RTEMS 6.1
Digital to Analog Converter. More...
#include <stm32h723xx.h>
__IO uint32_t CR
__IO uint32_t SWTRIGR
__IO uint32_t DHR12R1
__IO uint32_t DHR12L1
__IO uint32_t DHR8R1
__IO uint32_t DHR12R2
__IO uint32_t DHR12L2
__IO uint32_t DHR8R2
__IO uint32_t DHR12RD
__IO uint32_t DHR12LD
__IO uint32_t DHR8RD
__IO uint32_t DOR1
__IO uint32_t DOR2
__IO uint32_t SR
__IO uint32_t CCR
__IO uint32_t MCR
__IO uint32_t SHSR1
__IO uint32_t SHSR2
__IO uint32_t SHHR
__IO uint32_t SHRR
Field Documentation
◆ CCR
__IO uint32_t DAC_TypeDef::CCR
DAC calibration control register, Address offset: 0x38
◆ CR
__IO uint32_t DAC_TypeDef::CR
DAC control register, Address offset: 0x00
◆ DHR12L1
__IO uint32_t DAC_TypeDef::DHR12L1
DAC channel1 12-bit left aligned data holding register, Address offset: 0x0C
◆ DHR12L2
__IO uint32_t DAC_TypeDef::DHR12L2
DAC channel2 12-bit left aligned data holding register, Address offset: 0x18
◆ DHR12LD
__IO uint32_t DAC_TypeDef::DHR12LD
DUAL DAC 12-bit left aligned data holding register, Address offset: 0x24
◆ DHR12R1
__IO uint32_t DAC_TypeDef::DHR12R1
DAC channel1 12-bit right-aligned data holding register, Address offset: 0x08
◆ DHR12R2
__IO uint32_t DAC_TypeDef::DHR12R2
DAC channel2 12-bit right aligned data holding register, Address offset: 0x14
◆ DHR12RD
__IO uint32_t DAC_TypeDef::DHR12RD
Dual DAC 12-bit right-aligned data holding register, Address offset: 0x20
◆ DHR8R1
__IO uint32_t DAC_TypeDef::DHR8R1
DAC channel1 8-bit right aligned data holding register, Address offset: 0x10
◆ DHR8R2
__IO uint32_t DAC_TypeDef::DHR8R2
DAC channel2 8-bit right-aligned data holding register, Address offset: 0x1C
◆ DHR8RD
__IO uint32_t DAC_TypeDef::DHR8RD
DUAL DAC 8-bit right aligned data holding register, Address offset: 0x28
◆ DOR1
__IO uint32_t DAC_TypeDef::DOR1
DAC channel1 data output register, Address offset: 0x2C
◆ DOR2
__IO uint32_t DAC_TypeDef::DOR2
DAC channel2 data output register, Address offset: 0x30
◆ MCR
__IO uint32_t DAC_TypeDef::MCR
DAC mode control register, Address offset: 0x3C
◆ SHHR
__IO uint32_t DAC_TypeDef::SHHR
DAC Sample and Hold hold time register, Address offset: 0x48
◆ SHRR
__IO uint32_t DAC_TypeDef::SHRR
DAC Sample and Hold refresh time register, Address offset: 0x4C
◆ SHSR1
__IO uint32_t DAC_TypeDef::SHSR1
DAC Sample and Hold sample time register 1, Address offset: 0x40
◆ SHSR2
__IO uint32_t DAC_TypeDef::SHSR2
DAC Sample and Hold sample time register 2, Address offset: 0x44
◆ SR
__IO uint32_t DAC_TypeDef::SR
DAC status register, Address offset: 0x34
◆ SWTRIGR
__IO uint32_t DAC_TypeDef::SWTRIGR
DAC software trigger register, Address offset: 0x04
The documentation for this struct was generated from the following files:
