RTEMS 6.1
Macros | Functions
stm32h7xx_hal_timebase_rtc_alarm_template.c File Reference
HAL time base based on the hardware RTC_ALARM Template. More...
#include "stm32h7xx_hal.h"
#define RTC_CLOCK_SOURCE_HSE
#define RTC_ASYNCH_PREDIV   99U
#define RTC_SYNCH_PREDIV   9U
#define RCC_RTCCLKSOURCE_1MHZ   ((uint32_t)((uint32_t)RCC_BDCR_RTCSEL | (uint32_t)((HSE_VALUE/1000000U) << 12U)))
void RTC_Alarm_IRQHandler (void)
 This function handles RTC ALARM interrupt request.
HAL_StatusTypeDef HAL_InitTick (uint32_t TickPriority)
 This function configures the RTC_ALARMA as a time base source. The time source is configured to have 1ms time base with a dedicated Tick interrupt priority.
void HAL_SuspendTick (void)
 Suspend Tick increment.
void HAL_ResumeTick (void)
 Resume Tick increment.
void HAL_RTC_AlarmAEventCallback (RTC_HandleTypeDef *hrtc)
 ALARM A Event Callback in non blocking mode.
Author
MCD Application Team
     This file override the native HAL time base functions (defined as weak)
     to use the RTC ALARM for time base generation:
      + Initializes the RTC peripheral to increment the seconds registers each 1ms
      + The alarm is configured to assert an interrupt when the RTC reaches 1ms
      + HAL_IncTick is called at each Alarm event and the time is reset to 00:00:00
      + HSE (default), LSE or LSI can be selected as RTC clock source
Attention
                       ##### How to use this driver #####
   This file must be copied to the application folder and modified as follows:
   (#) Rename it to 'stm32h7xx_hal_timebase_rtc_alarm.c'
   (#) Add this file and the RTC HAL drivers to your project and uncomment
      HAL_RTC_MODULE_ENABLED define in stm32h7xx_hal_conf.h
   (@) HAL RTC alarm and HAL RTC wakeup drivers can not be used with low power modes:
       The wake up capability of the RTC may be intrusive in case of prior low power mode
       configuration requiring different wake up sources.
       Application/Example behavior is no more guaranteed
   (@) The stm32h7xx_hal_timebase_tim use is recommended for the Applications/Examples
         requiring low power modes
