RTEMS 6.1
RTEMS File Systems Inode Routines. More...
#include <inttypes.h>#include <string.h>#include <rtems/rfs/rtems-rfs-block.h>#include <rtems/rfs/rtems-rfs-file-system.h>#include <rtems/rfs/rtems-rfs-inode.h>#include <rtems/rfs/rtems-rfs-dir.h>RTEMS File Systems Inode Routines.
These functions manage inodes in the RFS file system. An inode is part of a block that reside after the bitmaps in the group.
| int rtems_rfs_inode_alloc | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_bitmap_bit | goal, | ||
| rtems_rfs_ino * | ino | ||
Allocate an inode number and return it.
| [in] | fs | is the file system data. |
| [out] | ino | will contain the ino. |
| 0 | Successful operation. |
| error_code | An error occurred. |
| int rtems_rfs_inode_close | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_inode_handle * | handle | ||
The close inode handle. All opened inodes need to be closed.
| [in] | fs | is the file system. |
| [in] | handle | is the handle to close. |
| int rtems_rfs_inode_create | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_ino | parent, | ||
| const char * | name, | ||
| size_t | length, | ||
| uint16_t | mode, | ||
| uint16_t | links, | ||
| uid_t | uid, | ||
| gid_t | gid, | ||
Create an inode allocating, initialising and adding an entry to the parent directory.
| [in] | parent | is the parent inode number to add the directory entry to. |
| [in] | name | is a pointer to the name of the directory entryinode to create. |
| int rtems_rfs_inode_delete | ( | rtems_rfs_file_system * | fs, |
Delete the inode eraseing it and release the buffer to commit the write. You need to load the inode again if you wish to use it again.
| [in] | handle | is the inode handle to erase. |
| int rtems_rfs_inode_free | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_ino | ino | ||
Free an inode.
| [in] | ino | is the ino too free. |
| rtems_rfs_pos rtems_rfs_inode_get_size | ( | rtems_rfs_file_system * | fs, |
Calculate the size of data attached to the inode.
| [in] | handle | is the inode handle. |
| size | The data size in bytes in the block map attched to the inode. |
| int rtems_rfs_inode_initialise | ( | rtems_rfs_inode_handle * | handle, |
| uid_t | uid, | ||
| gid_t | gid | ||
Initialise a new inode.
| [in] | handle | is the inode handle to initialise. |
| [in] | links | are the number of links to the inode. |
| [in] | mode | is the inode mode. |
| [in] | uid | is the user id. |
| [in] | gid | is the group id. |
| int rtems_rfs_inode_load | ( | rtems_rfs_file_system * | fs, |
Load the inode into memory.
| [in] | handle | is the inode handle to load. |
| int rtems_rfs_inode_open | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_ino | ino, | ||
| rtems_rfs_inode_handle * | handle, | ||
| bool | load | ||
Open the inode handle. This reads the inode into the buffer and sets the data pointer. All data is in media byte order and needs to be accessed via the supporting calls.
| [in] | ino | is the inode number. |
| [in] | handle | is the handle to the inode we are opening. |
| [in] | load | If true load the inode into memory from the media. |
| int rtems_rfs_inode_time_stamp_now | ( | rtems_rfs_inode_handle * | handle, |
| bool | atime, | ||
| bool | mtime | ||
Time stamp the inode with the current time. The ctime field is hanlded automatically.
| [in] | atime | Update the atime field. |
| [in] | mtime | UPdate the mtime field. |
| ENXIO | No inode is loaded. |
| int rtems_rfs_inode_unload | ( | rtems_rfs_file_system * | fs, |
| bool | update_ctime | ||
Unload the inode from memory.
| [in] | handle | is the inode handle to unload. |
| [in] | update_ctime | Update the ctime field of the inode. |
