◆ CCR
| __IO uint32_t ADC_Common_TypeDef::CCR |
ADC common control register, Address offset: ADC1/3 base address + 0x308
◆ CDR
| __IO uint32_t ADC_Common_TypeDef::CDR |
ADC common regular data register for dual Address offset: ADC1/3 base address + 0x30C
◆ CDR2
| __IO uint32_t ADC_Common_TypeDef::CDR2 |
ADC common regular data register for 32-bit dual mode Address offset: ADC1/3 base address + 0x310
◆ CSR
| __IO uint32_t ADC_Common_TypeDef::CSR |
ADC Common status register, Address offset: ADC1/3 base address + 0x300
◆ RESERVED
| uint32_t ADC_Common_TypeDef::RESERVED |
Reserved, ADC1/3 base address + 0x304
The documentation for this struct was generated from the following files:
