RTEMS 6.1
#include <MIMXRT1166_cm4.h>
uint8_t RESERVED_0 [1280]
__IO uint32_t PMU_LDO_PLL
uint8_t RESERVED_1 [76]
__IO uint32_t PMU_BIAS_CTRL
uint8_t RESERVED_2 [12]
__IO uint32_t PMU_BIAS_CTRL2
uint8_t RESERVED_3 [12]
__IO uint32_t PMU_REF_CTRL
uint8_t RESERVED_4 [12]
__IO uint32_t PMU_POWER_DETECT_CTRL
uint8_t RESERVED_5 [124]
__IO uint32_t LDO_PLL_ENABLE_SP
uint8_t RESERVED_6 [12]
__IO uint32_t LDO_LPSR_ANA_ENABLE_SP
uint8_t RESERVED_7 [12]
__IO uint32_t LDO_LPSR_ANA_LP_MODE_SP
uint8_t RESERVED_8 [12]
__IO uint32_t LDO_LPSR_ANA_TRACKING_EN_SP
uint8_t RESERVED_9 [12]
__IO uint32_t LDO_LPSR_ANA_BYPASS_EN_SP
uint8_t RESERVED_10 [12]
__IO uint32_t LDO_LPSR_ANA_STBY_EN_SP
uint8_t RESERVED_11 [12]
__IO uint32_t LDO_LPSR_DIG_ENABLE_SP
uint8_t RESERVED_12 [12]
__IO uint32_t LDO_LPSR_DIG_TRG_SP0
uint8_t RESERVED_13 [12]
__IO uint32_t LDO_LPSR_DIG_TRG_SP1
uint8_t RESERVED_14 [12]
__IO uint32_t LDO_LPSR_DIG_TRG_SP2
uint8_t RESERVED_15 [12]
__IO uint32_t LDO_LPSR_DIG_TRG_SP3
uint8_t RESERVED_16 [12]
__IO uint32_t LDO_LPSR_DIG_LP_MODE_SP
uint8_t RESERVED_17 [12]
__IO uint32_t LDO_LPSR_DIG_TRACKING_EN_SP
uint8_t RESERVED_18 [12]
__IO uint32_t LDO_LPSR_DIG_BYPASS_EN_SP
uint8_t RESERVED_19 [12]
__IO uint32_t LDO_LPSR_DIG_STBY_EN_SP
uint8_t RESERVED_20 [12]
__IO uint32_t BANDGAP_ENABLE_SP
uint8_t RESERVED_21 [28]
__IO uint32_t RBB_SOC_ENABLE_SP
uint8_t RESERVED_22 [12]
__IO uint32_t RBB_LPSR_ENABLE_SP
uint8_t RESERVED_23 [12]
__IO uint32_t BANDGAP_STBY_EN_SP
uint8_t RESERVED_24 [12]
__IO uint32_t PLL_LDO_STBY_EN_SP
uint8_t RESERVED_25 [28]
__IO uint32_t RBB_SOC_STBY_EN_SP
uint8_t RESERVED_26 [12]
__IO uint32_t RBB_LPSR_STBY_EN_SP
uint8_t RESERVED_27 [28]
__IO uint32_t RBB_LPSR_CONFIGURE
uint8_t RESERVED_28 [12]
__IO uint32_t RBB_SOC_CONFIGURE
uint8_t RESERVED_29 [12]
__I uint32_t REFTOP_OTP_TRIM_VALUE
uint8_t RESERVED_30 [28]
__I uint32_t LPSR_1P8_LDO_OTP_TRIM_VALUE
ANADIG_PMU - Register Layout Typedef
The documentation for this struct was generated from the following files:
