RTEMS 6.1
Macros | Functions
s25fl1.h File Reference
#define USE_QSPI_DMA
#define Size(pAt25)   ((pAt25)->pDesc->size)
#define PageSize(pAt25)   ((pAt25)->pDesc->pageSize)
#define BlockSize(pAt25)   ((pAt25)->pDesc->blockSize)
#define Name(pAt25)   ((pAt25)->pDesc->name)
#define ManId(pAt25)   (((pAt25)->pDesc->jedecId) & 0xFF)
#define PageNumber(pAt25)   (Size(pAt25) / PageSize(pAt25))
#define BlockNumber(pAt25)   (Size(pAt25) / BlockSize(pAt25))
#define PagePerBlock(pAt25)   (BlockSize(pAt25) / PageSize(pAt25))
#define BlockEraseCmd(pAt25)   ((pAt25)->pDesc->blockEraseCmd)
#define ERROR_PROTECTED   1
#define ERROR_BUSY   2
#define ERROR_PROGRAM   3
#define ERROR_SPI   4
#define STATUS_RDYBSY   (1 << 0)
#define STATUS_RDYBSY_READY   (0 << 0)
#define STATUS_RDYBSY_BUSY   (1 << 0)
#define STATUS_WEL   (1 << 1)
#define STATUS_WEL_DISABLED   (0 << 1)
#define STATUS_WEL_ENABLED   (1 << 1)
#define STATUS_SWP   (3 << 2)
#define STATUS_SWP_PROTALL   (3 << 2)
#define STATUS_SWP_PROTSOME   (1 << 2)
#define STATUS_SWP_PROTNONE   (0 << 2)
#define STATUS_WPP   (1 << 4)
#define STATUS_WPP_NOTASSERTED   (0 << 4)
#define STATUS_WPP_ASSERTED   (1 << 4)
#define STATUS_EPE   (1 << 5)
#define STATUS_EPE_SUCCESS   (0 << 5)
#define STATUS_EPE_ERROR   (1 << 5)
#define STATUS_SPRL   (1 << 7)
#define STATUS_SPRL_UNLOCKED   (0 << 7)
#define STATUS_SPRL_LOCKED   (1 << 7)
#define STATUS_QUAD_ENABLE   (1 << 1)
#define STATUS_WRAP_ENABLE   (0 << 4)
#define STATUS_LATENCY_CTRL   (0xF << 0)
#define STATUS_WRAP_BYTE   (1 << 5)
#define BLOCK_PROTECT_Msk   (7 << 2)
#define TOP_BTM_PROTECT_Msk   (1 << 5)
#define SEC_PROTECT_Msk   (1 << 6)
#define CHIP_PROTECT_Msk   (0x1F << 2)
#define READ_ARRAY   0x0B
#define READ_ARRAY_LF   0x03
#define READ_ARRAY_DUAL   0x3B
#define READ_ARRAY_QUAD   0x6B
#define READ_ARRAY_DUAL_IO   0xBB
#define READ_ARRAY_QUAD_IO   0xEB
#define BLOCK_ERASE_4K   0x20
#define BLOCK_ERASE_32K   0x52
#define BLOCK_ERASE_64K   0xD8
#define CHIP_ERASE_1   0x60
#define CHIP_ERASE_2   0xC7
#define BYTE_PAGE_PROGRAM   0x02
#define SEQUENTIAL_PROGRAM_1   0xAD
#define SEQUENTIAL_PROGRAM_2   0xAF
#define WRITE_ENABLE   0x06
#define WRITE_DISABLE   0x04
#define PROTECT_SECTOR   0x36
#define UNPROTECT_SECTOR   0x39
#define READ_SECTOR_PROT   0x3C
#define READ_STATUS_1   0x05
#define READ_STATUS_2   0x35
#define READ_STATUS_3   0x33
#define WRITE_STATUS   0x01
#define READ_JEDEC_ID   0x9F
#define DEEP_PDOWN   0xB9
#define RES_DEEP_PDOWN   0xAB
#define SOFT_RESET_ENABLE   0x66
#define SOFT_RESET   0x99
#define WRAP_ENABLE   0x77
#define CONT_MODE_RESET   0xFF
#define ATMEL_SPI_FLASH   0x1F
#define ST_SPI_FLASH   0x20
#define WINBOND_SPI_FLASH   0xEF
#define MACRONIX_SPI_FLASH   0xC2
#define SST_SPI_FLASH   0xBF
uint32_t S25FL1D_ReadJedecId (void)
void S25FL1D_InitFlashInterface (uint8_t Mode)
void S25FL1D_SoftReset (void)
void S25FL1D_ContReadModeReset (void)
unsigned char S25FL1D_Unprotect (void)
unsigned char S25FL1D_Protect (uint32_t StartAddr, uint32_t Size)
void S25FL1D_QuadMode (uint8_t Enable)
void S25FL1D_EnableWrap (uint8_t ByetAlign)
void S25FL1D_SetReadLatencyControl (uint8_t Latency)
unsigned char S25FL1D_EraseChip (void)
unsigned char S25FL1D_EraseSector (unsigned int address)
unsigned char S25FL1D_Erase64KBlock (unsigned int address)
unsigned char S25FL1D_Write (uint32_t *pData, uint32_t size, uint32_t address, uint8_t Secure)
unsigned char S25FL1D_Read (uint32_t *pData, uint32_t size, uint32_t address)
unsigned char S25FL1D_ReadDual (uint32_t *pData, uint32_t size, uint32_t address)
unsigned char S25FL1D_ReadQuad (uint32_t *pData, uint32_t size, uint32_t address)
unsigned char S25FL1D_ReadDualIO (uint32_t *pData, uint32_t size, uint32_t address, uint8_t ContMode, uint8_t Secure)
unsigned char S25FL1D_ReadQuadIO (uint32_t *pData, uint32_t size, uint32_t address, uint8_t ContMode, uint8_t Secure)
Interface for the S25fl1 Serial Flash driver.
◆ ATMEL_SPI_FLASH
SPI Flash Manufacturer JEDEC ID
◆ BLOCK_ERASE_32K
Block erase command code (32K block).
◆ BLOCK_ERASE_4K
Block erase command code (4K block).
◆ BLOCK_ERASE_64K
Block erase command code (64K block).
◆ BYTE_PAGE_PROGRAM
Byte/page program command code.
◆ CHIP_ERASE_1
Chip erase command code 1.
◆ CHIP_ERASE_2
Chip erase command code 2.
◆ CONT_MODE_RESET
Continuous Read Mode Reset command code.
◆ DEEP_PDOWN
Deep power-down command code.
◆ ERROR_BUSY
Device is busy executing a command.
◆ ERROR_PROGRAM
There was a problem while trying to program page data.
◆ ERROR_PROTECTED
Device is protected, operation cannot be carried out.
◆ ERROR_SPI
#define ERROR_SPI   4
There was an SPI communication error.
◆ PROTECT_SECTOR
Protect sector command code.
◆ READ_ARRAY
Read array command code.
◆ READ_ARRAY_DUAL
Fast Read array command code.
◆ READ_ARRAY_DUAL_IO
◆ READ_ARRAY_LF
Read array (low frequency) command code.
◆ READ_ARRAY_QUAD
◆ READ_ARRAY_QUAD_IO
◆ READ_JEDEC_ID
Read manufacturer and device ID command code.
◆ READ_SECTOR_PROT
Read sector protection registers command code.
◆ READ_STATUS_1
Read status register command code.
◆ READ_STATUS_2
◆ READ_STATUS_3
◆ RES_DEEP_PDOWN
Resume from deep power-down command code.
◆ SEQUENTIAL_PROGRAM_1
Sequential program mode command code 1.
◆ SEQUENTIAL_PROGRAM_2
Sequential program mode command code 2.
◆ SOFT_RESET
◆ SOFT_RESET_ENABLE
◆ STATUS_EPE
Erase/program error bit.
◆ STATUS_EPE_ERROR
Erase or program error detected.
◆ STATUS_EPE_SUCCESS
Erase or program operation was successful.
◆ STATUS_LATENCY_CTRL
Latency control bits
◆ STATUS_QUAD_ENABLE
Quad enable bit
◆ STATUS_RDYBSY
Device ready/busy status bit.
◆ STATUS_RDYBSY_BUSY
Device is busy with internal operations.
◆ STATUS_RDYBSY_READY
Device is ready.
◆ STATUS_SPRL
Sector protection registers locked bit.
◆ STATUS_SPRL_LOCKED
Sector protection registers are locked.
◆ STATUS_SPRL_UNLOCKED
Sector protection registers are unlocked.
◆ STATUS_SWP
Software protection status bit-field.
◆ STATUS_SWP_PROTALL
All sectors are software protected.
◆ STATUS_SWP_PROTNONE
No sector is software protected.
◆ STATUS_SWP_PROTSOME
Some sectors are software protected.
◆ STATUS_WEL
Write enable latch status bit.
◆ STATUS_WEL_DISABLED
Device is not write enabled.
◆ STATUS_WEL_ENABLED
Device is write enabled.
◆ STATUS_WPP
Write protect pin status bit.
◆ STATUS_WPP_ASSERTED
Write protect signal is asserted.
◆ STATUS_WPP_NOTASSERTED
Write protect signal is not asserted.
◆ STATUS_WRAP_ENABLE
Quad enable bit
◆ UNPROTECT_SECTOR
Unprotected sector command code.
◆ WRAP_ENABLE
◆ WRITE_DISABLE
Write disable command code.
◆ WRITE_ENABLE
Write enable command code.
◆ WRITE_STATUS
Write status register command code.
