RTEMS 6.1
Modules | Macros
 SoCAL Memory Bit Set/Clr/XOR/Replace Utilities
 SoCAL Memory Read/Write Utilities
#define ALT_CAST(type, ptr)   ((type) (ptr))
This file contains utility and support functions for the Altera SoCAL.
◆ ALT_CAST
#define ALT_CAST (   type,
  ptr
)    ((type) (ptr))
Cast the pointer to specified pointer type.
Note: This macro expands to ptr value only for assembler language targets.
Parameters
typeThe pointer type to cast to
ptrThe pointer to apply the type cast to
