RTEMS 6.1
Consumer Electronics Control. More...
#include <stm32h723xx.h>
__IO uint32_t CR
__IO uint32_t CFGR
__IO uint32_t TXDR
__IO uint32_t RXDR
__IO uint32_t ISR
__IO uint32_t IER
Field Documentation
◆ CFGR
__IO uint32_t CEC_TypeDef::CFGR
CEC configuration register, Address offset:0x04
◆ CR
__IO uint32_t CEC_TypeDef::CR
CEC control register, Address offset:0x00
◆ IER
__IO uint32_t CEC_TypeDef::IER
CEC interrupt enable register, Address offset:0x14
◆ ISR
__IO uint32_t CEC_TypeDef::ISR
CEC Interrupt and Status Register, Address offset:0x10
◆ RXDR
__IO uint32_t CEC_TypeDef::RXDR
CEC Rx Data Register, Address offset:0x0C
◆ TXDR
__IO uint32_t CEC_TypeDef::TXDR
CEC Tx data register , Address offset:0x08
The documentation for this struct was generated from the following files:
