#define | SAM(a, b, c) ((a << b) & c) |
#define | SIM_VOLATILE_USHORT_POINTER (volatile unsigned short int * const) |
#define | SIM_VOLATILE_UCHAR_POINTER (volatile unsigned char * const) |
#define | SIM_CRB 0x7ffa00 |
#define | SIMCR SIM_VOLATILE_USHORT_POINTER(0x00 + SIM_CRB) |
#define | EXOFF 0x8000 /* External Clock Off */ |
#define | FRZSW 0x4000 /* Freeze Software Enable */ |
#define | FRZBM 0x2000 /* Freeze Bus Monitor Enable */ |
#define | SLVEN 0x0800 /* Factory Test Model Enabled (ro)*/ |
#define | SHEN 0x0300 /* Show Cycle Enable */ |
#define | SUPV 0x0080 /* Supervisor/Unrestricted Data Space */ |
#define | MM 0x0040 /* Module Mapping */ |
#define | IARB 0x000f /* Interrupt Arbitration Field */ |
#define | SIMTR SIM_VOLATILE_USHORT_POINTER(0x02 + SIM_CRB) |
#define | SYNCR SIM_VOLATILE_USHORT_POINTER(0x04 + SIM_CRB) |
#define | VCO 0x8000 /* Frequency Control (VCO) */ |
#define | PRESCALE 0x4000 /* Frequency Control Bit (Prescale) */ |
#define | COUNTER 0x3f00 /* Frequency Control Counter */ |
#define | EDIV 0x0080 /* ECLK Divide Rate */ |
#define | SLIMP 0x0010 /* Limp Mode Status */ |
#define | SLOCK 0x0008 /* Synthesizer Lock */ |
#define | RSTEN 0x0004 /* Reset Enable */ |
#define | STSIM 0x0002 /* Stop Mode SIM Clock */ |
#define | STEXT 0x0001 /* Stop Mode External Clock */ |
#define | RSR SIM_VOLATILE_UCHAR_POINTER(0x07 + SIM_CRB) |
#define | EXT 0x0080 /* External Reset */ |
#define | POW 0x0040 /* Power-On Reset */ |
#define | SW 0x0020 /* Software Watchdog Reset */ |
#define | DBF 0x0010 /* Double Bus Fault Reset */ |
#define | LOC 0x0004 /* Loss of Clock Reset */ |
#define | SYS 0x0002 /* System Reset */ |
#define | TST 0x0001 /* Test Submodule Reset */ |
#define | SIMTRE SIM_VOLATILE_USHORT_POINTER(0x08 + SIM_CRB) |
#define | PORTE0 SIM_VOLATILE_UCHAR_POINTER(0x11 + SIM_CRB) |
#define | PORTE1 SIM_VOLATILE_UCHAR_POINTER(0x13 + SIM_CRB) |
#define | DDRE SIM_VOLATILE_UCHAR_POINTER(0x15 + SIM_CRB) |
#define | PEPAR SIM_VOLATILE_UCHAR_POINTER(0x17 + SIM_CRB) |
#define | PORTF0 SIM_VOLATILE_UCHAR_POINTER(0x19 + SIM_CRB) |
#define | PORTF1 SIM_VOLATILE_UCHAR_POINTER(0x1b + SIM_CRB) |
#define | DDRF SIM_VOLATILE_UCHAR_POINTER(0x1d + SIM_CRB) |
#define | PFPAR SIM_VOLATILE_UCHAR_POINTER(0x1f + SIM_CRB) |
#define | SYPCR SIM_VOLATILE_UCHAR_POINTER(0x21 + SIM_CRB) |
#define | SWE 0x80 /* Software Watch Enable */ |
#define | SWP 0x40 /* Software Watchdog Prescale */ |
#define | SWT 0x30 /* Software Watchdog Timing */ |
#define | HME 0x08 /* Halt Monitor Enable */ |
#define | BME 0x04 /* Bus Monitor External Enable */ |
#define | BMT 0x03 /* Bus Monitor Timing */ |
