RTEMS 6.1
__IO uint32_t CFGR
Field Documentation
◆ CFGR
__IO uint32_t COMP_Common_TypeDef::CFGR
COMP control and status register, used for bits common to several COMP instances, Address offset: 0x00
The documentation for this struct was generated from the following files:
