RTEMS 6.1
Data Structures | Macros | Enumerations | Functions
stm32h7xx_hal_sdram.h File Reference
Header file of SDRAM HAL module. More...
#include "stm32h7xx_ll_fmc.h"
struct  SDRAM_HandleTypeDef
 SDRAM handle Structure definition. More...
#define __HAL_SDRAM_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_SDRAM_STATE_RESET)
 Reset SDRAM handle state.
enum  HAL_SDRAM_StateTypeDef {
  HAL_SDRAM_STATE_RESET = 0x00U , HAL_SDRAM_STATE_READY = 0x01U , HAL_SDRAM_STATE_BUSY = 0x02U , HAL_SDRAM_STATE_ERROR = 0x03U ,
  HAL_SDRAM_STATE_WRITE_PROTECTED = 0x04U , HAL_SDRAM_STATE_PRECHARGED = 0x05U
 HAL SDRAM State structure definition. More...
HAL_StatusTypeDef HAL_SDRAM_Init (SDRAM_HandleTypeDef *hsdram, FMC_SDRAM_TimingTypeDef *Timing)
HAL_StatusTypeDef HAL_SDRAM_DeInit (SDRAM_HandleTypeDef *hsdram)
void HAL_SDRAM_MspInit (SDRAM_HandleTypeDef *hsdram)
void HAL_SDRAM_MspDeInit (SDRAM_HandleTypeDef *hsdram)
void HAL_SDRAM_IRQHandler (SDRAM_HandleTypeDef *hsdram)
void HAL_SDRAM_RefreshErrorCallback (SDRAM_HandleTypeDef *hsdram)
void HAL_SDRAM_DMA_XferCpltCallback (MDMA_HandleTypeDef *hmdma)
void HAL_SDRAM_DMA_XferErrorCallback (MDMA_HandleTypeDef *hmdma)
HAL_StatusTypeDef HAL_SDRAM_Read_8b (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint8_t *pDstBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SDRAM_Write_8b (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint8_t *pSrcBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SDRAM_Read_16b (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint16_t *pDstBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SDRAM_Write_16b (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint16_t *pSrcBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SDRAM_Read_32b (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint32_t *pDstBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SDRAM_Write_32b (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint32_t *pSrcBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SDRAM_Read_DMA (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint32_t *pDstBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SDRAM_Write_DMA (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint32_t *pSrcBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SDRAM_WriteProtection_Enable (SDRAM_HandleTypeDef *hsdram)
HAL_StatusTypeDef HAL_SDRAM_WriteProtection_Disable (SDRAM_HandleTypeDef *hsdram)
HAL_StatusTypeDef HAL_SDRAM_SendCommand (SDRAM_HandleTypeDef *hsdram, FMC_SDRAM_CommandTypeDef *Command, uint32_t Timeout)
HAL_StatusTypeDef HAL_SDRAM_ProgramRefreshRate (SDRAM_HandleTypeDef *hsdram, uint32_t RefreshRate)
HAL_StatusTypeDef HAL_SDRAM_SetAutoRefreshNumber (SDRAM_HandleTypeDef *hsdram, uint32_t AutoRefreshNumber)
uint32_t HAL_SDRAM_GetModeStatus (SDRAM_HandleTypeDef *hsdram)
HAL_SDRAM_StateTypeDef HAL_SDRAM_GetState (SDRAM_HandleTypeDef *hsdram)
Author
MCD Application Team
Attention
