RTEMS 6.1
Test context for spec:/bsp/sparc/leon3/val/fatal-clock-initialization test case. More...
rtems_fatal_source source
 This member contains a copy of the corresponding BspSparcLeon3ValFatalClockInitialization_Run() parameter.
rtems_fatal_code code
