RTEMS 6.1
CORE_message_queue_Buffer Struct Reference
The structure is used to organize message buffers of a message queue. More...
#include <coremsgbuffer.h>
Chain_Node Node
 This member is used to enqueue the buffer in the pending or free buffer queue of a message queue.
size_t size
 This member defines the size of this message.
int priority
 This member defines the priority of this message.
size_t buffer [RTEMS_ZERO_LENGTH_ARRAY]
 This member contains the actual message.
Field Documentation
◆ buffer
size_t CORE_message_queue_Buffer::buffer[RTEMS_ZERO_LENGTH_ARRAY]
This is a zero-length array since the maximum message size is defined by the user. Use a size_t array to make sure that the member offset is at the structure end. This enables a more efficient memcpy() on 64-bit targets and makes it easier to inspect the message buffers with a debugger.
