RTEMS 6.1
samv71n21.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAMV71N21_
31#define _SAMV71N21_
32
41
42#ifdef __cplusplus
43 extern "C" {
44#endif
45
46#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
47#include <stdint.h>
48#endif
49
50/* ************************************************************************** */
51/* CMSIS DEFINITIONS FOR SAMV71N21 */
52/* ************************************************************************** */
55
57typedef enum IRQn
58{
59/****** Cortex-M7 Processor Exceptions Numbers ******************************/
69/****** SAMV71N21 specific Interrupt Numbers *********************************/
70
80 PIOA_IRQn = 10,
81 PIOB_IRQn = 11,
85 PIOD_IRQn = 16,
89 SPI0_IRQn = 21,
90 SSC_IRQn = 22,
91 TC0_IRQn = 23,
92 TC1_IRQn = 24,
93 TC2_IRQn = 25,
95 DACC_IRQn = 30,
96 PWM0_IRQn = 31,
97 ICM_IRQn = 32,
98 ACC_IRQn = 33,
110 TC9_IRQn = 50,
113 MLB_IRQn = 53,
114 AES_IRQn = 56,
117 ISI_IRQn = 59,
123
124typedef struct _DeviceVectors
125{
126 /* Stack pointer */
127 void* pvStack;
128
129 /* Cortex-M handlers */
130 void* pfnReset_Handler;
131 void* pfnNMI_Handler;
132 void* pfnHardFault_Handler;
133 void* pfnMemManage_Handler;
134 void* pfnBusFault_Handler;
135 void* pfnUsageFault_Handler;
136 void* pfnReserved1_Handler;
137 void* pfnReserved2_Handler;
138 void* pfnReserved3_Handler;
139 void* pfnReserved4_Handler;
140 void* pfnSVC_Handler;
141 void* pfnDebugMon_Handler;
142 void* pfnReserved5_Handler;
143 void* pfnPendSV_Handler;
144 void* pfnSysTick_Handler;
145
146 /* Peripheral handlers */
147 void* pfnSUPC_Handler; /* 0 Supply Controller */
148 void* pfnRSTC_Handler; /* 1 Reset Controller */
149 void* pfnRTC_Handler; /* 2 Real Time Clock */
150 void* pfnRTT_Handler; /* 3 Real Time Timer */
151 void* pfnWDT_Handler; /* 4 Watchdog Timer */
152 void* pfnPMC_Handler; /* 5 Power Management Controller */
153 void* pfnEFC_Handler; /* 6 Enhanced Embedded Flash Controller */
154 void* pfnUART0_Handler; /* 7 UART 0 */
155 void* pfnUART1_Handler; /* 8 UART 1 */
156 void* pvReserved9;
157 void* pfnPIOA_Handler; /* 10 Parallel I/O Controller A */
158 void* pfnPIOB_Handler; /* 11 Parallel I/O Controller B */
159 void* pvReserved12;
160 void* pfnUSART0_Handler; /* 13 USART 0 */
161 void* pfnUSART1_Handler; /* 14 USART 1 */
162 void* pfnUSART2_Handler; /* 15 USART 2 */
163 void* pfnPIOD_Handler; /* 16 Parallel I/O Controller D */
164 void* pvReserved17;
165 void* pfnHSMCI_Handler; /* 18 Multimedia Card Interface */
166 void* pfnTWIHS0_Handler; /* 19 Two Wire Interface 0 HS */
167 void* pfnTWIHS1_Handler; /* 20 Two Wire Interface 1 HS */
168 void* pfnSPI0_Handler; /* 21 Serial Peripheral Interface 0 */
169 void* pfnSSC_Handler; /* 22 Synchronous Serial Controller */
170 void* pfnTC0_Handler; /* 23 Timer/Counter 0 */
171 void* pfnTC1_Handler; /* 24 Timer/Counter 1 */
172 void* pfnTC2_Handler; /* 25 Timer/Counter 2 */
173 void* pvReserved26;
174 void* pvReserved27;
175 void* pvReserved28;
176 void* pfnAFEC0_Handler; /* 29 Analog Front End 0 */
177 void* pfnDACC_Handler; /* 30 Digital To Analog Converter */
178 void* pfnPWM0_Handler; /* 31 Pulse Width Modulation 0 */
179 void* pfnICM_Handler; /* 32 Integrity Check Monitor */
180 void* pfnACC_Handler; /* 33 Analog Comparator */
181 void* pfnUSBHS_Handler; /* 34 USB Host / Device Controller */
182 void* pfnMCAN0_Handler; /* 35 MCAN Controller 0 */
183 void* pvReserved36;
184 void* pfnMCAN1_Handler; /* 37 MCAN Controller 1 */
185 void* pvReserved38;
186 void* pfnGMAC_Handler; /* 39 Ethernet MAC */
187 void* pfnAFEC1_Handler; /* 40 Analog Front End 1 */
188 void* pfnTWIHS2_Handler; /* 41 Two Wire Interface 2 HS */
189 void* pfnSPI1_Handler; /* 42 Serial Peripheral Interface 1 */
190 void* pfnQSPI_Handler; /* 43 Quad I/O Serial Peripheral Interface */
191 void* pfnUART2_Handler; /* 44 UART 2 */
192 void* pfnUART3_Handler; /* 45 UART 3 */
193 void* pfnUART4_Handler; /* 46 UART 4 */
194 void* pvReserved47;
195 void* pvReserved48;
196 void* pvReserved49;
197 void* pfnTC9_Handler; /* 50 Timer/Counter 9 */
198 void* pfnTC10_Handler; /* 51 Timer/Counter 10 */
199 void* pfnTC11_Handler; /* 52 Timer/Counter 11 */
200 void* pfnMLB_Handler; /* 53 MediaLB */
201 void* pvReserved54;
202 void* pvReserved55;
203 void* pfnAES_Handler; /* 56 AES */
204 void* pfnTRNG_Handler; /* 57 True Random Generator */
205 void* pfnXDMAC_Handler; /* 58 DMA */
206 void* pfnISI_Handler; /* 59 Camera Interface */
207 void* pfnPWM1_Handler; /* 60 Pulse Width Modulation 1 */
208 void* pvReserved61;
209 void* pvReserved62;
210 void* pfnRSWDT_Handler; /* 63 Reinforced Secure Watchdog Timer */
212
213/* Cortex-M7 core handlers */
214void Reset_Handler ( void );
215void NMI_Handler ( void );
216void HardFault_Handler ( void );
217void MemManage_Handler ( void );
218void BusFault_Handler ( void );
219void UsageFault_Handler ( void );
220void SVC_Handler ( void );
221void DebugMon_Handler ( void );
222void PendSV_Handler ( void );
223void SysTick_Handler ( void );
224
225/* Peripherals handlers */
226void ACC_Handler ( void );
227void AES_Handler ( void );
228void AFEC0_Handler ( void );
229void AFEC1_Handler ( void );
230void DACC_Handler ( void );
231void EFC_Handler ( void );
232void GMAC_Handler ( void );
233void HSMCI_Handler ( void );
234void ICM_Handler ( void );
235void ISI_Handler ( void );
236void MCAN0_Handler ( void );
237void MCAN1_Handler ( void );
238void MLB_Handler ( void );
239void PIOA_Handler ( void );
240void PIOB_Handler ( void );
241void PIOD_Handler ( void );
242void PMC_Handler ( void );
243void PWM0_Handler ( void );
244void PWM1_Handler ( void );
245void QSPI_Handler ( void );
246void RSTC_Handler ( void );
247void RSWDT_Handler ( void );
248void RTC_Handler ( void );
249void RTT_Handler ( void );
250void SPI0_Handler ( void );
251void SPI1_Handler ( void );
252void SSC_Handler ( void );
253void SUPC_Handler ( void );
254void TC0_Handler ( void );
255void TC1_Handler ( void );
256void TC2_Handler ( void );
257void TC9_Handler ( void );
258void TC10_Handler ( void );
259void TC11_Handler ( void );
260void TRNG_Handler ( void );
261void TWIHS0_Handler ( void );
262void TWIHS1_Handler ( void );
263void TWIHS2_Handler ( void );
264void UART0_Handler ( void );
265void UART1_Handler ( void );
266void UART2_Handler ( void );
267void UART3_Handler ( void );