#define | PICR SIM_VOLATILE_USHORT_POINTER(0x22 + SIM_CRB) |
#define | PIRQL 0x0700 /* Periodic Interrupt Request Level */ |
#define | PIV 0x00ff /* Periodic Interrupt Level */ |
#define | PITR SIM_VOLATILE_USHORT_POINTER(0x24 + SIM_CRB) |
#define | PTP 0x0100 /* Periodic Timer Prescaler Control */ |
#define | PITM 0x00ff /* Periodic Interrupt Timing Modulus */ |
#define | SWSR SIM_VOLATILE_UCHAR_POINTER(0x27 + SIM_CRB) |
#define | TSTMSRA SIM_VOLATILE_USHORT_POINTER(0x30 + SIM_CRB) |
#define | TSTMSRB SIM_VOLATILE_USHORT_POINTER(0x32 + SIM_CRB) |
#define | TSTSC SIM_VOLATILE_USHORT_POINTER(0x34 + SIM_CRB) |
#define | TSTRC SIM_VOLATILE_USHORT_POINTER(0x36 + SIM_CRB) |
#define | CREG SIM_VOLATILE_USHORT_POINTER(0x38 + SIM_CRB) |
#define | DREG SIM_VOLATILE_USHORT_POINTER(0x3a + SIM_CRB) |
#define | PORTC SIM_VOLATILE_UCHAR_POINTER(0x41 + SIM_CRB) |
#define | CSPAR0 SIM_VOLATILE_USHORT_POINTER(0x44 + SIM_CRB) |
#define | CSPAR1 SIM_VOLATILE_USHORT_POINTER(0x46 + SIM_CRB) |
#define | DisOut 0x0 |
#define | AltFun 0x1 |
#define | CS8bit 0x2 |
#define | CS16bit 0x3 |
#define | CS_5 12 /* !CS5 | FC2 | PC2 */ |
#define | CS_4 10 /* !CS4 | FC1 | PC1 */ |
#define | CS_3 8 /* !CS3 | FC0 | PC0 */ |
#define | CS_2 6 /* !CS2 | !BGACK | */ |
#define | CS_1 4 /* !CS1 | !BG | */ |
#define | CS_0 2 /* !CS0 | !BR | */ |
#define | CSBOOT 0 /* !CSBOOT | | */ |
#define | CS_10 8 /* !CS10 | ADDR23 | ECLK */ |
#define | CS_9 6 /* !CS9 | ADDR22 | PC6 */ |
#define | CS_8 4 /* !CS8 | ADDR21 | PC5 */ |
#define | CS_7 2 /* !CS7 | ADDR20 | PC4 */ |
#define | CS_6 0 /* !CS6 | ADDR19 | PC3 */ |
#define | BS_2K 0x0 |
#define | BS_8K 0x1 |
#define | BS_16K 0x2 |
#define | BS_64K 0x3 |
#define | BS_128K 0x4 |
#define | BS_256K 0x5 |
#define | BS_512K 0x6 |
#define | BS_1M 0x7 |
#define | CSBARBT SIM_VOLATILE_USHORT_POINTER(0x48 + SIM_CRB) |
#define | CSBAR0 SIM_VOLATILE_USHORT_POINTER(0x4c + SIM_CRB) |
#define | CSBAR1 SIM_VOLATILE_USHORT_POINTER(0x50 + SIM_CRB) |
#define | CSBAR2 SIM_VOLATILE_USHORT_POINTER(0x54 + SIM_CRB) |
#define | CSBAR3 SIM_VOLATILE_USHORT_POINTER(0x58 + SIM_CRB) |
#define | CSBAR4 SIM_VOLATILE_USHORT_POINTER(0x5c + SIM_CRB) |
#define | CSBAR5 SIM_VOLATILE_USHORT_POINTER(0x60 + SIM_CRB) |
#define | CSBAR6 SIM_VOLATILE_USHORT_POINTER(0x64 + SIM_CRB) |
#define | CSBAR7 SIM_VOLATILE_USHORT_POINTER(0x68 + SIM_CRB) |
#define | CSBAR8 SIM_VOLATILE_USHORT_POINTER(0x6c + SIM_CRB) |
#define | CSBAR9 SIM_VOLATILE_USHORT_POINTER(0x70 + SIM_CRB) |
#define | CSBAR10 SIM_VOLATILE_USHORT_POINTER(0x74 + SIM_CRB) |
#define | MODE 0x8000 |
#define | Disable 0 |
#define | LowerByte 0x2000 |
#define | UpperByte 0x4000 |
#define | BothBytes 0x6000 |
#define | ReadOnly 0x0800 |
#define | WriteOnly 0x1000 |
#define | ReadWrite 0x1800 |
#define | SyncAS 0x0 |
#define | SyncDS 0x0400 |
#define | WaitStates_0 (0x0 << 6) |
#define | WaitStates_1 (0x1 << 6) |
#define | WaitStates_2 (0x2 << 6) |
#define | WaitStates_3 (0x3 << 6) |
#define | WaitStates_4 (0x4 << 6) |
#define | WaitStates_5 (0x5 << 6) |
#define | WaitStates_6 (0x6 << 6) |
#define | WaitStates_7 (0x7 << 6) |
#define | WaitStates_8 (0x8 << 6) |
#define | WaitStates_9 (0x9 << 6) |
#define | WaitStates_10 (0xa << 6) |
#define | WaitStates_11 (0xb << 6) |
#define | WaitStates_12 (0xc << 6) |
#define | WaitStates_13 (0xd << 6) |
#define | FastTerm (0xe << 6) |
#define | External (0xf << 6) |
#define | CPUSpace (0x0 << 4) |
#define | UserSpace (0x1 << 4) |
#define | SupSpace (0x2 << 4) |
#define | UserSupSpace (0x3 << 4) |
#define | IPLevel_any 0x0 |
#define | IPLevel_1 0x2 |
#define | IPLevel_2 0x4 |
#define | IPLevel_3 0x6 |
#define | IPLevel_4 0x8 |
#define | IPLevel_5 0xa |
#define | IPLevel_6 0xc |
#define | IPLevel_7 0xe |
#define | AVEC 1 |
#define | CSORBT SIM_VOLATILE_USHORT_POINTER(0x4a + SIM_CRB) |
#define | CSOR0 SIM_VOLATILE_USHORT_POINTER(0x4e + SIM_CRB) |
#define | CSOR1 SIM_VOLATILE_USHORT_POINTER(0x52 + SIM_CRB) |
#define | CSOR2 SIM_VOLATILE_USHORT_POINTER(0x56 + SIM_CRB) |
#define | CSOR3 SIM_VOLATILE_USHORT_POINTER(0x5a + SIM_CRB) |
#define | CSOR4 SIM_VOLATILE_USHORT_POINTER(0x5e + SIM_CRB) |
#define | CSOR5 SIM_VOLATILE_USHORT_POINTER(0x62 + SIM_CRB) |
#define | CSOR6 SIM_VOLATILE_USHORT_POINTER(0x66 + SIM_CRB) |
#define | CSOR7 SIM_VOLATILE_USHORT_POINTER(0x6a + SIM_CRB) |
#define | CSOR8 SIM_VOLATILE_USHORT_POINTER(0x6e + SIM_CRB) |
#define | CSOR9 SIM_VOLATILE_USHORT_POINTER(0x72 + SIM_CRB) |
#define | CSOR10 SIM_VOLATILE_USHORT_POINTER(0x76 + SIM_CRB) |
Motorola M68K System Integration Module.
The system integration module (SIM) is used on many Motorola 16- and 32-bit MCUs for the following functions:
() System configuration and protection. Bus and software watchdog monitors are provided in addition to periodic interrupt generators.
() Clock signal generation for other intermodule bus (IMB) members and external devices.
() The generation of chip-select signals that simplify external circuitry interface.
() Data ports that are available for general purpose input and output.
() A system test block that is intended only for factory tests.
For more information, refer to Motorola's "Modular Microcontroller
Family System Integration Module Reference Manual" (Motorola document SIMRM/AD).
