RTEMS 6.1
Data Structures | Macros | Typedefs | Enumerations | Functions
stm32h7xx_hal_spi.h File Reference
Header file of SPI HAL module. More...
#include "stm32h7xx_hal_def.h"
#include "stm32h7xx_hal_spi_ex.h"
struct  SPI_InitTypeDef
 SPI Configuration Structure definition. More...
struct  __SPI_HandleTypeDef
 SPI handle Structure definition. More...
#define SPI_LOWEND_FIFO_SIZE   8UL
#define SPI_HIGHEND_FIFO_SIZE   16UL
#define HAL_SPI_ERROR_NONE   (0x00000000UL)
#define HAL_SPI_ERROR_MODF   (0x00000001UL)
#define HAL_SPI_ERROR_CRC   (0x00000002UL)
#define HAL_SPI_ERROR_OVR   (0x00000004UL)
#define HAL_SPI_ERROR_FRE   (0x00000008UL)
#define HAL_SPI_ERROR_DMA   (0x00000010UL)
#define HAL_SPI_ERROR_FLAG   (0x00000020UL)
#define HAL_SPI_ERROR_ABORT   (0x00000040UL)
#define HAL_SPI_ERROR_UDR   (0x00000080UL)
#define HAL_SPI_ERROR_TIMEOUT   (0x00000100UL)
#define HAL_SPI_ERROR_UNKNOW   (0x00000200UL)
#define HAL_SPI_ERROR_NOT_SUPPORTED   (0x00000400UL)
#define HAL_SPI_ERROR_RELOAD   (0x00000800UL)
#define SPI_MODE_SLAVE   (0x00000000UL)
#define SPI_MODE_MASTER   SPI_CFG2_MASTER
#define SPI_DIRECTION_2LINES   (0x00000000UL)
#define SPI_DIRECTION_2LINES_TXONLY   SPI_CFG2_COMM_0
#define SPI_DIRECTION_2LINES_RXONLY   SPI_CFG2_COMM_1
#define SPI_DIRECTION_1LINE   SPI_CFG2_COMM
#define SPI_DATASIZE_4BIT   (0x00000003UL)
#define SPI_DATASIZE_5BIT   (0x00000004UL)
#define SPI_DATASIZE_6BIT   (0x00000005UL)
#define SPI_DATASIZE_7BIT   (0x00000006UL)
#define SPI_DATASIZE_8BIT   (0x00000007UL)
#define SPI_DATASIZE_9BIT   (0x00000008UL)
#define SPI_DATASIZE_10BIT   (0x00000009UL)
#define SPI_DATASIZE_11BIT   (0x0000000AUL)
#define SPI_DATASIZE_12BIT   (0x0000000BUL)
#define SPI_DATASIZE_13BIT   (0x0000000CUL)
#define SPI_DATASIZE_14BIT   (0x0000000DUL)
#define SPI_DATASIZE_15BIT   (0x0000000EUL)
#define SPI_DATASIZE_16BIT   (0x0000000FUL)
#define SPI_DATASIZE_17BIT   (0x00000010UL)
#define SPI_DATASIZE_18BIT   (0x00000011UL)
#define SPI_DATASIZE_19BIT   (0x00000012UL)
#define SPI_DATASIZE_20BIT   (0x00000013UL)
#define SPI_DATASIZE_21BIT   (0x00000014UL)
#define SPI_DATASIZE_22BIT   (0x00000015UL)
#define SPI_DATASIZE_23BIT   (0x00000016UL)
#define SPI_DATASIZE_24BIT   (0x00000017UL)
#define SPI_DATASIZE_25BIT   (0x00000018UL)
#define SPI_DATASIZE_26BIT   (0x00000019UL)
#define SPI_DATASIZE_27BIT   (0x0000001AUL)
#define SPI_DATASIZE_28BIT   (0x0000001BUL)
#define SPI_DATASIZE_29BIT   (0x0000001CUL)
#define SPI_DATASIZE_30BIT   (0x0000001DUL)
#define SPI_DATASIZE_31BIT   (0x0000001EUL)
#define SPI_DATASIZE_32BIT   (0x0000001FUL)
#define SPI_POLARITY_LOW   (0x00000000UL)
#define SPI_POLARITY_HIGH   SPI_CFG2_CPOL
#define SPI_PHASE_1EDGE   (0x00000000UL)
#define SPI_PHASE_2EDGE   SPI_CFG2_CPHA
#define SPI_NSS_SOFT   SPI_CFG2_SSM
#define SPI_NSS_HARD_INPUT   (0x00000000UL)
#define SPI_NSS_HARD_OUTPUT   SPI_CFG2_SSOE
#define SPI_NSS_PULSE_DISABLE   (0x00000000UL)
#define SPI_NSS_PULSE_ENABLE   SPI_CFG2_SSOM
#define SPI_BAUDRATEPRESCALER_2   (0x00000000UL)
#define SPI_BAUDRATEPRESCALER_4   (0x10000000UL)
#define SPI_BAUDRATEPRESCALER_8   (0x20000000UL)
#define SPI_BAUDRATEPRESCALER_16   (0x30000000UL)
#define SPI_BAUDRATEPRESCALER_32   (0x40000000UL)
#define SPI_BAUDRATEPRESCALER_64   (0x50000000UL)
#define SPI_BAUDRATEPRESCALER_128   (0x60000000UL)
#define SPI_BAUDRATEPRESCALER_256   (0x70000000UL)
#define SPI_FIRSTBIT_MSB   (0x00000000UL)
#define SPI_FIRSTBIT_LSB   SPI_CFG2_LSBFRST
#define SPI_TIMODE_DISABLE   (0x00000000UL)
#define SPI_TIMODE_ENABLE   SPI_CFG2_SP_0
#define SPI_CRCCALCULATION_DISABLE   (0x00000000UL)
#define SPI_CRCCALCULATION_ENABLE   SPI_CFG1_CRCEN
#define SPI_CRC_LENGTH_DATASIZE   (0x00000000UL)
#define SPI_CRC_LENGTH_4BIT   (0x00030000UL)
#define SPI_CRC_LENGTH_5BIT   (0x00040000UL)
#define SPI_CRC_LENGTH_6BIT   (0x00050000UL)
#define SPI_CRC_LENGTH_7BIT   (0x00060000UL)
#define SPI_CRC_LENGTH_8BIT   (0x00070000UL)
#define SPI_CRC_LENGTH_9BIT   (0x00080000UL)
#define SPI_CRC_LENGTH_10BIT   (0x00090000UL)
#define SPI_CRC_LENGTH_11BIT   (0x000A0000UL)
#define SPI_CRC_LENGTH_12BIT   (0x000B0000UL)
#define SPI_CRC_LENGTH_13BIT   (0x000C0000UL)
#define SPI_CRC_LENGTH_14BIT   (0x000D0000UL)
#define SPI_CRC_LENGTH_15BIT   (0x000E0000UL)
#define SPI_CRC_LENGTH_16BIT   (0x000F0000UL)
#define SPI_CRC_LENGTH_17BIT   (0x00100000UL)
#define SPI_CRC_LENGTH_18BIT   (0x00110000UL)
#define SPI_CRC_LENGTH_19BIT   (0x00120000UL)
#define SPI_CRC_LENGTH_20BIT   (0x00130000UL)
#define SPI_CRC_LENGTH_21BIT   (0x00140000UL)
#define SPI_CRC_LENGTH_22BIT   (0x00150000UL)
#define SPI_CRC_LENGTH_23BIT   (0x00160000UL)
#define SPI_CRC_LENGTH_24BIT   (0x00170000UL)
#define SPI_CRC_LENGTH_25BIT   (0x00180000UL)
#define SPI_CRC_LENGTH_26BIT   (0x00190000UL)
#define SPI_CRC_LENGTH_27BIT   (0x001A0000UL)
#define SPI_CRC_LENGTH_28BIT   (0x001B0000UL)
#define SPI_CRC_LENGTH_29BIT   (0x001C0000UL)
#define SPI_CRC_LENGTH_30BIT   (0x001D0000UL)
#define SPI_CRC_LENGTH_31BIT   (0x001E0000UL)
#define SPI_CRC_LENGTH_32BIT   (0x001F0000UL)
#define SPI_FIFO_THRESHOLD_01DATA   (0x00000000UL)
#define SPI_FIFO_THRESHOLD_02DATA   (0x00000020UL)
#define SPI_FIFO_THRESHOLD_03DATA   (0x00000040UL)
#define SPI_FIFO_THRESHOLD_04DATA   (0x00000060UL)
#define SPI_FIFO_THRESHOLD_05DATA   (0x00000080UL)
#define SPI_FIFO_THRESHOLD_06DATA   (0x000000A0UL)
#define SPI_FIFO_THRESHOLD_07DATA   (0x000000C0UL)
#define SPI_FIFO_THRESHOLD_08DATA   (0x000000E0UL)
#define SPI_FIFO_THRESHOLD_09DATA   (0x00000100UL)
#define SPI_FIFO_THRESHOLD_10DATA   (0x00000120UL)
#define SPI_FIFO_THRESHOLD_11DATA   (0x00000140UL)
#define SPI_FIFO_THRESHOLD_12DATA   (0x00000160UL)
#define SPI_FIFO_THRESHOLD_13DATA   (0x00000180UL)
#define SPI_FIFO_THRESHOLD_14DATA   (0x000001A0UL)
#define SPI_FIFO_THRESHOLD_15DATA   (0x000001C0UL)
#define SPI_FIFO_THRESHOLD_16DATA   (0x000001E0UL)
#define SPI_CRC_INITIALIZATION_ALL_ZERO_PATTERN   (0x00000000UL)
#define SPI_CRC_INITIALIZATION_ALL_ONE_PATTERN   (0x00000001UL)
#define SPI_NSS_POLARITY_LOW   (0x00000000UL)
#define SPI_NSS_POLARITY_HIGH   SPI_CFG2_SSIOP
#define SPI_MASTER_KEEP_IO_STATE_DISABLE   (0x00000000UL)
#define SPI_MASTER_KEEP_IO_STATE_ENABLE   SPI_CFG2_AFCNTR
#define SPI_IO_SWAP_DISABLE   (0x00000000UL)
#define SPI_IO_SWAP_ENABLE   SPI_CFG2_IOSWP
#define SPI_MASTER_SS_IDLENESS_00CYCLE   (0x00000000UL)
#define SPI_MASTER_SS_IDLENESS_01CYCLE   (0x00000001UL)
#define SPI_MASTER_SS_IDLENESS_02CYCLE   (0x00000002UL)
#define SPI_MASTER_SS_IDLENESS_03CYCLE   (0x00000003UL)
#define SPI_MASTER_SS_IDLENESS_04CYCLE   (0x00000004UL)
#define SPI_MASTER_SS_IDLENESS_05CYCLE   (0x00000005UL)
#define SPI_MASTER_SS_IDLENESS_06CYCLE   (0x00000006UL)
#define SPI_MASTER_SS_IDLENESS_07CYCLE   (0x00000007UL)
#define SPI_MASTER_SS_IDLENESS_08CYCLE   (0x00000008UL)
#define SPI_MASTER_SS_IDLENESS_09CYCLE   (0x00000009UL)
#define SPI_MASTER_SS_IDLENESS_10CYCLE   (0x0000000AUL)
#define SPI_MASTER_SS_IDLENESS_11CYCLE   (0x0000000BUL)
#define SPI_MASTER_SS_IDLENESS_12CYCLE   (0x0000000CUL)
#define SPI_MASTER_SS_IDLENESS_13CYCLE   (0x0000000DUL)
#define SPI_MASTER_SS_IDLENESS_14CYCLE   (0x0000000EUL)
#define SPI_MASTER_SS_IDLENESS_15CYCLE   (0x0000000FUL)
#define SPI_MASTER_INTERDATA_IDLENESS_00CYCLE   (0x00000000UL)
#define SPI_MASTER_INTERDATA_IDLENESS_01CYCLE   (0x00000010UL)
#define SPI_MASTER_INTERDATA_IDLENESS_02CYCLE   (0x00000020UL)
#define SPI_MASTER_INTERDATA_IDLENESS_03CYCLE   (0x00000030UL)
#define SPI_MASTER_INTERDATA_IDLENESS_04CYCLE   (0x00000040UL)
#define SPI_MASTER_INTERDATA_IDLENESS_05CYCLE   (0x00000050UL)
#define SPI_MASTER_INTERDATA_IDLENESS_06CYCLE   (0x00000060UL)
#define SPI_MASTER_INTERDATA_IDLENESS_07CYCLE   (0x00000070UL)
#define SPI_MASTER_INTERDATA_IDLENESS_08CYCLE   (0x00000080UL)
#define SPI_MASTER_INTERDATA_IDLENESS_09CYCLE   (0x00000090UL)
#define SPI_MASTER_INTERDATA_IDLENESS_10CYCLE   (0x000000A0UL)
#define SPI_MASTER_INTERDATA_IDLENESS_11CYCLE   (0x000000B0UL)
#define SPI_MASTER_INTERDATA_IDLENESS_12CYCLE   (0x000000C0UL)
#define SPI_MASTER_INTERDATA_IDLENESS_13CYCLE   (0x000000D0UL)
#define SPI_MASTER_INTERDATA_IDLENESS_14CYCLE   (0x000000E0UL)
#define SPI_MASTER_INTERDATA_IDLENESS_15CYCLE   (0x000000F0UL)
#define SPI_MASTER_RX_AUTOSUSP_DISABLE   (0x00000000UL)
#define SPI_MASTER_RX_AUTOSUSP_ENABLE   SPI_CR1_MASRX
#define SPI_UNDERRUN_BEHAV_REGISTER_PATTERN   (0x00000000UL)
#define SPI_UNDERRUN_BEHAV_LAST_RECEIVED   SPI_CFG1_UDRCFG_0
#define SPI_UNDERRUN_BEHAV_LAST_TRANSMITTED   SPI_CFG1_UDRCFG_1
#define SPI_UNDERRUN_DETECT_BEGIN_DATA_FRAME   (0x00000000UL)
#define SPI_UNDERRUN_DETECT_END_DATA_FRAME   SPI_CFG1_UDRDET_0
#define SPI_UNDERRUN_DETECT_BEGIN_ACTIVE_NSS   SPI_CFG1_UDRDET_1
#define SPI_IT_RXP   SPI_IER_RXPIE
#define SPI_IT_TXP   SPI_IER_TXPIE
#define SPI_IT_DXP   SPI_IER_DXPIE
#define SPI_IT_EOT   SPI_IER_EOTIE
#define SPI_IT_TXTF   SPI_IER_TXTFIE
#define SPI_IT_UDR   SPI_IER_UDRIE
#define SPI_IT_OVR   SPI_IER_OVRIE
#define SPI_IT_CRCERR   SPI_IER_CRCEIE
#define SPI_IT_FRE   SPI_IER_TIFREIE
#define SPI_IT_MODF   SPI_IER_MODFIE
#define SPI_IT_TSERF   SPI_IER_TSERFIE
#define SPI_IT_ERR   (SPI_IT_UDR | SPI_IT_OVR | SPI_IT_FRE | SPI_IT_MODF | SPI_IT_CRCERR)
#define SPI_FLAG_RXP   SPI_SR_RXP /* SPI status flag : Rx-Packet available flag */
#define SPI_FLAG_TXP   SPI_SR_TXP /* SPI status flag : Tx-Packet space available flag */
#define SPI_FLAG_DXP   SPI_SR_DXP /* SPI status flag : Duplex Packet flag */
#define SPI_FLAG_EOT   SPI_SR_EOT /* SPI status flag : End of transfer flag */
#define SPI_FLAG_TXTF   SPI_SR_TXTF /* SPI status flag : Transmission Transfer Filled flag */
#define SPI_FLAG_UDR   SPI_SR_UDR /* SPI Error flag : Underrun flag */
#define SPI_FLAG_OVR   SPI_SR_OVR /* SPI Error flag : Overrun flag */
#define SPI_FLAG_CRCERR   SPI_SR_CRCE /* SPI Error flag : CRC error flag */
#define SPI_FLAG_FRE   SPI_SR_TIFRE /* SPI Error flag : TI mode frame format error flag */
#define SPI_FLAG_MODF   SPI_SR_MODF /* SPI Error flag : Mode fault flag */
#define SPI_FLAG_TSERF   SPI_SR_TSERF /* SPI status flag : Additional number of data reloaded flag */
#define SPI_FLAG_SUSP   SPI_SR_SUSP /* SPI status flag : Transfer suspend complete flag */
#define SPI_FLAG_TXC   SPI_SR_TXC /* SPI status flag : TxFIFO transmission complete flag */
#define SPI_FLAG_FRLVL   SPI_SR_RXPLVL /* SPI status flag : Fifo reception level flag */
#define SPI_FLAG_RXWNE   SPI_SR_RXWNE /* SPI status flag : RxFIFO word not empty flag */
#define SPI_RX_FIFO_0PACKET   (0x00000000UL) /* 0 or multiple of 4 packets available in the RxFIFO */
#define SPI_RX_FIFO_1PACKET   (SPI_SR_RXPLVL_0)
#define SPI_RX_FIFO_2PACKET   (SPI_SR_RXPLVL_1)
#define SPI_RX_FIFO_3PACKET   (SPI_SR_RXPLVL_1 | SPI_SR_RXPLVL_0)
#define __HAL_SPI_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_SPI_STATE_RESET)
 Reset SPI handle state.
