RTEMS 6.1
psignalimpl.h File Reference
POSIX Signals Support. More...
#include <rtems/posix/psignal.h>
#include <rtems/posix/pthread.h>
#include <rtems/posix/sigset.h>
#include <rtems/score/isrlock.h>
#define POSIX_SIGNALS_TQ_OPERATIONS   &_Thread_queue_Operations_FIFO
#define _States_Is_interruptible_signal(_states)
#define SIGACTION_TERMINATE    { 0, SIGNAL_ALL_MASK, {_POSIX_signals_Abnormal_termination_handler} }
#define SIGACTION_IGNORE    { 0, SIGNAL_ALL_MASK, {SIG_IGN} }
#define SIGACTION_STOP    { 0, SIGNAL_ALL_MASK, {_POSIX_signals_Stop_handler} }
#define SIGACTION_CONTINUE    { 0, SIGNAL_ALL_MASK, {_POSIX_signals_Continue_handler} }
#define SIG_ARRAY_MAX   (SIGRTMAX + 1)
#define _POSIX_signals_Stop_handler   NULL
#define _POSIX_signals_Continue_handler   NULL
bool _POSIX_signals_Unblock_thread (Thread_Control *the_thread, int signo, siginfo_t *info)
 Unlock POSIX signals thread.
bool _POSIX_signals_Clear_signals (POSIX_API_Control *api, int signo, siginfo_t *info, bool is_global, bool check_blocked, bool do_signals_acquire_release)
 Clear POSIX signals.
int _POSIX_signals_Send (pid_t pid, int sig, const union sigval *value)
void _POSIX_signals_Set_process_signals (sigset_t mask)
 Set POSIX process signals.
void _POSIX_signals_Clear_process_signals (int signo)
void _POSIX_signals_Abnormal_termination_handler (int signo)
sigset_t _POSIX_signals_Pending
const struct sigaction _POSIX_signals_Default_vectors [SIG_ARRAY_MAX]
struct sigaction _POSIX_signals_Vectors [SIG_ARRAY_MAX]
Thread_queue_Control _POSIX_signals_Wait_queue
Chain_Control _POSIX_signals_Inactive_siginfo
Chain_Control _POSIX_signals_Siginfo [SIG_ARRAY_MAX]
This include file defines internal information about POSIX signals.
