [12] |
| __IO uint32_t | CH1STAT |
| __IO uint32_t | CH1STAT_SET |
| __IO uint32_t | CH1STAT_CLR |
| __IO uint32_t | CH1STAT_TOG |
| __IO uint32_t | CH1OPTS |
| __IO uint32_t | CH1OPTS_SET |
| __IO uint32_t | CH1OPTS_CLR |
| __IO uint32_t | CH1OPTS_TOG |
| __IO uint32_t | CH2CMDPTR |
| uint8_t | RESERVED_16 [12] |
| __IO uint32_t | CH2SEMA |
| uint8_t | RESERVED_17 [12] |
| __IO uint32_t | CH2STAT |
| __IO uint32_t | CH2STAT_SET |
| __IO uint32_t | CH2STAT_CLR |
| __IO uint32_t | CH2STAT_TOG |
| __IO uint32_t | CH2OPTS |
| __IO uint32_t | CH2OPTS_SET |
| __IO uint32_t | CH2OPTS_CLR |
| __IO uint32_t | CH2OPTS_TOG |
| __IO uint32_t | CH3CMDPTR |
| uint8_t | RESERVED_18 [12] |
| __IO uint32_t | CH3SEMA |
| uint8_t | RESERVED_19 [12] |
| __IO uint32_t | CH3STAT |
| __IO uint32_t | CH3STAT_SET |
| __IO uint32_t | CH3STAT_CLR |
| __IO uint32_t | CH3STAT_TOG |
| __IO uint32_t | CH3OPTS |
| __IO uint32_t | CH3OPTS_SET |
| __IO uint32_t | CH3OPTS_CLR |
| __IO uint32_t | CH3OPTS_TOG |
| uint8_t | RESERVED_20 [512] |
| __IO uint32_t | DBGSELECT |
| uint8_t | RESERVED_21 [12] |
| __I uint32_t | DBGDATA |
| uint8_t | RESERVED_22 [12] |
| __IO uint32_t | PAGETABLE |
| uint8_t | RESERVED_23 [12] |
| __I uint32_t | VERSION |
DCP - Register Layout Typedef
