RTEMS 6.1
CLKCON::_reg Struct Reference
unsigned STOP_BIT:1
unsigned SL_IDLE:1
unsigned IDLE_BIT:1
unsigned LCDC:1
unsigned USB_host:1
unsigned USB_device:1
unsigned PWMTIMER:1
unsigned MMC:1
unsigned UART0:1
unsigned UART1:1
unsigned GPIO:1
unsigned RTC:1
unsigned ADC:1
unsigned IIC:1
unsigned IIS:1
unsigned SPI:1
unsigned SM_BIT:1
unsigned Reserved:1
unsigned POWER_OFF:1
unsigned NAND_flash:1
unsigned SDI:1
unsigned UART2:1
The documentation for this struct was generated from the following files:
