RTEMS 6.1
#include "chip.h"#include "stdlib.h"#include "string.h"#include <stdint.h>#include <bsp/iocopy.h>Macros | |
| #define | SCRAMBLE_KEY 0x0BADDEAD |
| __STATIC_INLINE void | QSPI_ConfigureMode (Qspi *pQspi, uint8_t dMode) |
| Configure QSPI/SPI mode. | |
| __STATIC_INLINE void | QSPI_Configure (Qspi *pQspi, uint32_t dwConfiguration) |
| Configure mode register of QSPI. | |
| __STATIC_INLINE void | QSPI_SetInstAddr (Qspi *pQspi, uint32_t dwAddr) |
| Configures a instruction address for QSPI in QSPI mode. | |
| __STATIC_INLINE void | QSPI_SetInst (Qspi *pQspi, uint8_t dwInst, uint8_t dwOpt) |
| Configures instruction register with a given command for QSPI. | |
| __STATIC_INLINE void | QSPI_SetInstFrame (Qspi *pQspi, QspiInstFrame_t *pInstFrame) |
| Configures instruction frame register of QSPI. | |
| __STATIC_INLINE uint32_t | QSPI_GetInstFrame (Qspi *pQspi) |
| Reads the Instruction frame of QSPI. | |
| __STATIC_INLINE uint16_t | QSPI_ReadSPI (Qspi *pQspi) |
| Read QSPI RDR register for SPI mode. | |
| __STATIC_INLINE void | QSPI_WriteSPI (Qspi *pQspi, uint16_t wData) |
| Write to QSPI Tx register in SPI mode. | |
| __STATIC_INLINE void | QSPI_ScrambleData (Qspi *pQspi, uint32_t wKey, uint8_t EnableFlag, uint8_t Random) |
| Configures QSPI scrambling with a given Key. | |
| void | QSPI_Enable (Qspi *pQspi) |
| Enables a QSPI peripheral. | |
| void | QSPI_Disable (Qspi *pQspi) |
| Disables a QSPI peripheral. | |
| void | QSPI_SwReset (Qspi *pQspi) |
| Resets a QSPI peripheral. | |
| QspidStatus_t | QSPI_EnableIt (Qspi *pQspi, uint32_t dwSources) |
| Enables one or more interrupt sources of a QSPI peripheral. | |
| QspidStatus_t | QSPI_DisableIt (Qspi *pQspi, uint32_t dwSources) |
| Disables one or more interrupt sources of a QSPI peripheral. | |
| uint32_t | QSPI_GetItMask (Qspi *pQspi) |
| Return the interrupt mask register. | |
| uint32_t | QSPI_GetEnabledItStatus (Qspi *pQspi) |
| Returns enabled interrupt status. | |
| uint32_t | QSPI_GetStatus (Qspi *pQspi, const QspiStatus_t rStatus) |
| Get the current status register of the given QSPI peripheral. | |
| void | QSPI_ConfigureClock (Qspi *pQspi, QspiClockMode_t ClockMode, uint32_t dwClockCfg) |
| Configures peripheral clock of a QSPI/SPI peripheral. | |
| QspidStatus_t | QSPI_ConfigureInterface (Qspid_t *pQspid, QspiMode_t Mode, uint32_t dwConfiguration) |
| Configures QSPI/SPI. | |
| QspidStatus_t | QSPI_EndTransfer (Qspi *pQspi) |
| Ends ongoing transfer by releasing CS of QSPI peripheral. | |
| QspidStatus_t | QSPI_SingleReadSPI (Qspid_t *pQspid, uint16_t *const pData) |
| Reads the data received by a SPI peripheral. This method must be called after a successful SPI_Write call. | |
| QspidStatus_t | QSPI_MultiReadSPI (Qspid_t *pQspid, uint16_t *const pData, uint32_t NumOfBytes) |
| Reads multiple data received by a SPI peripheral. This method must be called after a successful SPI_Write call. | |
| QspidStatus_t | QSPI_SingleWriteSPI (Qspid_t *pQspid, uint16_t const *pData) |
| Sends a single data through a SPI peripheral. | |
| QspidStatus_t | QSPI_MultiWriteSPI (Qspid_t *pQspid, uint16_t const *pData, uint32_t NumOfBytes) |
| Sends multiple data through a SPI peripheral. | |
| QspidStatus_t | QSPI_SendCommand (Qspid_t *pQspid, uint8_t const KeepCfg) |
| Send an instruction over QSPI (oly a flash command no data) | |
| QspidStatus_t | QSPI_SendCommandWithData (Qspid_t *pQspid, uint8_t const KeepCfg) |
| Send instruction over QSPI with data. | |
| QspidStatus_t | QSPI_ReadCommand (Qspid_t *pQspid, uint8_t const KeepCfg) |
| Send instruction over QSPI to read data. | |
| QspidStatus_t | QSPI_EnableMemAccess (Qspid_t *pQspid, uint8_t const KeepCfg, uint8_t ScrambleFlag) |
| Sends an instruction over QSPI and configures other related address like Addr , Frame and synchronise bus access before data read or write. | |
| QspidStatus_t | QSPI_ReadWriteMem (Qspid_t *pQspid, Access_t const ReadWrite) |
| Writes or reads the QSPI memory (0x80000000) to transmit or receive data from Flash memory. | |
Implementation of Serial Peripheral Interface (QSPI) controller.
| __STATIC_INLINE void QSPI_Configure | ( | Qspi * | pQspi, |
| uint32_t | dwConfiguration | ||
| pQspi | Pointer to a Qspi instance. |
| void QSPI_ConfigureClock | ( | Qspi * | pQspi, |
| QspiClockMode_t | ClockMode, | ||
| uint32_t | dwClockCfg | ||
| pQspi | Pointer to an Qspi instance. |
| dwConfiguration | Desired clock configuration. |
| QspidStatus_t QSPI_ConfigureInterface | ( | Qspid_t * | pQspid, |
| QspiMode_t | Mode, | ||
| Mode | Mode for QSPI or SPI |
| dwConfiguration | Config of SPI or QSPI mode |
| __STATIC_INLINE void QSPI_ConfigureMode | ( | Qspi * | pQspi, |
| uint8_t | dMode | ||
| void QSPI_Disable | ( | Qspi * | pQspi | ) |
| QspidStatus_t QSPI_DisableIt | ( | Qspi * | pQspi, |
| uint32_t | dwSources | ||
| sources | Bitwise OR of selected interrupt sources. |
| void QSPI_Enable | ( | Qspi * | pQspi | ) |
| QspidStatus_t QSPI_EnableIt | ( | Qspi * | pQspi, |
| QspidStatus_t QSPI_EnableMemAccess | ( | Qspid_t * | pQspid, |
| uint8_t const | KeepCfg, | ||
| uint8_t | ScrambleFlag | ||
| KeepCfg | To keep Instruction from value or resets to zero |
| ScrambleFlag | Enable or disable scramble on QSPI |
| QspidStatus_t QSPI_EndTransfer | ( | Qspi * | pQspi | ) |
| uint32_t QSPI_GetEnabledItStatus | ( | Qspi * | pQspi | ) |
| __STATIC_INLINE uint32_t QSPI_GetInstFrame | ( | Qspi * | pQspi | ) |
| uint32_t QSPI_GetItMask | ( | Qspi * | pQspi | ) |
| uint32_t QSPI_GetStatus | ( | Qspi * | pQspi, |
| const QspiStatus_t | rStatus | ||
| rStatus | Compare status with given status bit |
| QspidStatus_t QSPI_MultiReadSPI | ( | Qspid_t * | pQspid, |
| uint16_t *const | pData, | ||
| uint32_t | NumOfBytes | ||
| QspidStatus_t QSPI_MultiWriteSPI | ( | Qspid_t * | pQspid, |
| uint16_t const * | pData, | ||
| pQspid | Pointer to a Qspi instance. |
| pData | Pointer to a Tx buffer |
| NumOfBytes | Num of data to send. |
| QspidStatus_t QSPI_ReadCommand | ( | Qspid_t * | pQspid, |
| uint8_t const | KeepCfg | ||
| __STATIC_INLINE uint16_t QSPI_ReadSPI | ( | Qspi * | pQspi | ) |
| QspidStatus_t QSPI_ReadWriteMem | ( | Qspid_t * | pQspid, |
| Access_t const | ReadWrite | ||
| ReadWrite | Flag to indicate read/write QSPI memory access |
| __STATIC_INLINE void QSPI_ScrambleData | ( | Qspi * | pQspi, |
| uint32_t | wKey, | ||
| uint8_t | EnableFlag, | ||
| uint8_t | Random | ||
| wKey | Key for scramble/unscramble |
| EnableFlag | Enable/disable scramble |
| Random | Add random value with given key |
| QspidStatus_t QSPI_SendCommand | ( | Qspid_t * | pQspid, |
| KeepCfg | To keep Instruction fram value or restes to zero |
| QspidStatus_t QSPI_SendCommandWithData | ( | Qspid_t * | pQspid, |
| __STATIC_INLINE void QSPI_SetInst | ( | Qspi * | pQspi, |
| uint8_t | dwInst, | ||
| uint8_t | dwOpt | ||
| dwInst | Instruction Code |
| dwOpt | Instruction Code option |
| __STATIC_INLINE void QSPI_SetInstAddr | ( | Qspi * | pQspi, |
| uint32_t | dwAddr | ||
| dwAddr | Instruction Address |
| __STATIC_INLINE void QSPI_SetInstFrame | ( | Qspi * | pQspi, |
| QspiInstFrame_t * | pInstFrame | ||
| pInstFrame | Instruction Frame configuration |
| QspidStatus_t QSPI_SingleReadSPI | ( | Qspid_t * | pQspid, |
| uint16_t *const | pData | ||
| QspidStatus_t QSPI_SingleWriteSPI | ( | Qspid_t * | pQspid, |
| uint16_t const * | pData | ||
| void QSPI_SwReset | ( | Qspi * | pQspi | ) |
