RTEMS 6.1
psignal.h
2
11/*
12 * COPYRIGHT (c) 1989-2011.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_POSIX_PSIGNAL_H
38#define _RTEMS_POSIX_PSIGNAL_H
39
40#include <sys/signal.h>
41
42#include <rtems/score/chain.h>
43
44/*
45 * POSIX internal siginfo structure
46 */
47
48typedef struct {
49 Chain_Node Node;
50 siginfo_t Info;
52
53extern const uint32_t _POSIX_signals_Maximum_queued_signals;
54
55extern POSIX_signals_Siginfo_node _POSIX_signals_Siginfo_nodes[];
56
57#endif
58/* end of file */
This header file provides interfaces of the Chain Handler which are used by the implementation and th...
This structure represents a chain node.
Definition: chain.h:78
Definition: psignal.h:48
