RTEMS 6.1
Structure definition of ADC multimode. More...
#include <stm32h7xx_hal_adc_ex.h>
Data Fields | |
| uint32_t | Mode |
| uint32_t | DualModeData |
| uint32_t | TwoSamplingDelay |
| uint32_t ADC_MultiModeTypeDef::DualModeData |
Configures the Dual ADC Mode Data Format: This parameter can be a value of ADC Extended Dual Mode Data Formatting
| uint32_t ADC_MultiModeTypeDef::Mode |
Configures the ADC to operate in independent or multimode. This parameter can be a value of Multimode - Mode.
| uint32_t ADC_MultiModeTypeDef::TwoSamplingDelay |
Configures the Delay between 2 sampling phases. This parameter can be a value of Multimode - Delay between two sampling phases. Delay range depends on selected resolution: from 1 to 9 clock cycles for 16 bits, from 1 to 9 clock cycles for 14 bits from 1 to 8 clock cycles for 12 bits from 1 to 6 clock cycles for 10 bits from 1 to 6 clock cycles for 8 bits
