RTEMS 6.1
RTEMS File Systems Format. More...
#include <string.h>#include <stdlib.h>#include <stdio.h>#include <inttypes.h>#include <rtems/rfs/rtems-rfs-data.h>#include <rtems/rfs/rtems-rfs-file-system.h>#include <rtems/rfs/rtems-rfs-inode.h>#include <rtems/rtems-rfs-format.h>#include <rtems/rfs/rtems-rfs-dir.h>Macros | |
| #define | GIGS(_g) (((uint64_t)(_g)) * 1024 * 1024) |
| #define | write_sb(_o, _d) rtems_rfs_write_u32(sb + (_o), _d) |
| int | rtems_rfs_format (const char *name, const rtems_rfs_format_config *config) |
Format the file system ready for use.
| #define GIGS | ( | _g | ) | (((uint64_t)(_g)) * 1024 * 1024) |
Return the number of gigabytes.
| int rtems_rfs_format | ( | const char * | name, |
| const rtems_rfs_format_config * | config | ||
RFS Format command.
| [in] | name | is the device name to format. |
| [in] | config | is a pointer to the configuration table. |
| -1 | Error. See errno. |
| 0 | No error. Format successful. |
