RTEMS 6.1
#include <MIMXRT1052.h>
__IO uint32_t CCR
uint8_t RESERVED_0 [4]
__I uint32_t CSR
__IO uint32_t CCSR
__IO uint32_t CACRR
__IO uint32_t CBCDR
__IO uint32_t CBCMR
__IO uint32_t CSCMR1
__IO uint32_t CSCMR2
__IO uint32_t CSCDR1
__IO uint32_t CS1CDR
__IO uint32_t CS2CDR
__IO uint32_t CDCDR
uint8_t RESERVED_1 [4]
__IO uint32_t CSCDR2
__IO uint32_t CSCDR3
uint8_t RESERVED_2 [8]
__I uint32_t CDHIPR
uint8_t RESERVED_3 [8]
__IO uint32_t CLPCR
__IO uint32_t CISR
__IO uint32_t CIMR
__IO uint32_t CCOSR
__IO uint32_t CGPR
__IO uint32_t CCGR0
__IO uint32_t CCGR1
__IO uint32_t CCGR2
__IO uint32_t CCGR3
__IO uint32_t CCGR4
__IO uint32_t CCGR5
__IO uint32_t CCGR6
uint8_t RESERVED_4 [4]
__IO uint32_t CMEOR
struct {
   __IO uint32_t   CCM_Type::CONTROL
   __IO uint32_t   CCM_Type::CONTROL_SET
   __IO uint32_t   CCM_Type::CONTROL_CLR
   __IO uint32_t   CCM_Type::CONTROL_TOG
   uint8_t   RESERVED_0 [16]
   __I uint32_t   CCM_Type::STATUS0
   __I uint32_t   CCM_Type::STATUS1
   __I uint32_t   CCM_Type::CONFIG
   __IO uint32_t   CCM_Type::AUTHEN
   __IO uint32_t   CCM_Type::AUTHEN_SET
   __IO uint32_t   CCM_Type::AUTHEN_CLR
   __IO uint32_t   CCM_Type::AUTHEN_TOG
   __IO uint32_t   CCM_Type::SETPOINT [16]
CLOCK_ROOT [79]
struct {
   __IO uint32_t   CCM_Type::STATUS0
CLOCK_GROUP [2]
struct {
   __IO uint32_t   CCM_Type::GPR_SHARED
   __IO uint32_t   CCM_Type::CLR
   __IO uint32_t   CCM_Type::TOG
GPR_SHARED [8]
__IO uint32_t GPR_PRIVATE1
__IO uint32_t GPR_PRIVATE1_SET
__IO uint32_t GPR_PRIVATE1_CLR
__IO uint32_t GPR_PRIVATE1_TOG
__IO uint32_t GPR_PRIVATE1_AUTHEN
__IO uint32_t GPR_PRIVATE1_AUTHEN_SET
__IO uint32_t GPR_PRIVATE1_AUTHEN_CLR
__IO uint32_t GPR_PRIVATE1_AUTHEN_TOG
__IO uint32_t GPR_PRIVATE2
__IO uint32_t GPR_PRIVATE2_SET
__IO uint32_t GPR_PRIVATE2_CLR
__IO uint32_t GPR_PRIVATE2_TOG
__IO uint32_t GPR_PRIVATE2_AUTHEN
__IO uint32_t GPR_PRIVATE2_AUTHEN_SET
__IO uint32_t GPR_PRIVATE2_AUTHEN_CLR
__IO uint32_t GPR_PRIVATE2_AUTHEN_TOG
__IO uint32_t GPR_PRIVATE3
__IO uint32_t GPR_PRIVATE3_SET
__IO uint32_t GPR_PRIVATE3_CLR
__IO uint32_t GPR_PRIVATE3_TOG
__IO uint32_t GPR_PRIVATE3_AUTHEN
__IO uint32_t GPR_PRIVATE3_AUTHEN_SET
__IO uint32_t GPR_PRIVATE3_AUTHEN_CLR
__IO uint32_t GPR_PRIVATE3_AUTHEN_TOG
__IO uint32_t GPR_PRIVATE4
__IO uint32_t GPR_PRIVATE4_SET
__IO uint32_t GPR_PRIVATE4_CLR
__IO uint32_t GPR_PRIVATE4_TOG
__IO uint32_t GPR_PRIVATE4_AUTHEN
__IO uint32_t GPR_PRIVATE4_AUTHEN_SET
__IO uint32_t GPR_PRIVATE4_AUTHEN_CLR
__IO uint32_t GPR_PRIVATE4_AUTHEN_TOG
__IO uint32_t GPR_PRIVATE5
__IO uint32_t GPR_PRIVATE5_SET
__IO uint32_t GPR_PRIVATE5_CLR
__IO uint32_t GPR_PRIVATE5_TOG
__IO uint32_t GPR_PRIVATE5_AUTHEN
__IO uint32_t GPR_PRIVATE5_AUTHEN_SET
__IO uint32_t GPR_PRIVATE5_AUTHEN_CLR
__IO uint32_t GPR_PRIVATE5_AUTHEN_TOG
__IO uint32_t GPR_PRIVATE6
__IO uint32_t GPR_PRIVATE6_SET
__IO uint32_t GPR_PRIVATE6_CLR
__IO uint32_t GPR_PRIVATE6_TOG
__IO uint32_t GPR_PRIVATE6_AUTHEN
__IO uint32_t GPR_PRIVATE6_AUTHEN_SET
__IO uint32_t GPR_PRIVATE6_AUTHEN_CLR
__IO uint32_t GPR_PRIVATE6_AUTHEN_TOG
__IO uint32_t GPR_PRIVATE7
__IO uint32_t GPR_PRIVATE7_SET
__IO uint32_t GPR_PRIVATE7_CLR
__IO uint32_t GPR_PRIVATE7_TOG
__IO uint32_t GPR_PRIVATE7_AUTHEN
__IO uint32_t GPR_PRIVATE7_AUTHEN_SET
__IO uint32_t GPR_PRIVATE7_AUTHEN_CLR
__IO uint32_t GPR_PRIVATE7_AUTHEN_TOG
struct {
   __IO uint32_t   CCM_Type::DIRECT
   __IO uint32_t   CCM_Type::DOMAINr
OSCPLL [29]
struct {
LPCG [138]
struct {
CLOCK_ROOT [79]
struct {
CLOCK_GROUP [2]
struct {
GPR_SHARED [8]
struct {
OSCPLL [29]
struct {
LPCG [138]
CCM - Register Layout Typedef
The documentation for this struct was generated from the following files:
