RTEMS 6.1
VMEConfig.h File Reference
This header file provides the interfaces used by VME bus device drivers. More...
#define _VME_DRIVER_TSI148
#define PCI_MEM_BASE   0
#define PCI_DRAM_OFFSET   0
#define _VME_A32_WIN0_ON_PCI   (bsp_vme_pcie_base_address + 0x10000000)
#define _VME_A24_ON_PCI   (bsp_vme_pcie_base_address + 0x03000000)
#define _VME_A16_ON_PCI   (bsp_vme_pcie_base_address + 0x02000000)
#define _VME_CSR_ON_PCI   (bsp_vme_pcie_base_address + 0x01000000)
#define _VME_A32_WIN0_ON_VME   0x20000000
#define BSP_VME_INSTALL_IRQ_MGR(err)
int BSP_VMEInit (void)
int BSP_VMEIrqMgrInstall (void)
uintptr_t bsp_vme_pcie_base_address
unsigned short(* _BSP_clear_vmebridge_errors )(int)
Note that for the MVME2500, you need the PCIe support from libbsd for this to work.
◆ BSP_VME_INSTALL_IRQ_MGR
#define BSP_VME_INSTALL_IRQ_MGR (   err)
Value:
do { \
QORIQ_IRQ_EXT_0, \
QORIQ_EIRQ_TRIGGER_LEVEL_LOW, \
NULL \
if (err == 0) { \
err = vmeTsi148InstallIrqMgrAlt(0, 0, QORIQ_IRQ_EXT_0, -1); \
} while (0)
rtems_status_code qoriq_pic_set_sense_and_polarity(rtems_vector_number vector, qoriq_eirq_sense_and_polarity new_sense_and_polarity, qoriq_eirq_sense_and_polarity *old_sense_and_polarity)
Change polarity and sense settings of external interrupts.
Definition: irq.c:350