#define __HAL_SPI_ENABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->IER |= (__INTERRUPT__))
 Enable the specified SPI interrupts.
#define __HAL_SPI_DISABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->IER &= (~(__INTERRUPT__)))
 Disable the specified SPI interrupts.
#define __HAL_SPI_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
 Check whether the specified SPI interrupt source is enabled or not.
#define __HAL_SPI_GET_FLAG(__HANDLE__, __FLAG__)   ((((__HANDLE__)->Instance->SR) & (__FLAG__)) == (__FLAG__))
 Check whether the specified SPI flag is set or not.
#define __HAL_SPI_CLEAR_CRCERRFLAG(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_CRCEC)
 Clear the SPI CRCERR pending flag.
#define __HAL_SPI_CLEAR_MODFFLAG(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->IFCR , (uint32_t)(SPI_IFCR_MODFC));
 Clear the SPI MODF pending flag.
#define __HAL_SPI_CLEAR_OVRFLAG(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_OVRC)
 Clear the SPI OVR pending flag.
#define __HAL_SPI_CLEAR_FREFLAG(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_TIFREC)
 Clear the SPI FRE pending flag.
#define __HAL_SPI_CLEAR_UDRFLAG(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_UDRC)
 Clear the SPI UDR pending flag.
#define __HAL_SPI_CLEAR_EOTFLAG(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_EOTC)
 Clear the SPI EOT pending flag.
#define __HAL_SPI_CLEAR_TXTFFLAG(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_TXTFC)
#define __HAL_SPI_CLEAR_SUSPFLAG(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_SUSPC)
 Clear the SPI SUSP pending flag.
#define __HAL_SPI_CLEAR_TSERFFLAG(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_TSERFC)
 Clear the SPI TSERF pending flag.
#define __HAL_SPI_ENABLE(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->CR1 , SPI_CR1_SPE)
 Enable the SPI peripheral.
#define __HAL_SPI_DISABLE(__HANDLE__)   CLEAR_BIT((__HANDLE__)->Instance->CR1 , SPI_CR1_SPE)
 Disable the SPI peripheral.
#define SPI_1LINE_TX(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->CR1, SPI_CR1_HDDIR)
 Set the SPI transmit-only mode in 1Line configuration.
#define SPI_1LINE_RX(__HANDLE__)   CLEAR_BIT((__HANDLE__)->Instance->CR1, SPI_CR1_HDDIR)
 Set the SPI receive-only mode in 1Line configuration.
#define SPI_2LINES_TX(__HANDLE__)   MODIFY_REG((__HANDLE__)->Instance->CFG2, SPI_CFG2_COMM, SPI_CFG2_COMM_0)
 Set the SPI transmit-only mode in 2Lines configuration.
#define SPI_2LINES_RX(__HANDLE__)   MODIFY_REG((__HANDLE__)->Instance->CFG2, SPI_CFG2_COMM, SPI_CFG2_COMM_1)
 Set the SPI receive-only mode in 2Lines configuration.
#define SPI_2LINES(__HANDLE__)   MODIFY_REG((__HANDLE__)->Instance->CFG2, SPI_CFG2_COMM, 0x00000000UL)
 Set the SPI Transmit-Receive mode in 2Lines configuration.
