RTEMS 6.1
sim.h
1
28/*
29 * This file was created by John S. Gwynne to support Motorola's 68332 MCU.
30 *
31 * Redistribution and use in source and binary forms are permitted
32 * provided that the following conditions are met:
33 * 1. Redistribution of source code and documentation must retain
34 * the above authorship, this list of conditions and the
35 * following disclaimer.
36 * 2. The name of the author may not be used to endorse or promote
37 * products derived from this software without specific prior
38 * written permission.
39 *
40 * This software is provided "AS IS" without warranty of any kind,
41 * either expressed or implied, including, but not limited to, the
42 * implied warranties of merchantability, title and fitness for a
43 * particular purpose.
44 *
45 *------------------------------------------------------------------
46 */
47
48#ifndef _RTEMS_M68K_SIM_H
49#define _RTEMS_M68K_SIM_H
50
51
52/* SAM-- shift and mask */
53#undef SAM
54#define SAM(a,b,c) ((a << b) & c)
55
56/*
57 * These macros make this file usable from assembly.
58 */
59
60#ifdef ASM
61#define SIM_VOLATILE_USHORT_POINTER
62#define SIM_VOLATILE_UCHAR_POINTER
63#else
64#define SIM_VOLATILE_USHORT_POINTER (volatile unsigned short int * const)
65#define SIM_VOLATILE_UCHAR_POINTER (volatile unsigned char * const)
66#endif
67
68/* SIM_CRB (SIM Control Register Block) base address of the SIM
69 control registers */
70#ifndef SIM_CRB
71#if SIM_MM == 0
72#define SIM_CRB 0x7ffa00
73#else /* SIM_MM */
74#undef SIM_MM
75#define SIM_MM 1
76#define SIM_CRB 0xfffa00
77#endif /* SIM_MM */
78#endif /* SIM_CRB */
79
80
81#define SIMCR SIM_VOLATILE_USHORT_POINTER(0x00 + SIM_CRB)
82 /* Module Configuration Register */
83#define EXOFF 0x8000 /* External Clock Off */
84#define FRZSW 0x4000 /* Freeze Software Enable */
85#define FRZBM 0x2000 /* Freeze Bus Monitor Enable */
86#define SLVEN 0x0800 /* Factory Test Model Enabled (ro)*/
87#define SHEN 0x0300 /* Show Cycle Enable */
88#define SUPV 0x0080 /* Supervisor/Unrestricted Data Space */
89#define MM 0x0040 /* Module Mapping */
90#define IARB 0x000f /* Interrupt Arbitration Field */
91
92
93
94#define SIMTR SIM_VOLATILE_USHORT_POINTER(0x02 + SIM_CRB)
95 /* SIM Test Register */
96/* Used only for factor testing */
97
98
99
100#define SYNCR SIM_VOLATILE_USHORT_POINTER(0x04 + SIM_CRB)
101 /* Clock Synthesizer Control Register */
102#define VCO 0x8000 /* Frequency Control (VCO) */
103#define PRESCALE 0x4000 /* Frequency Control Bit (Prescale) */
104#define COUNTER 0x3f00 /* Frequency Control Counter */
105#define EDIV 0x0080 /* ECLK Divide Rate */
106#define SLIMP 0x0010 /* Limp Mode Status */
107#define SLOCK 0x0008 /* Synthesizer Lock */
108#define RSTEN 0x0004 /* Reset Enable */
109#define STSIM 0x0002 /* Stop Mode SIM Clock */
110#define STEXT 0x0001 /* Stop Mode External Clock */
111
112
113
114#define RSR SIM_VOLATILE_UCHAR_POINTER(0x07 + SIM_CRB)
115 /* Reset Status Register */
116#define EXT 0x0080 /* External Reset */
117#define POW 0x0040 /* Power-On Reset */
118#define SW 0x0020 /* Software Watchdog Reset */
119#define DBF 0x0010 /* Double Bus Fault Reset */
120#define LOC 0x0004 /* Loss of Clock Reset */
121#define SYS 0x0002 /* System Reset */
122#define TST 0x0001 /* Test Submodule Reset */
123
124
125
126#define SIMTRE SIM_VOLATILE_USHORT_POINTER(0x08 + SIM_CRB)
127 /* System Integration Test Register */
128/* Used only for factor testing */
129
130
131
132#define PORTE0 SIM_VOLATILE_UCHAR_POINTER(0x11 + SIM_CRB)
133#define PORTE1 SIM_VOLATILE_UCHAR_POINTER(0x13 + SIM_CRB)
134 /* Port E Data Register */
135#define DDRE SIM_VOLATILE_UCHAR_POINTER(0x15 + SIM_CRB)
136 /* Port E Data Direction Register */
137#define PEPAR SIM_VOLATILE_UCHAR_POINTER(0x17 + SIM_CRB)
138 /* Port E Pin Assignment Register */
139/* Any bit cleared (zero) defines the corresponding pin to be an I/O
140 pin. Any bit set defines the corresponding pin to be a bus control
141 signal. */
142
143
144
145#define PORTF0 SIM_VOLATILE_UCHAR_POINTER(0x19 + SIM_CRB)
146#define PORTF1 SIM_VOLATILE_UCHAR_POINTER(0x1b + SIM_CRB)
147 /* Port F Data Register */
148#define DDRF SIM_VOLATILE_UCHAR_POINTER(0x1d + SIM_CRB)
149 /* Port E Data Direction Register */
150#define PFPAR SIM_VOLATILE_UCHAR_POINTER(0x1f + SIM_CRB)
151/* Any bit cleared (zero) defines the corresponding pin to be an I/O
152 pin. Any bit set defines the corresponding pin to be a bus control
153 signal. */
154
155
156
157#define SYPCR SIM_VOLATILE_UCHAR_POINTER(0x21 + SIM_CRB)
158/* !!! can write to only once after reset !!! */
159 /* System Protection Control Register */
160#define SWE 0x80 /* Software Watch Enable */
161#define SWP 0x40 /* Software Watchdog Prescale */
162#define SWT 0x30 /* Software Watchdog Timing */
163#define HME 0x08 /* Halt Monitor Enable */
164#define BME 0x04 /* Bus Monitor External Enable */
165#define BMT 0x03 /* Bus Monitor Timing */
166
167
168
169#define PICR SIM_VOLATILE_USHORT_POINTER(0x22 + SIM_CRB)
170 /* Periodic Interrupt Control Reg. */
171#define PIRQL 0x0700 /* Periodic Interrupt Request Level */
172#define PIV 0x00ff /* Periodic Interrupt Level */
173
174
175
176#define PITR SIM_VOLATILE_USHORT_POINTER(0x24 + SIM_CRB)
177 /* Periodic Interrupt Timer Register */
178#define PTP 0x0100 /* Periodic Timer Prescaler Control */
179#define PITM 0x00ff /* Periodic Interrupt Timing Modulus */
180
181
182
183#define SWSR SIM_VOLATILE_UCHAR_POINTER(0x27 + SIM_CRB)
184 /* Software Service Register */
185/* write 0x55 then 0xaa to service the software watchdog */
186
187
188
189#define TSTMSRA SIM_VOLATILE_USHORT_POINTER(0x30 + SIM_CRB)
190 /* Test Module Master Shift A */
191#define TSTMSRB SIM_VOLATILE_USHORT_POINTER(0x32 + SIM_CRB)
192 /* Test Module Master Shift A */
193#define TSTSC SIM_VOLATILE_USHORT_POINTER(0x34 + SIM_CRB)
194 /* Test Module Shift Count */
195#define TSTRC SIM_VOLATILE_USHORT_POINTER(0x36 + SIM_CRB)
196 /* Test Module Repetition Counter */
197#define CREG SIM_VOLATILE_USHORT_POINTER(0x38 + SIM_CRB)
198 /* Test Module Control */
199#define DREG SIM_VOLATILE_USHORT_POINTER(0x3a + SIM_CRB)
200 /* Test Module Distributed */
201/* Used only for factor testing */
202
203
204
205#define PORTC SIM_VOLATILE_UCHAR_POINTER(0x41 + SIM_CRB)
206 /* Port C Data */
207
208
209
210#define CSPAR0 SIM_VOLATILE_USHORT_POINTER(0x44 + SIM_CRB)
211 /* Chip Select Pin Assignment
212 Resgister 0 */
213/* CSPAR0 contains seven two-bit fields that determine the functions
214 of corresponding chip-select pins. CSPAR0[15:14] are not
215 used. These bits always read zero; write have no effect. CSPAR0 bit
216 1 always reads one; writes to CSPAR0 bit 1 have no effect. */
217#define CSPAR1 SIM_VOLATILE_USHORT_POINTER(0x46 + SIM_CRB)
218 /* Chip Select Pin Assignment
219 Register 1 */
220/* CSPAR1 contains five two-bit fields that determine the finctions of
221 corresponding chip-select pins. CSPAR1[15:10] are not used. These
222 bits always read zero; writes have no effect. */
223/*
224 *
225 * Bit Field | Description
226 * ------------+---------------
227 * 00 | Discrete Output
228 * 01 | Alternate Function
229 * 10 | Chip Select (8-bit port)
230 * 11 | Chip Select (16-bit port)
231 */
232#define DisOut 0x0
233#define AltFun 0x1
234#define CS8bit 0x2
235#define CS16bit 0x3
236/*
237 *
238 * CSPARx Field |Chip Select Signal | Alternate Signal | Discrete Output
239 *-----------------+--------------------+--------------------+---------------*/
240#define CS_5 12 /* !CS5 | FC2 | PC2 */
241#define CS_4 10 /* !CS4 | FC1 | PC1 */
242#define CS_3 8 /* !CS3 | FC0 | PC0 */
243#define CS_2 6 /* !CS2 | !BGACK | */
244#define CS_1 4 /* !CS1 | !BG | */
245#define CS_0 2 /* !CS0 | !BR | */
246#define CSBOOT 0 /* !CSBOOT | | */
247/* | | | */
248#define CS_10 8 /* !CS10 | ADDR23 | ECLK */
249#define CS_9 6 /* !CS9 | ADDR22 | PC6 */
250#define CS_8 4 /* !CS8 | ADDR21 | PC5 */
251#define CS_7 2 /* !CS7 | ADDR20 | PC4 */
252#define CS_6 0 /* !CS6 | ADDR19 | PC3 */
253
254#define BS_2K 0x0
255#define BS_8K 0x1
256#define BS_16K 0x2
257#define BS_64K 0x3
258#define BS_128K 0x4
259#define BS_256K 0x5
260#define BS_512K 0x6
261#define BS_1M 0x7
262
263#define CSBARBT SIM_VOLATILE_USHORT_POINTER(0x48 + SIM_CRB)
264#define CSBAR0 SIM_VOLATILE_USHORT_POINTER(0x4c + SIM_CRB)
265#define CSBAR1 SIM_VOLATILE_USHORT_POINTER(0x50 + SIM_CRB)
266#define CSBAR2 SIM_VOLATILE_USHORT_POINTER(0x54 + SIM_CRB)
267#define CSBAR3 SIM_VOLATILE_USHORT_POINTER(0x58 + SIM_CRB)
268#define CSBAR4 SIM_VOLATILE_USHORT_POINTER(0x5c + SIM_CRB)
269#define CSBAR5 SIM_VOLATILE_USHORT_POINTER(0x60 + SIM_CRB)
270#define CSBAR6 SIM_VOLATILE_USHORT_POINTER(0x64 + SIM_CRB)
271#define CSBAR7 SIM_VOLATILE_USHORT_POINTER(0x68 + SIM_CRB)
272#define CSBAR8 SIM_VOLATILE_USHORT_POINTER(0x6c + SIM_CRB)
273#define CSBAR9 SIM_VOLATILE_USHORT_POINTER(0x70 + SIM_CRB)
274#define CSBAR10 SIM_VOLATILE_USHORT_POINTER(0x74 + SIM_CRB)
275
276#define MODE 0x8000
277#define Disable 0
278#define LowerByte 0x2000
279#define UpperByte 0x4000
280#define BothBytes 0x6000
281#define ReadOnly 0x0800
282#define WriteOnly 0x1000
283#define ReadWrite 0x1800
284#define SyncAS 0x0
285#define SyncDS 0x0400
286
287#define WaitStates_0 (0x0 << 6)
288#define WaitStates_1 (0x1 << 6)
289#define WaitStates_2 (0x2 << 6)
290#define WaitStates_3 (0x3 << 6)
291#define WaitStates_4 (0x4 << 6)
292#define WaitStates_5 (0x5 << 6)
293#define WaitStates_6 (0x6 << 6)
294#define WaitStates_7 (0x7 << 6)
295#define WaitStates_8 (0x8 << 6)
296#define WaitStates_9 (0x9 << 6)
297#define WaitStates_10 (0xa << 6)
298#define WaitStates_11 (0xb << 6)
299#define WaitStates_12 (0xc << 6)
300#define WaitStates_13 (0xd << 6)
301#define FastTerm (0xe << 6)
302#define External (0xf << 6)
303
304#define CPUSpace (0x0 << 4)
305#define UserSpace (0x1 << 4)
306#define SupSpace (0x2 << 4)
307#define UserSupSpace (0x3 << 4)
308
309#define IPLevel_any 0x0
310#define IPLevel_1 0x2
311#define IPLevel_2 0x4
312#define IPLevel_3 0x6
313#define IPLevel_4 0x8
314#define IPLevel_5 0xa
315#define IPLevel_6 0xc
316#define IPLevel_7 0xe
317
318#define AVEC 1
319
320#define CSORBT SIM_VOLATILE_USHORT_POINTER(0x4a + SIM_CRB)
321#define CSOR0 SIM_VOLATILE_USHORT_POINTER(0x4e + SIM_CRB)
322#define CSOR1 SIM_VOLATILE_USHORT_POINTER(0x52 + SIM_CRB)
323#define CSOR2 SIM_VOLATILE_USHORT_POINTER(0x56 + SIM_CRB)
324#define CSOR3 SIM_VOLATILE_USHORT_POINTER(0x5a + SIM_CRB)
325#define CSOR4 SIM_VOLATILE_USHORT_POINTER(0x5e + SIM_CRB)
326#define CSOR5 SIM_VOLATILE_USHORT_POINTER(0x62 + SIM_CRB)
327#define CSOR6 SIM_VOLATILE_USHORT_POINTER(0x66 + SIM_CRB)
328#define CSOR7 SIM_VOLATILE_USHORT_POINTER(0x6a + SIM_CRB)
329#define CSOR8 SIM_VOLATILE_USHORT_POINTER(0x6e + SIM_CRB)
330#define CSOR9 SIM_VOLATILE_USHORT_POINTER(0x72 + SIM_CRB)
331#define CSOR10 SIM_VOLATILE_USHORT_POINTER(0x76 + SIM_CRB)
332
333#endif /* _RTEMS_M68K_SIM_H */
