RTEMS 6.1
statusimpl.h
2
12/* COPYRIGHT (c) 1989-2008.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_RTEMS_STATUSIMPL_H
38#define _RTEMS_RTEMS_STATUSIMPL_H
39
40#include <rtems/rtems/status.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif
46
66static inline rtems_status_code _Status_Get(
67 Status_Control status
68)
69{
70 return (rtems_status_code) STATUS_GET_CLASSIC( status );
71}
72
73static inline rtems_status_code _Status_Get_after_wait(
74 const Thread_Control *executing
75)
76{
77 return _Status_Get( _Thread_Wait_get_status( executing ) );
78}
79
82#ifdef __cplusplus
83}
84#endif
85
86#endif
87/* end of include file */
rtems_status_code
Definition: status.h:85
#define STATUS_GET_CLASSIC(status)
Macro to get the Classic API status code.
Definition: status.h:97
Status_Control
Status codes.
Definition: status.h:111
This header file provides the status codes of Classic API directives and support functions.
Definition: thread.h:837
This header file provides interfaces of the Thread Handler which are only used by the implementation.
