RTEMS 6.1
DCMI. More...
#include <stm32h723xx.h>
__IO uint32_t CR
__IO uint32_t SR
__IO uint32_t RISR
__IO uint32_t IER
__IO uint32_t MISR
__IO uint32_t ICR
__IO uint32_t ESCR
__IO uint32_t ESUR
__IO uint32_t CWSTRTR
__IO uint32_t CWSIZER
__IO uint32_t DR
DCMI.
Field Documentation
◆ CR
__IO uint32_t DCMI_TypeDef::CR
DCMI control register 1, Address offset: 0x00
◆ CWSIZER
__IO uint32_t DCMI_TypeDef::CWSIZER
DCMI crop window size, Address offset: 0x24
◆ CWSTRTR
__IO uint32_t DCMI_TypeDef::CWSTRTR
DCMI crop window start, Address offset: 0x20
◆ DR
__IO uint32_t DCMI_TypeDef::DR
DCMI data register, Address offset: 0x28
◆ ESCR
__IO uint32_t DCMI_TypeDef::ESCR
DCMI embedded synchronization code register, Address offset: 0x18
◆ ESUR
__IO uint32_t DCMI_TypeDef::ESUR
DCMI embedded synchronization unmask register, Address offset: 0x1C
◆ ICR
__IO uint32_t DCMI_TypeDef::ICR
DCMI interrupt clear register, Address offset: 0x14
◆ IER
__IO uint32_t DCMI_TypeDef::IER
DCMI interrupt enable register, Address offset: 0x0C
◆ MISR
__IO uint32_t DCMI_TypeDef::MISR
DCMI masked interrupt status register, Address offset: 0x10
◆ RISR
__IO uint32_t DCMI_TypeDef::RISR
DCMI raw interrupt status register, Address offset: 0x08
◆ SR
__IO uint32_t DCMI_TypeDef::SR
DCMI status register, Address offset: 0x04
The documentation for this struct was generated from the following files:
