RTEMS 6.1
#include <alt_generalpurpose_io.h>
ALT_GPIO_1BIT_t signal_number
ALT_GPIO_PIN_DIR_t direction
ALT_GPIO_PIN_TYPE_t type
ALT_GPIO_PIN_POL_t polarity
ALT_GPIO_PIN_DEBOUNCE_t debounce
ALT_GPIO_PIN_DATA_t data
This configuration record definition is used for configuring bits and groups of bits of the GPIO interface.
Field Documentation
◆ data
ALT_GPIO_PIN_DATA_t ALT_GPIO_CONFIG_RECORD_s::data
If the signal is an output, the data value to be output.
◆ debounce
ALT_GPIO_PIN_DEBOUNCE_t ALT_GPIO_CONFIG_RECORD_s::debounce
Enable or disable GPIO debounce capability.
◆ direction
ALT_GPIO_PIN_DIR_t ALT_GPIO_CONFIG_RECORD_s::direction
The data direction of the signal.
◆ polarity
ALT_GPIO_PIN_POL_t ALT_GPIO_CONFIG_RECORD_s::polarity
Active-high or active-low trigger for the interrupt.
◆ signal_number
ALT_GPIO_1BIT_t ALT_GPIO_CONFIG_RECORD_s::signal_number
The index number of the signal to configure.
◆ type
ALT_GPIO_PIN_TYPE_t ALT_GPIO_CONFIG_RECORD_s::type
Edge-triggered or level triggered interrupts.
