RTEMS 6.1
#include <MIMXRT1166_cm4.h>
uint8_t RESERVED_0 [512]
__IO uint32_t ARM_PLL_CTRL
uint8_t RESERVED_1 [12]
__IO uint32_t SYS_PLL3_CTRL
uint8_t RESERVED_2 [12]
__IO uint32_t SYS_PLL3_UPDATE
uint8_t RESERVED_3 [12]
__IO uint32_t SYS_PLL3_PFD
uint8_t RESERVED_4 [12]
__IO uint32_t SYS_PLL2_CTRL
uint8_t RESERVED_5 [12]
__IO uint32_t SYS_PLL2_UPDATE
uint8_t RESERVED_6 [12]
__IO uint32_t SYS_PLL2_SS
uint8_t RESERVED_7 [12]
__IO uint32_t SYS_PLL2_PFD
uint8_t RESERVED_8 [44]
__IO uint32_t SYS_PLL2_MFD
uint8_t RESERVED_9 [12]
__IO uint32_t SYS_PLL1_SS
uint8_t RESERVED_10 [12]
__IO uint32_t SYS_PLL1_CTRL
uint8_t RESERVED_11 [12]
__IO uint32_t SYS_PLL1_DENOMINATOR
uint8_t RESERVED_12 [12]
__IO uint32_t SYS_PLL1_NUMERATOR
uint8_t RESERVED_13 [12]
__IO uint32_t SYS_PLL1_DIV_SELECT
uint8_t RESERVED_14 [12]
__IO uint32_t PLL_AUDIO_CTRL
uint8_t RESERVED_15 [12]
__IO uint32_t PLL_AUDIO_SS
uint8_t RESERVED_16 [12]
__IO uint32_t PLL_AUDIO_DENOMINATOR
uint8_t RESERVED_17 [12]
__IO uint32_t PLL_AUDIO_NUMERATOR
uint8_t RESERVED_18 [12]
__IO uint32_t PLL_AUDIO_DIV_SELECT
uint8_t RESERVED_19 [12]
__IO uint32_t PLL_VIDEO_CTRL
uint8_t RESERVED_20 [12]
__IO uint32_t PLL_VIDEO_SS
uint8_t RESERVED_21 [12]
__IO uint32_t PLL_VIDEO_DENOMINATOR
uint8_t RESERVED_22 [12]
__IO uint32_t PLL_VIDEO_NUMERATOR
uint8_t RESERVED_23 [12]
__IO uint32_t PLL_VIDEO_DIV_SELECT
ANADIG_PLL - Register Layout Typedef
The documentation for this struct was generated from the following files:
