RTEMS 6.1
__IO uint32_t CCR
__IO uint32_t CNDTR
__IO uint32_t CPAR
__IO uint32_t CM0AR
__IO uint32_t CM1AR
Field Documentation
◆ CCR
__IO uint32_t BDMA_Channel_TypeDef::CCR
DMA channel x configuration register
◆ CM0AR
__IO uint32_t BDMA_Channel_TypeDef::CM0AR
DMA channel x memory 0 address register
◆ CM1AR
__IO uint32_t BDMA_Channel_TypeDef::CM1AR
DMA channel x memory 1 address register
◆ CNDTR
__IO uint32_t BDMA_Channel_TypeDef::CNDTR
DMA channel x number of data register
◆ CPAR
__IO uint32_t BDMA_Channel_TypeDef::CPAR
DMA channel x peripheral address register
The documentation for this struct was generated from the following files:
