RTEMS 6.1
Analog to Digital Converter. More...
#include <stm32h723xx.h>
Data Fields | |
| __IO uint32_t | ISR |
| __IO uint32_t | IER |
| __IO uint32_t | CR |
| __IO uint32_t | CFGR |
| __IO uint32_t | CFGR2 |
| __IO uint32_t | SMPR1 |
| __IO uint32_t | SMPR2 |
| __IO uint32_t | PCSEL_RES0 |
| __IO uint32_t | LTR1_TR1 |
| __IO uint32_t | HTR1_TR2 |
| __IO uint32_t | RES1_TR3 |
| uint32_t | RESERVED2 |
| __IO uint32_t | SQR1 |
| __IO uint32_t | SQR2 |
| __IO uint32_t | SQR3 |
| __IO uint32_t | SQR4 |
| __IO uint32_t | DR |
| uint32_t | RESERVED3 |
| uint32_t | RESERVED4 |
| __IO uint32_t | JSQR |
| uint32_t | RESERVED5 [4] |
| __IO uint32_t | OFR1 |
| __IO uint32_t | OFR2 |
| __IO uint32_t | OFR3 |
| __IO uint32_t | OFR4 |
| uint32_t | RESERVED6 [4] |
| __IO uint32_t | JDR1 |
| __IO uint32_t | JDR2 |
| __IO uint32_t | JDR3 |
| __IO uint32_t | JDR4 |
| uint32_t | RESERVED7 [4] |
| __IO uint32_t | AWD2CR |
| __IO uint32_t | AWD3CR |
| uint32_t | RESERVED8 |
| uint32_t | RESERVED9 |
| __IO uint32_t | LTR2_DIFSEL |
| __IO uint32_t | HTR2_CALFACT |
| __IO uint32_t | LTR3_RES10 |
| __IO uint32_t | HTR3_RES11 |
| __IO uint32_t | DIFSEL_RES12 |
| __IO uint32_t | CALFACT_RES13 |
| __IO uint32_t | CALFACT2_RES14 |
| __IO uint32_t | PCSEL |
| __IO uint32_t | LTR1 |
| __IO uint32_t | HTR1 |
| uint32_t | RESERVED1 |
| __IO uint32_t | LTR2 |
| __IO uint32_t | HTR2 |
| __IO uint32_t | LTR3 |
| __IO uint32_t | HTR3 |
| __IO uint32_t | DIFSEL |
| __IO uint32_t | CALFACT |
| __IO uint32_t | CALFACT2 |
| __IO uint32_t ADC_TypeDef::AWD2CR |
ADC Analog Watchdog 2 Configuration Register, Address offset: 0xA0
| __IO uint32_t ADC_TypeDef::AWD3CR |
ADC Analog Watchdog 3 Configuration Register, Address offset: 0xA4
| __IO uint32_t ADC_TypeDef::CALFACT |
ADC Calibration Factors, Address offset: 0xC4
| __IO uint32_t ADC_TypeDef::CALFACT2 |
ADC Linearity Calibration Factors, Address offset: 0xC8
| __IO uint32_t ADC_TypeDef::CALFACT2_RES14 |
ADC Linearity Calibration Factors specific ADC1/2, Address offset: 0xC8
| __IO uint32_t ADC_TypeDef::CALFACT_RES13 |
ADC Calibration Factors specific ADC1/2, Address offset: 0xC4
| __IO uint32_t ADC_TypeDef::CFGR |
ADC Configuration register, Address offset: 0x0C
| __IO uint32_t ADC_TypeDef::CFGR2 |
ADC Configuration register 2, Address offset: 0x10
| __IO uint32_t ADC_TypeDef::CR |
ADC control register, Address offset: 0x08
| __IO uint32_t ADC_TypeDef::DIFSEL |
ADC Differential Mode Selection Register, Address offset: 0xC0
| __IO uint32_t ADC_TypeDef::DIFSEL_RES12 |
ADC Differential Mode Selection Register specific ADC1/2, Address offset: 0xC0
| __IO uint32_t ADC_TypeDef::DR |
ADC regular data register, Address offset: 0x40
| __IO uint32_t ADC_TypeDef::HTR1 |
ADC watchdog higher threshold register 1, Address offset: 0x24
| __IO uint32_t ADC_TypeDef::HTR1_TR2 |
| __IO uint32_t ADC_TypeDef::HTR2 |
ADC watchdog Higher threshold register 2, Address offset: 0xB4
| __IO uint32_t ADC_TypeDef::HTR2_CALFACT |
ADC watchdog Higher threshold register 2, Calfact for ADC3, Address offset: 0xB4
