RTEMS
6.1
AUDIO_PLL_Type Struct Reference
Mapping Information
Iomuxc_pads
Device Peripheral Access Layer
AUDIO_PLL Peripheral Access Layer
MIMXRT1166_cm4.h
struct {
__IO
uint32_t
AUDIO_PLL_Type::RW
__IO
uint32_t
AUDIO_PLL_Type::SET
__IO
uint32_t
AUDIO_PLL_Type::CLR
__IO
uint32_t
AUDIO_PLL_Type::TOG
CTRL0
struct {
__IO
uint32_t
AUDIO_PLL_Type::RW
__IO
uint32_t
AUDIO_PLL_Type::SET
__IO
uint32_t
AUDIO_PLL_Type::CLR
__IO
uint32_t
AUDIO_PLL_Type::TOG
SPREAD_SPECTRUM
struct {
__IO
uint32_t
AUDIO_PLL_Type::RW
__IO
uint32_t
AUDIO_PLL_Type::SET
__IO
uint32_t
AUDIO_PLL_Type::CLR
__IO
uint32_t
AUDIO_PLL_Type::TOG
NUMERATOR
struct {
__IO
uint32_t
AUDIO_PLL_Type::RW
__IO
uint32_t
AUDIO_PLL_Type::SET
__IO
uint32_t
AUDIO_PLL_Type::CLR
__IO
uint32_t
AUDIO_PLL_Type::TOG
DENOMINATOR
struct {
__IO
uint32_t
AUDIO_PLL_Type::RW
__IO
uint32_t
AUDIO_PLL_Type::SET
__IO
uint32_t
AUDIO_PLL_Type::CLR
__IO
uint32_t
AUDIO_PLL_Type::TOG
CTRL0
struct {
__IO
uint32_t
AUDIO_PLL_Type::RW
__IO
uint32_t
AUDIO_PLL_Type::SET
__IO
uint32_t
AUDIO_PLL_Type::CLR
__IO
uint32_t
AUDIO_PLL_Type::TOG
SPREAD_SPECTRUM
struct {
__IO
uint32_t
AUDIO_PLL_Type::RW
__IO
uint32_t
AUDIO_PLL_Type::SET
__IO
uint32_t
AUDIO_PLL_Type::CLR
__IO
uint32_t
AUDIO_PLL_Type::TOG
NUMERATOR
struct {
__IO
uint32_t
AUDIO_PLL_Type::RW
__IO
uint32_t
AUDIO_PLL_Type::SET
__IO
uint32_t
AUDIO_PLL_Type::CLR
__IO
uint32_t
AUDIO_PLL_Type::TOG
DENOMINATOR
AUDIO_PLL - Register Layout Typedef
The documentation for this struct was generated from the following files:
bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/
MIMXRT1166_cm4.h
MIMXRT1166_cm7.h