#define IS_SPI_MODE(MODE)
#define IS_SPI_DIRECTION(MODE)
#define IS_SPI_DIRECTION_2LINES(MODE)   ((MODE) == SPI_DIRECTION_2LINES)
#define IS_SPI_DIRECTION_2LINES_OR_1LINE_2LINES_TXONLY(MODE)
#define IS_SPI_DIRECTION_2LINES_OR_1LINE_2LINES_RXONLY(MODE)
#define IS_SPI_DATASIZE(DATASIZE)
#define IS_SPI_FIFOTHRESHOLD(THRESHOLD)
#define IS_SPI_CPOL(CPOL)
#define IS_SPI_CPHA(CPHA)
#define IS_SPI_NSS(NSS)
#define IS_SPI_NSSP(NSSP)
#define IS_SPI_BAUDRATE_PRESCALER(PRESCALER)
#define IS_SPI_FIRST_BIT(BIT)
#define IS_SPI_TIMODE(MODE)
#define IS_SPI_CRC_CALCULATION(CALCULATION)
#define IS_SPI_CRC_INITIALIZATION_PATTERN(PATTERN)
#define IS_SPI_CRC_LENGTH(LENGTH)
#define IS_SPI_CRC_POLYNOMIAL(POLYNOMIAL)   ((POLYNOMIAL) > 0x0UL)
#define IS_SPI_CRC_POLYNOMIAL_SIZE(POLYNOM, LENGTH)   (((POLYNOM) >> (((LENGTH) >> SPI_CFG1_CRCSIZE_Pos) + 1UL)) == 0UL)
#define IS_SPI_UNDERRUN_DETECTION(MODE)
#define IS_SPI_UNDERRUN_BEHAVIOUR(MODE)
#define IS_SPI_MASTER_RX_AUTOSUSP(MODE)
typedef struct __SPI_HandleTypeDef SPI_HandleTypeDef
enum  HAL_SPI_StateTypeDef {
  HAL_SPI_STATE_RESET = 0x00UL , HAL_SPI_STATE_READY = 0x01UL , HAL_SPI_STATE_BUSY = 0x02UL , HAL_SPI_STATE_BUSY_TX = 0x03UL ,
  HAL_SPI_STATE_BUSY_RX = 0x04UL , HAL_SPI_STATE_BUSY_TX_RX = 0x05UL , HAL_SPI_STATE_ERROR = 0x06UL , HAL_SPI_STATE_ABORT = 0x07UL
 HAL SPI State structure definition. More...
HAL_StatusTypeDef HAL_SPI_Init (SPI_HandleTypeDef *hspi)
HAL_StatusTypeDef HAL_SPI_DeInit (SPI_HandleTypeDef *hspi)
void HAL_SPI_MspInit (SPI_HandleTypeDef *hspi)
void HAL_SPI_MspDeInit (SPI_HandleTypeDef *hspi)
HAL_StatusTypeDef HAL_SPI_Transmit (SPI_HandleTypeDef *hspi, const uint8_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_SPI_Receive (SPI_HandleTypeDef *hspi, uint8_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_SPI_TransmitReceive (SPI_HandleTypeDef *hspi, const uint8_t *pTxData, uint8_t *pRxData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_SPI_Transmit_IT (SPI_HandleTypeDef *hspi, const uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_SPI_Receive_IT (SPI_HandleTypeDef *hspi, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_SPI_TransmitReceive_IT (SPI_HandleTypeDef *hspi, const uint8_t *pTxData, uint8_t *pRxData, uint16_t Size)
HAL_StatusTypeDef HAL_SPI_Transmit_DMA (SPI_HandleTypeDef *hspi, const uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_SPI_Receive_DMA (SPI_HandleTypeDef *hspi, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_SPI_TransmitReceive_DMA (SPI_HandleTypeDef *hspi, const uint8_t *pTxData, uint8_t *pRxData, uint16_t Size)
HAL_StatusTypeDef HAL_SPI_DMAPause (SPI_HandleTypeDef *hspi)
HAL_StatusTypeDef HAL_SPI_DMAResume (SPI_HandleTypeDef *hspi)
HAL_StatusTypeDef HAL_SPI_DMAStop (SPI_HandleTypeDef *hspi)
HAL_StatusTypeDef HAL_SPI_Abort (SPI_HandleTypeDef *hspi)
HAL_StatusTypeDef HAL_SPI_Abort_IT (SPI_HandleTypeDef *hspi)
void HAL_SPI_IRQHandler (SPI_HandleTypeDef *hspi)
void HAL_SPI_TxCpltCallback (SPI_HandleTypeDef *hspi)
void HAL_SPI_RxCpltCallback (SPI_HandleTypeDef *hspi)
void HAL_SPI_TxRxCpltCallback (SPI_HandleTypeDef *hspi)
void HAL_SPI_TxHalfCpltCallback (SPI_HandleTypeDef *hspi)
void HAL_SPI_RxHalfCpltCallback (SPI_HandleTypeDef *hspi)
void HAL_SPI_TxRxHalfCpltCallback (SPI_HandleTypeDef *hspi)
void HAL_SPI_ErrorCallback (SPI_HandleTypeDef *hspi)
void HAL_SPI_AbortCpltCallback (SPI_HandleTypeDef *hspi)
void HAL_SPI_SuspendCallback (SPI_HandleTypeDef *hspi)
HAL_SPI_StateTypeDef HAL_SPI_GetState (const SPI_HandleTypeDef *hspi)
uint32_t HAL_SPI_GetError (const SPI_HandleTypeDef *hspi)
Author
MCD Application Team
Attention
