RTEMS 6.1
rbtreeimpl.h
2
12/*
13 * Copyright (c) 2010-2012 Gedare Bloom.
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_SCORE_RBTREEIMPL_H
38#define _RTEMS_SCORE_RBTREEIMPL_H
39
40#include <rtems/score/rbtree.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
63void _RBTree_Append( RBTree_Control *the_rbtree, RBTree_Node *the_node );
64
76void _RBTree_Prepend( RBTree_Control *the_rbtree, RBTree_Node *the_node );
77
89typedef bool (*RBTree_Visitor)(
90 const RBTree_Node *node,
91 void *visitor_arg
92);
93
101void _RBTree_Iterate(
102 const RBTree_Control *rbtree,
103 RBTree_Visitor visitor,
104 void *visitor_arg
105);
106
109#ifdef __cplusplus
110}
111#endif
112
113#endif
114/* end of include file */
void _RBTree_Append(RBTree_Control *the_rbtree, RBTree_Node *the_node)
Appends the node to the red-black tree.
Definition: rbtreeappend.c:43
void _RBTree_Iterate(const RBTree_Control *rbtree, RBTree_Visitor visitor, void *visitor_arg)
Red-black tree iteration.
Definition: rbtreeiterate.c:43
void _RBTree_Prepend(RBTree_Control *the_rbtree, RBTree_Node *the_node)
Prepends the node to the red-black tree.
Definition: rbtreeprepend.c:43
bool(* RBTree_Visitor)(const RBTree_Node *node, void *visitor_arg)
Red-black tree visitor.
Definition: rbtreeimpl.h:89
This header file provides interfaces of the Red-Black Tree Handler which are used by the implementati...
Red-black tree node.
Definition: rbtree.h:73
