RTEMS 6.1
40#ifndef __ALTERA_SOCAL_H__
41#define __ALTERA_SOCAL_H__
68#define ALT_CAST(type, ptr) ptr
78#define ALT_CAST(type, ptr) ((type) (ptr))
103#define alt_write_byte(dest, src) (*ALT_CAST(volatile uint8_t *, (dest)) = (src))
109#define alt_read_byte(src) (*ALT_CAST(volatile uint8_t *, (src)))
115#define alt_write_hword(dest, src) (*ALT_CAST(volatile uint16_t *, (dest)) = (src))
121#define alt_read_hword(src) (*ALT_CAST(volatile uint16_t *, (src)))
127#define alt_write_word(dest, src) (*ALT_CAST(volatile uint32_t *, (dest)) = (src))
133#define alt_read_word(src) (*ALT_CAST(volatile uint32_t *, (src)))
139#define alt_write_dword(dest, src) (*ALT_CAST(volatile uint64_t *, (dest)) = (src))
145#define alt_read_dword(src) (*ALT_CAST(volatile uint64_t *, (src)))
162#define alt_setbits_byte(dest, bits) (alt_write_byte(dest, alt_read_byte(dest) | (bits)))
168#define alt_clrbits_byte(dest, bits) (alt_write_byte(dest, alt_read_byte(dest) & ~(bits)))
174#define alt_xorbits_byte(dest, bits) (alt_write_byte(dest, alt_read_byte(dest) ^ (bits)))
181#define alt_replbits_byte(dest, msk, src) (alt_write_byte(dest,(alt_read_byte(dest) & ~(msk)) | ((src) & (msk))))
187#define alt_setbits_hword(dest, bits) (alt_write_hword(dest, alt_read_hword(dest) | (bits)))
193#define alt_clrbits_hword(dest, bits) (alt_write_hword(dest, alt_read_hword(dest) & ~(bits)))
199#define alt_xorbits_hword(dest, bits) (alt_write_hword(dest, alt_read_hword(dest) ^ (bits)))
206#define alt_replbits_hword(dest, msk, src) (alt_write_hword(dest,(alt_read_hword(dest) & ~(msk)) | ((src) & (msk))))
212#define alt_setbits_word(dest, bits) (alt_write_word(dest, alt_read_word(dest) | (bits)))
218#define alt_clrbits_word(dest, bits) (alt_write_word(dest, alt_read_word(dest) & ~(bits)))
224#define alt_xorbits_word(dest, bits) (alt_write_word(dest, alt_read_word(dest) ^ (bits)))
231#define alt_replbits_word(dest, msk, src) (alt_write_word(dest,(alt_read_word(dest) & ~(msk)) | ((src) & (msk))))
237#define alt_setbits_dword(dest, bits) (alt_write_dword(dest, alt_read_dword(dest) | (bits)))
243#define alt_clrbits_dword(dest, bits) (alt_write_dword(dest, alt_read_dword(dest) & ~(bits)))
249#define alt_xorbits_dword(dest, bits) (alt_write_dword(dest, alt_read_dword(dest) ^ (bits)))
256#define alt_replbits_dword(dest, msk, src) (alt_write_dword(dest,(alt_read_dword(dest) & ~(msk)) | ((src) & (msk))))