| __IO uint32_t ADC_TypeDef::HTR3 |
ADC watchdog Higher threshold register 3, Address offset: 0xBC
| __IO uint32_t ADC_TypeDef::HTR3_RES11 |
ADC watchdog Higher threshold register 3, specific ADC1/2, Address offset: 0xBC
| __IO uint32_t ADC_TypeDef::IER |
ADC Interrupt Enable Register, Address offset: 0x04
| __IO uint32_t ADC_TypeDef::ISR |
ADC Interrupt and Status Register, Address offset: 0x00
| __IO uint32_t ADC_TypeDef::JDR1 |
ADC injected data register 1, Address offset: 0x80
| __IO uint32_t ADC_TypeDef::JDR2 |
ADC injected data register 2, Address offset: 0x84
| __IO uint32_t ADC_TypeDef::JDR3 |
ADC injected data register 3, Address offset: 0x88
| __IO uint32_t ADC_TypeDef::JDR4 |
ADC injected data register 4, Address offset: 0x8C
| __IO uint32_t ADC_TypeDef::JSQR |
ADC injected sequence register, Address offset: 0x4C
| __IO uint32_t ADC_TypeDef::LTR1 |
ADC watchdog Lower threshold register 1, Address offset: 0x20
| __IO uint32_t ADC_TypeDef::LTR1_TR1 |
| __IO uint32_t ADC_TypeDef::LTR2 |
ADC watchdog Lower threshold register 2, Address offset: 0xB0
| __IO uint32_t ADC_TypeDef::LTR2_DIFSEL |
ADC watchdog Lower threshold register 2, Difsel for ADC3, Address offset: 0xB0
| __IO uint32_t ADC_TypeDef::LTR3 |
ADC watchdog Lower threshold register 3, Address offset: 0xB8
| __IO uint32_t ADC_TypeDef::LTR3_RES10 |
ADC watchdog Lower threshold register 3, specific ADC1/2, Address offset: 0xB8
| __IO uint32_t ADC_TypeDef::OFR1 |
ADC offset register 1, Address offset: 0x60
| __IO uint32_t ADC_TypeDef::OFR2 |
ADC offset register 2, Address offset: 0x64
| __IO uint32_t ADC_TypeDef::OFR3 |
ADC offset register 3, Address offset: 0x68
| __IO uint32_t ADC_TypeDef::OFR4 |
ADC offset register 4, Address offset: 0x6C
| __IO uint32_t ADC_TypeDef::PCSEL |
ADC pre-channel selection, Address offset: 0x1C
| __IO uint32_t ADC_TypeDef::PCSEL_RES0 |
Reserved for ADC3, ADC1/2 pre-channel selection, Address offset: 0x1C
| __IO uint32_t ADC_TypeDef::RES1_TR3 |
Reserved for ADC1/2, ADC3 threshold register, Address offset: 0x28
| uint32_t ADC_TypeDef::RESERVED1 |
Reserved, 0x028
| uint32_t ADC_TypeDef::RESERVED2 |
Reserved, 0x02C
| uint32_t ADC_TypeDef::RESERVED3 |
Reserved, 0x044
| uint32_t ADC_TypeDef::RESERVED4 |
Reserved, 0x048
| uint32_t ADC_TypeDef::RESERVED5 |
Reserved, 0x050 - 0x05C
| uint32_t ADC_TypeDef::RESERVED6 |
Reserved, 0x070 - 0x07C
| uint32_t ADC_TypeDef::RESERVED7 |
Reserved, 0x090 - 0x09C
| uint32_t ADC_TypeDef::RESERVED8 |
Reserved, 0x0A8
| uint32_t ADC_TypeDef::RESERVED9 |
Reserved, 0x0AC
| __IO uint32_t ADC_TypeDef::SMPR1 |
ADC sample time register 1, Address offset: 0x14
| __IO uint32_t ADC_TypeDef::SMPR2 |
ADC sample time register 2, Address offset: 0x18
| __IO uint32_t ADC_TypeDef::SQR1 |
ADC regular sequence register 1, Address offset: 0x30
| __IO uint32_t ADC_TypeDef::SQR2 |
ADC regular sequence register 2, Address offset: 0x34
| __IO uint32_t ADC_TypeDef::SQR3 |
ADC regular sequence register 3, Address offset: 0x38
| __IO uint32_t ADC_TypeDef::SQR4 |
ADC regular sequence register 4, Address offset: 0x3C