268void UART4_Handler ( void );
269void USART0_Handler ( void );
270void USART1_Handler ( void );
271void USART2_Handler ( void );
272void USBHS_Handler ( void );
273void WDT_Handler ( void );
274void XDMAC_Handler ( void );
275
280#define __CM7_REV 0x0000
281#define __MPU_PRESENT 1
282#define __NVIC_PRIO_BITS 3
283#define __FPU_PRESENT 1
284#define __FPU_DP 1
285#define __ICACHE_PRESENT 1
286#define __DCACHE_PRESENT 1
287#define __DTCM_PRESENT 1
288#define __ITCM_PRESENT 1
289#define __Vendor_SysTickConfig 0
291/*
292 * \brief CMSIS includes
293 */
294
295#include <core_cm7.h>
296#if !defined DONT_USE_CMSIS_INIT
297#include "system_samv71.h"
298#endif /* DONT_USE_CMSIS_INIT */
299
302/* ************************************************************************** */
304/* ************************************************************************** */
307
308#include "component/component_acc.h"
309#include "component/component_aes.h"
310#include "component/component_afec.h"
311#include "component/component_chipid.h"
312#include "component/component_dacc.h"
313#include "component/component_efc.h"
314#include "component/component_gmac.h"
315#include "component/component_gpbr.h"
316#include "component/component_hsmci.h"
317#include "component/component_icm.h"
318#include "component/component_isi.h"
319#include "component/component_matrix.h"
320#include "component/component_mcan.h"
321#include "component/component_mlb.h"
322#include "component/component_pio.h"
323#include "component/component_pmc.h"
324#include "component/component_pwm.h"
325#include "component/component_qspi.h"
326#include "component/component_rstc.h"
327#include "component/component_rswdt.h"
328#include "component/component_rtc.h"
329#include "component/component_rtt.h"
330#include "component/component_spi.h"
331#include "component/component_ssc.h"
332#include "component/component_supc.h"
333#include "component/component_tc.h"
334#include "component/component_trng.h"
335#include "component/component_twihs.h"
336#include "component/component_uart.h"
337#include "component/component_usart.h"
338#include "component/component_usbhs.h"
339#include "component/component_utmi.h"
340#include "component/component_wdt.h"
341#include "component/component_xdmac.h"
344#ifndef __rtems__
345/* ************************************************************************** */
346/* REGISTER ACCESS DEFINITIONS FOR SAMV71N21 */
347/* ************************************************************************** */
350
351#include "instance/instance_hsmci.h"
352#include "instance/instance_ssc.h"
353#include "instance/instance_spi0.h"
354#include "instance/instance_tc0.h"
355#include "instance/instance_twihs0.h"
356#include "instance/instance_twihs1.h"
357#include "instance/instance_pwm0.h"
358#include "instance/instance_usart0.h"
359#include "instance/instance_usart1.h"
360#include "instance/instance_usart2.h"
361#include "instance/instance_mcan0.h"
362#include "instance/instance_mcan1.h"
363#include "instance/instance_usbhs.h"
364#include "instance/instance_afec0.h"
365#include "instance/instance_dacc.h"
366#include "instance/instance_acc.h"
367#include "instance/instance_icm.h"
368#include "instance/instance_isi.h"
369#include "instance/instance_gmac.h"
370#include "instance/instance_tc3.h"
371#include "instance/instance_spi1.h"
372#include "instance/instance_pwm1.h"
373#include "instance/instance_twihs2.h"
374#include "instance/instance_afec1.h"
375#include "instance/instance_mlb.h"
376#include "instance/instance_aes.h"
377#include "instance/instance_trng.h"
378#include "instance/instance_xdmac.h"
379#include "instance/instance_qspi.h"
380#include "instance/instance_matrix.h"
381#include "instance/instance_utmi.h"
382#include "instance/instance_pmc.h"
383#include "instance/instance_uart0.h"
384#include "instance/instance_chipid.h"
385#include "instance/instance_uart1.h"
386#include "instance/instance_efc.h"
387#include "instance/instance_pioa.h"
388#include "instance/instance_piob.h"
389#include "instance/instance_piod.h"
390#include "instance/instance_rstc.h"
391#include "instance/instance_supc.h"
392#include "instance/instance_rtt.h"
393#include "instance/instance_wdt.h"
394#include "instance/instance_rtc.h"
395#include "instance/instance_gpbr.h"
396#include "instance/instance_rswdt.h"
397#include "instance/instance_uart2.h"
398#include "instance/instance_uart3.h"
399#include "instance/instance_uart4.h"
401#endif /* __rtems__ */
402
403/* ************************************************************************** */
404/* PERIPHERAL ID DEFINITIONS FOR SAMV71N21 */
405/* ************************************************************************** */
408
409#define ID_SUPC ( 0)
410#define ID_RSTC ( 1)
411#define ID_RTC ( 2)
412#define ID_RTT ( 3)
413#define ID_WDT ( 4)
414#define ID_PMC ( 5)
415#define ID_EFC ( 6)
416#define ID_UART0 ( 7)
417#define ID_UART1 ( 8)
418#define ID_PIOA (10)
419#define ID_PIOB (11)
420#define ID_USART0 (13)
421#define ID_USART1 (14)
422#define ID_USART2 (15)
423#define ID_PIOD (16)
424#define ID_HSMCI (18)
425#define ID_TWIHS0 (19)
426#define ID_TWIHS1 (20)
427#define ID_SPI0 (21)
428#define ID_SSC (22)
429#define ID_TC0 (23)
430#define ID_TC1 (24)
431#define ID_TC2 (25)
432#define ID_AFEC0 (29)
433#define ID_DACC (30)
434#define ID_PWM0 (31)
435#define ID_ICM (32)
436#define ID_ACC (33)
437#define ID_USBHS (34)
438#define ID_MCAN0 (35)
439#define ID_MCAN1 (37)
440#define ID_GMAC (39)
441#define ID_AFEC1 (40)
442#define ID_TWIHS2 (41)
443#define ID_SPI1 (42)
444#define ID_QSPI (43)
445#define ID_UART2 (44)
446#define ID_UART3 (45)
447#define ID_UART4 (46)
448#define ID_TC9 (50)
449#define ID_TC10 (51)
450#define ID_TC11 (52)
451#define ID_MLB (53)
452#define ID_AES (56)
453#define ID_TRNG (57)
454#define ID_XDMAC (58)
455#define ID_ISI (59)
456#define ID_PWM1 (60)
457#define ID_RSWDT (63)
459#define ID_PERIPH_COUNT (64)
461
462/* ************************************************************************** */
463/* BASE ADDRESS DEFINITIONS FOR SAMV71N21 */
464/* ************************************************************************** */
467
468#if (defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
469#define HSMCI (0x40000000U)
470#define SSC (0x40004000U)
471#define SPI0 (0x40008000U)
472#define TC0 (0x4000C000U)
473#define TWIHS0 (0x40018000U)
474#define TWIHS1 (0x4001C000U)
475#define PWM0 (0x40020000U)
476#define USART0 (0x40024000U)
477#define USART1 (0x40028000U)
478#define USART2 (0x4002C000U)
479#define MCAN0 (0x40030000U)
480#define MCAN1 (0x40034000U)
481#define USBHS (0x40038000U)
482#define AFEC0 (0x4003C000U)
483#define DACC (0x40040000U)
484#define ACC (0x40044000U)
485#define ICM (0x40048000U)
486#define ISI (0x4004C000U)
487#define GMAC (0x40050000U)
488#define TC3 (0x40054000U)
489#define SPI1 (0x40058000U)
490#define PWM1 (0x4005C000U)
491#define TWIHS2 (0x40060000U)
492#define AFEC1 (0x40064000U)
493#define MLB (0x40068000U)
494#define AES (0x4006C000U)
495#define TRNG (0x40070000U)
496#define XDMAC (0x40078000U)
497#define QSPI (0x4007C000U)
498#define MATRIX (0x40088000U)
499#define UTMI (0x400E0400U)
500#define PMC (0x400E0600U)
501#define UART0 (0x400E0800U)
502#define CHIPID (0x400E0940U)
503#define UART1 (0x400E0A00U)
504#define EFC (0x400E0C00U)
505#define PIOA (0x400E0E00U)
506#define PIOB (0x400E1000U)
507#define PIOD (0x400E1400U)
508#define RSTC (0x400E1800U)
509#define SUPC (0x400E1810U)
510#define RTT (0x400E1830U)
511#define WDT (0x400E1850U)
512#define RTC (0x400E1860U)
513#define GPBR (0x400E1890U)
514#define RSWDT (0x400E1900U)
515#define UART2 (0x400E1A00U)
516#define UART3 (0x400E1C00U)
517#define UART4 (0x400E1E00U)
518#else
519#define HSMCI ((Hsmci *)0x40000000U)
520#define SSC ((Ssc *)0x40004000U)
521#define SPI0 ((Spi *)0x40008000U)
522#define TC0 ((Tc *)0x4000C000U)
523#define TWIHS0 ((Twihs *)0x40018000U)
524#define TWIHS1 ((Twihs *)0x4001C000U)
525#define PWM0 ((Pwm *)0x40020000U)
526#define USART0 ((Usart *)0x40024000U)
527#define USART1 ((Usart *)0x40028000U)
528#define USART2 ((Usart *)0x4002C000U)
529#define MCAN0 ((Mcan *)0x40030000U)
530#define MCAN1 ((Mcan *)0x40034000U)
531#define USBHS ((Usbhs *)0x40038000U)
532#define AFEC0 ((Afec *)0x4003C000U)
533#define DACC ((Dacc *)0x40040000U)
534#define ACC ((Acc *)0x40044000U)
535#define ICM ((Icm *)0x40048000U)
536#define ISI ((Isi *)0x4004C000U)
537#define GMAC ((Gmac *)0x40050000U)
538#define TC3 ((Tc *)0x40054000U)
539#define SPI1 ((Spi *)0x40058000U)
540#define PWM1 ((Pwm *)0x4005C000U)
541#define TWIHS2 ((Twihs *)0x40060000U)
542#define AFEC1 ((Afec *)0x40064000U)
543#define MLB ((Mlb *)0x40068000U)
544#define AES ((Aes *)0x4006C000U)
545#define TRNG ((Trng *)0x40070000U)
546#define XDMAC ((Xdmac *)0x40078000U)
547#define QSPI ((Qspi *)0x4007C000U)
548#define MATRIX ((Matrix *)0x40088000U)
549#define UTMI ((Utmi *)0x400E0400U)
550#define PMC ((Pmc *)0x400E0600U)
551#define UART0 ((Uart *)0x400E0800U)
552#define CHIPID ((Chipid *)0x400E0940U)
553#define UART1 ((Uart *)0x400E0A00U)
554#define EFC ((Efc *)0x400E0C00U)
555#define PIOA ((Pio *)0x400E0E00U)
556#define PIOB ((Pio *)0x400E1000U)
557#define PIOD ((Pio *)0x400E1400U)
558#define RSTC ((Rstc *)0x400E1800U)
559#define SUPC ((Supc *)0x400E1810U)
560#define RTT ((Rtt *)0x400E1830U)
561#define WDT ((Wdt *)0x400E1850U)
562#define RTC ((Rtc *)0x400E1860U)
563#define GPBR ((Gpbr *)0x400E1890U)
564#define RSWDT ((Rswdt *)0x400E1900U)
565#define UART2 ((Uart *)0x400E1A00U)
566#define UART3 ((Uart *)0x400E1C00U)
567#define UART4 ((Uart *)0x400E1E00U)
568#endif /* (defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
571/* ************************************************************************** */
572/* PIO DEFINITIONS FOR SAMV71N21 */
573/* ************************************************************************** */
576
577#include "pio/pio_samv71n21.h"
580/* ************************************************************************** */
581/* MEMORY MAPPING DEFINITIONS FOR SAMV71N21 */
582/* ************************************************************************** */
583
584#define IFLASH_SIZE (0x200000u)
585#define IFLASH_PAGE_SIZE (512u)
586#define IFLASH_LOCK_REGION_SIZE (8192u)
587#define IFLASH_NB_OF_PAGES (4096u)
588#define IFLASH_NB_OF_LOCK_BITS (128u)
589#define IRAM_SIZE (0x60000u)
590
591#define QSPIMEM_ADDR (0x80000000u)
592#define AXIMX_ADDR (0xA0000000u)
593#define ITCM_ADDR (0x00000000u)
594#define IFLASH_ADDR (0x00400000u)
595#define IROM_ADDR (0x00800000u)
596#define DTCM_ADDR (0x20000000u)
597#define IRAM_ADDR (0x20400000u)
598#define EBI_CS0_ADDR (0x60000000u)
599#define EBI_CS1_ADDR (0x61000000u)
600#define EBI_CS2_ADDR (0x62000000u)
601#define EBI_CS3_ADDR (0x63000000u)
602#define SDRAM_CS_ADDR (0x70000000u)
604/* ************************************************************************** */
605/* MISCELLANEOUS DEFINITIONS FOR SAMV71N21 */
606/* ************************************************************************** */
607
608#define CHIP_JTAGID (0x05B3D03FUL)
609#define CHIP_CIDR (0xA1220E00UL)
610#define CHIP_EXID (0x00000001UL)
611
612/* ************************************************************************** */
613/* ELECTRICAL DEFINITIONS FOR SAMV71N21 */
614/* ************************************************************************** */
615
616/* %ATMEL_ELECTRICAL% */
617
618/* Device characteristics */
619#define CHIP_FREQ_SLCK_RC_MIN (20000UL)
620#define CHIP_FREQ_SLCK_RC (32000UL)
621#define CHIP_FREQ_SLCK_RC_MAX (44000UL)
622#define CHIP_FREQ_MAINCK_RC_4MHZ (4000000UL)
623#define CHIP_FREQ_MAINCK_RC_8MHZ (8000000UL)
624#define CHIP_FREQ_MAINCK_RC_12MHZ (12000000UL)
625#define CHIP_FREQ_CPU_MAX (120000000UL)
626#define CHIP_FREQ_XTAL_32K (32768UL)
627#define CHIP_FREQ_XTAL_12M (12000000UL)
628
629/* Embedded Flash Read Wait State (VDDCORE set at 1.20V) */
630#define CHIP_FREQ_FWS_0 (20000000UL)
631#define CHIP_FREQ_FWS_1 (40000000UL)
632#define CHIP_FREQ_FWS_2 (60000000UL)
633#define CHIP_FREQ_FWS_3 (80000000UL)
634#define CHIP_FREQ_FWS_4 (100000000UL)
635#define CHIP_FREQ_FWS_5 (123000000UL)
637#ifdef __cplusplus
638}
639#endif
640
643#endif /* _SAMV71N21_ */
CMSIS Cortex-M7 Core Peripheral Access Layer Header File.
void UsageFault_Handler(void)
Default UsageFault interrupt handler.
Definition: exceptions.c:207
void HardFault_Handler(void)
Default HardFault interrupt handler.
Definition: exceptions.c:168
void MemManage_Handler(void)
Default MemManage interrupt handler.
Definition: exceptions.c:180
void NMI_Handler(void)
Default NMI interrupt handler.
Definition: exceptions.c:53
void BusFault_Handler(void)
Default BusFault interrupt handler.
Definition: exceptions.c:193
@ TC9_IRQn
Definition: samv71n21.h:110
@ PendSV_IRQn
Definition: samv71n21.h:67
@ PWM1_IRQn
Definition: samv71n21.h:118
@ UART3_IRQn
Definition: samv71n21.h:108
@ XDMAC_IRQn
Definition: samv71n21.h:116
@ TC0_IRQn
Definition: samv71n21.h:91
@ MemoryManagement_IRQn
Definition: samv71n21.h:62
@ ISI_IRQn
Definition: samv71n21.h:117
@ TWIHS1_IRQn
Definition: samv71n21.h:88
@ MCAN1_IRQn
Definition: samv71n21.h:101
@ USART2_IRQn
Definition: samv71n21.h:84
@ USART0_IRQn
Definition: samv71n21.h:82
@ GMAC_IRQn
Definition: samv71n21.h:102
@ SVCall_IRQn
Definition: samv71n21.h:65
@ RSWDT_IRQn
Definition: samv71n21.h:119
@ AFEC0_IRQn
Definition: samv71n21.h:94
@ TC1_IRQn
Definition: samv71n21.h:92
@ UsageFault_IRQn
Definition: samv71n21.h:64
@ SysTick_IRQn
Definition: samv71n21.h:68
@ PMC_IRQn
Definition: samv71n21.h:76
@ SUPC_IRQn
Definition: samv71n21.h:71
@ WDT_IRQn
Definition: samv71n21.h:75
@ SSC_IRQn
Definition: samv71n21.h:90
@ PIOA_IRQn
Definition: samv71n21.h:80
@ PERIPH_COUNT_IRQn
Definition: samv71n21.h:121
@ AES_IRQn
Definition: samv71n21.h:114
@ BusFault_IRQn
Definition: samv71n21.h:63
@ TC11_IRQn
Definition: samv71n21.h:112
@ DebugMonitor_IRQn
Definition: samv71n21.h:66
@ TC2_IRQn
Definition: samv71n21.h:93
@ UART1_IRQn
Definition: samv71n21.h:79
@ TWIHS2_IRQn
Definition: samv71n21.h:104
@ MLB_IRQn
Definition: samv71n21.h:113
@ TC10_IRQn
Definition: samv71n21.h:111
@ RSTC_IRQn
Definition: samv71n21.h:72
@ PIOD_IRQn
Definition: samv71n21.h:85
@ SPI1_IRQn
Definition: samv71n21.h:105
@ UART2_IRQn
Definition: samv71n21.h:107
@ HardFault_IRQn
Definition: samv71n21.h:61
@ TRNG_IRQn
Definition: samv71n21.h:115
@ RTT_IRQn
Definition: samv71n21.h:74
@ AFEC1_IRQn
Definition: samv71n21.h:103
@ QSPI_IRQn
Definition: samv71n21.h:106
@ USART1_IRQn
Definition: samv71n21.h:83
@ RTC_IRQn
Definition: samv71n21.h:73
@ NonMaskableInt_IRQn
Definition: samv71n21.h:60
@ UART4_IRQn
Definition: samv71n21.h:109
@ TWIHS0_IRQn
Definition: samv71n21.h:87
@ PIOB_IRQn
Definition: samv71n21.h:81
@ USBHS_IRQn
Definition: samv71n21.h:99
@ PWM0_IRQn
Definition: samv71n21.h:96
@ HSMCI_IRQn
Definition: samv71n21.h:86
@ UART0_IRQn
Definition: samv71n21.h:78
@ ICM_IRQn
Definition: samv71n21.h:97
@ ACC_IRQn
Definition: samv71n21.h:98
@ MCAN0_IRQn
Definition: samv71n21.h:100
@ EFC_IRQn
Definition: samv71n21.h:77
@ SPI0_IRQn
Definition: samv71n21.h:89
@ DACC_IRQn
Definition: samv71n21.h:95
IRQn_Type
STM32H7XX Interrupt Number Definition, according to the selected device in Library_configuration_sect...
Definition: stm32h723xx.h:49
Definition: same70j19.h:122
