RTEMS 6.1
#include <MIMXRT1052.h>
Data Fields | |
| __IO uint32_t | PLL_ARM |
| __IO uint32_t | PLL_ARM_SET |
| __IO uint32_t | PLL_ARM_CLR |
| __IO uint32_t | PLL_ARM_TOG |
| __IO uint32_t | PLL_USB1 |
| __IO uint32_t | PLL_USB1_SET |
| __IO uint32_t | PLL_USB1_CLR |
| __IO uint32_t | PLL_USB1_TOG |
| __IO uint32_t | PLL_USB2 |
| __IO uint32_t | PLL_USB2_SET |
| __IO uint32_t | PLL_USB2_CLR |
| __IO uint32_t | PLL_USB2_TOG |
| __IO uint32_t | PLL_SYS |
| __IO uint32_t | PLL_SYS_SET |
| __IO uint32_t | PLL_SYS_CLR |
| __IO uint32_t | PLL_SYS_TOG |
| __IO uint32_t | PLL_SYS_SS |
| uint8_t | RESERVED_0 [12] |
| __IO uint32_t | PLL_SYS_NUM |
| uint8_t | RESERVED_1 [12] |
| __IO uint32_t | PLL_SYS_DENOM |
| uint8_t | RESERVED_2 [12] |
| __IO uint32_t | PLL_AUDIO |
| __IO uint32_t | PLL_AUDIO_SET |
| __IO uint32_t | PLL_AUDIO_CLR |
| __IO uint32_t | PLL_AUDIO_TOG |
| __IO uint32_t | PLL_AUDIO_NUM |
| uint8_t | RESERVED_3 [12] |
| __IO uint32_t | PLL_AUDIO_DENOM |
| uint8_t | RESERVED_4 [12] |
| __IO uint32_t | PLL_VIDEO |
| __IO uint32_t | PLL_VIDEO_SET |
| __IO uint32_t | PLL_VIDEO_CLR |
| __IO uint32_t | PLL_VIDEO_TOG |
| __IO uint32_t | PLL_VIDEO_NUM |
| uint8_t | RESERVED_5 [12] |
| __IO uint32_t | PLL_VIDEO_DENOM |
| uint8_t | RESERVED_6 [28] |
| __IO uint32_t | PLL_ENET |
| __IO uint32_t | PLL_ENET_SET |
| __IO uint32_t | PLL_ENET_CLR |
| __IO uint32_t | PLL_ENET_TOG |
| __IO uint32_t | PFD_480 |
| __IO uint32_t | PFD_480_SET |
| __IO uint32_t | PFD_480_CLR |
| __IO uint32_t | PFD_480_TOG |
| __IO uint32_t | PFD_528 |
| __IO uint32_t | PFD_528_SET |
| __IO uint32_t | PFD_528_CLR |
| __IO uint32_t | PFD_528_TOG |
| uint8_t | RESERVED_7 [64] |
| __IO uint32_t | MISC0 |
| __IO uint32_t | MISC0_SET |
| __IO uint32_t | MISC0_CLR |
| __IO uint32_t | MISC0_TOG |
| __IO uint32_t | MISC1 |
| __IO uint32_t | MISC1_SET |
| __IO uint32_t | MISC1_CLR |
| __IO uint32_t | MISC1_TOG |
| __IO uint32_t | MISC2 |
| __IO uint32_t | MISC2_SET |
| __IO uint32_t | MISC2_CLR |
| __IO uint32_t | MISC2_TOG |
CCM_ANALOG - Register Layout Typedef
