RTEMS 6.1
ADC_ChannelConfTypeDef Struct Reference
Structure definition of ADC channel for regular group. More...
#include <stm32h7xx_hal_adc.h>
uint32_t Channel
uint32_t Rank
uint32_t SamplingTime
uint32_t SingleDiff
uint32_t OffsetNumber
uint32_t Offset
FunctionalState OffsetRightShift
FunctionalState OffsetSignedSaturation
Note
The setting of these parameters by function HAL_ADC_ConfigChannel() is conditioned to ADC state. ADC state can be either:
  • For all parameters: ADC disabled (this is the only possible ADC state to modify parameter 'SingleDiff')
  • For all except parameters 'SamplingTime', 'Offset', 'OffsetNumber': ADC enabled without conversion on going on regular group.
  • For parameters 'SamplingTime', 'Offset', 'OffsetNumber': ADC enabled without conversion on going on regular and injected groups. If ADC is not in the appropriate state to modify some parameters, these parameters setting is bypassed without error reporting (as it can be the expected behavior in case of intended action to update another parameter (which fulfills the ADC state condition) on the fly).
Field Documentation
◆ Channel
uint32_t ADC_ChannelConfTypeDef::Channel
Specify the channel to configure into ADC regular group. This parameter can be a value of ADC instance - Channel number Note: Depending on devices and ADC instances, some channels may not be available on device package pins. Refer to device datasheet for channels availability.
◆ Offset
uint32_t ADC_ChannelConfTypeDef::Offset
Define the offset to be subtracted from the raw converted data. Offset value must be a positive number. Maximum value depends on ADC resolution and oversampling ratio (in case of oversampling used). This parameter must be a number between Min_Data = 0x0000 and Max_Data = 0x3FFFC00 (corresponding to resolution 16 bit and oversampling ratio 1024). Note: This parameter must be modified when no conversion is on going on both regular and injected groups (ADC disabled, or ADC enabled without continuous mode or external trigger that could launch a conversion).
◆ OffsetNumber
uint32_t ADC_ChannelConfTypeDef::OffsetNumber
Select the offset number This parameter can be a value of ADC instance - Offset number Caution: Only one offset is allowed per channel. This parameter overwrites the last setting.
◆ OffsetRightShift
FunctionalState ADC_ChannelConfTypeDef::OffsetRightShift
Define the Right-shift data after Offset correction. This parameter is applied only for 16-bit or 8-bit resolution. This parameter can be set to ENABLE or DISABLE.
◆ OffsetSignedSaturation
FunctionalState ADC_ChannelConfTypeDef::OffsetSignedSaturation
Specify whether the Signed saturation feature is used or not. This parameter is applied only for 16-bit or 8-bit resolution. This parameter can be set to ENABLE or DISABLE.
◆ Rank
uint32_t ADC_ChannelConfTypeDef::Rank
Specify the rank in the regular group sequencer. This parameter can be a value of ADC group regular - Sequencer ranks Note: to disable a channel or change order of conversion sequencer, rank containing a previous channel setting can be overwritten by the new channel setting (or parameter number of conversions adjusted)
◆ SamplingTime
uint32_t ADC_ChannelConfTypeDef::SamplingTime
Sampling time value to be set for the selected channel. Unit: ADC clock cycles Conversion time is the addition of sampling time and processing time (12.5 ADC clock cycles at ADC resolution 12 bits, 10.5 cycles at 10 bits, 8.5 cycles at 8 bits, 6.5 cycles at 6 bits). This parameter can be a value of Channel - Sampling time Caution: This parameter applies to a channel that can be used into regular and/or injected group. It overwrites the last setting. Note: In case of usage of internal measurement channels (VrefInt/Vbat/TempSensor), sampling time constraints must be respected (sampling time can be adjusted in function of ADC clock frequency and sampling time setting) Refer to device datasheet for timings values.
◆ SingleDiff
uint32_t ADC_ChannelConfTypeDef::SingleDiff
Select single-ended or differential input. In differential mode: Differential measurement is carried out between the selected channel 'i' (positive input) and channel 'i+1' (negative input). Only channel 'i' has to be configured, channel 'i+1' is configured automatically. This parameter must be a value of Channel - Single or differential ending Caution: This parameter applies to a channel that can be used in a regular and/or injected group. It overwrites the last setting. Note: Refer to Reference Manual to ensure the selected channel is available in differential mode. Note: When configuring a channel 'i' in differential mode, the channel 'i+1' is not usable separately. Note: This parameter must be modified when ADC is disabled (before ADC start conversion or after ADC stop conversion). If ADC is enabled, this parameter setting is bypassed without error reporting (as it can be the expected behavior in case of another parameter update on the fly)
