RTEMS 6.1
rbtree.h File Reference
This header file provides interfaces of the Red-Black Tree Handler which are used by the implementation, the Application Configuration, and the API. More...
#include <rtems/score/bsd-tree.h>
struct  RBTree_Node
 Red-black tree node. More...
#define RBTREE_INITIALIZER_EMPTY(name)    RTEMS_RB_INITIALIZER( name )
 Initializer for an empty red-black tree with designator name.
#define RBTREE_DEFINE_EMPTY(name)    RBTree_Control name = RBTREE_INITIALIZER_EMPTY( name )
 Definition for an empty red-black tree with designator name.
typedef struct RBTree_Node RBTree_Node
typedef RTEMS_RB_HEAD (RBTree_Control, RBTree_Node) RBTree_Control
 Red-black tree control.
void _RBTree_Insert_color (RBTree_Control *the_rbtree, RBTree_Node *the_node)
 Rebalances the red-black tree after insertion of the node.
void _RBTree_Extract (RBTree_Control *the_rbtree, RBTree_Node *the_node)
 Extracts (removes) the node from the red-black tree.
RBTree_Node_RBTree_Minimum (const RBTree_Control *the_rbtree)
 Returns the minimum node of the red-black tree.
RBTree_Node_RBTree_Maximum (const RBTree_Control *the_rbtree)
 Returns the maximum node of the red-black tree.
RBTree_Node_RBTree_Predecessor (const RBTree_Node *node)
 Returns the predecessor of a node.
RBTree_Node_RBTree_Successor (const RBTree_Node *node)
 Returns the successor of a node.
void _RBTree_Replace_node (RBTree_Control *the_rbtree, RBTree_Node *victim, RBTree_Node *replacement)
 Replaces a node in the red-black tree without a rebalance.
void * _RBTree_Postorder_first (const RBTree_Control *the_rbtree, size_t offset)
 Returns the container of the first node of the specified red-black tree in postorder.
void * _RBTree_Postorder_next (const RBTree_Node *the_node, size_t offset)
 Returns the container of the next node in postorder.
