RTEMS 6.1
Debug MCU. More...
#include <stm32h723xx.h>
Data Fields | |
| __IO uint32_t | IDCODE |
| __IO uint32_t | CR |
| uint32_t | RESERVED4 [11] |
| __IO uint32_t | APB3FZ1 |
| uint32_t | RESERVED5 |
| __IO uint32_t | APB1LFZ1 |
| uint32_t | RESERVED6 |
| __IO uint32_t | APB1HFZ1 |
| uint32_t | RESERVED7 |
| __IO uint32_t | APB2FZ1 |
| uint32_t | RESERVED8 |
| __IO uint32_t | APB4FZ1 |
| __IO uint32_t | RESERVED9 [990] |
| __IO uint32_t | PIDR4 |
| __IO uint32_t | RESERVED10 [3] |
| __IO uint32_t | PIDR0 |
| __IO uint32_t | PIDR1 |
| __IO uint32_t | PIDR2 |
| __IO uint32_t | PIDR3 |
| __IO uint32_t | CIDR0 |
| __IO uint32_t | CIDR1 |
| __IO uint32_t | CIDR2 |
| __IO uint32_t | CIDR3 |
| __IO uint32_t | RESERVED4 [11] |
| __IO uint32_t | APB3FZ2 |
| __IO uint32_t | APB1LFZ2 |
| __IO uint32_t | APB1HFZ2 |
| __IO uint32_t | APB2FZ2 |
| __IO uint32_t | APB4FZ2 |
Debug MCU.
| __IO uint32_t DBGMCU_TypeDef::APB1HFZ1 |
Debug MCU APB1LFZ1 freeze register, Address offset: 0x44
| __IO uint32_t DBGMCU_TypeDef::APB1HFZ2 |
Debug MCU APB1LFZ2 freeze register, Address offset: 0x48
| __IO uint32_t DBGMCU_TypeDef::APB1LFZ1 |
Debug MCU APB1LFZ1 freeze register, Address offset: 0x3C
| __IO uint32_t DBGMCU_TypeDef::APB1LFZ2 |
Debug MCU APB1LFZ2 freeze register, Address offset: 0x40
| __IO uint32_t DBGMCU_TypeDef::APB2FZ1 |
Debug MCU APB2FZ1 freeze register, Address offset: 0x4C
| __IO uint32_t DBGMCU_TypeDef::APB2FZ2 |
Debug MCU APB2FZ2 freeze register, Address offset: 0x50
| __IO uint32_t DBGMCU_TypeDef::APB3FZ1 |
Debug MCU APB3FZ1 freeze register, Address offset: 0x34
| __IO uint32_t DBGMCU_TypeDef::APB3FZ2 |
Debug MCU APB3FZ2 freeze register, Address offset: 0x38
| __IO uint32_t DBGMCU_TypeDef::APB4FZ1 |
Debug MCU APB4FZ1 freeze register, Address offset: 0x54
| __IO uint32_t DBGMCU_TypeDef::APB4FZ2 |
Debug MCU APB4FZ2 freeze register, Address offset: 0x58
| __IO uint32_t DBGMCU_TypeDef::CIDR0 |
Debug MCU component identity register 0, Address offset: 0xFF0
| __IO uint32_t DBGMCU_TypeDef::CIDR1 |
Debug MCU component identity register 1, Address offset: 0xFF4
| __IO uint32_t DBGMCU_TypeDef::CIDR2 |
Debug MCU component identity register 2, Address offset: 0xFF8
| __IO uint32_t DBGMCU_TypeDef::CIDR3 |
Debug MCU component identity register 3, Address offset: 0xFFC
| __IO uint32_t DBGMCU_TypeDef::CR |
Debug MCU configuration register, Address offset: 0x04
| __IO uint32_t DBGMCU_TypeDef::IDCODE |
MCU device ID code, Address offset: 0x00
| __IO uint32_t DBGMCU_TypeDef::PIDR0 |
Debug MCU peripheral identity register 0, Address offset: 0xFE0
| __IO uint32_t DBGMCU_TypeDef::PIDR1 |
Debug MCU peripheral identity register 1, Address offset: 0xFE4
| __IO uint32_t DBGMCU_TypeDef::PIDR2 |
Debug MCU peripheral identity register 2, Address offset: 0xFE8
| __IO uint32_t DBGMCU_TypeDef::PIDR3 |
Debug MCU peripheral identity register 3, Address offset: 0xFEC
| __IO uint32_t DBGMCU_TypeDef::PIDR4 |
Debug MCU peripheral identity register 4, Address offset: 0xFD0
| __IO uint32_t DBGMCU_TypeDef::RESERVED10 |
Reserved, Address offset: 0xFD4-0xFDC
| uint32_t DBGMCU_TypeDef::RESERVED4 |
Reserved, Address offset: 0x08
| __IO uint32_t DBGMCU_TypeDef::RESERVED4[11] |
| uint32_t DBGMCU_TypeDef::RESERVED5 |
Reserved, Address offset: 0x38
| uint32_t DBGMCU_TypeDef::RESERVED6 |
Reserved, Address offset: 0x40
| uint32_t DBGMCU_TypeDef::RESERVED7 |
Reserved, Address offset: 0x48
| uint32_t DBGMCU_TypeDef::RESERVED8 |
Reserved, Address offset: 0x50
| __IO uint32_t DBGMCU_TypeDef::RESERVED9 |
Reserved, Address offset: 0x58-0xFCC
