RTEMS 6.1
Enhanced Direct Memory Access (eDMA). More...
| struct | edma_channel_context |
Typedefs | |
| typedef struct edma_channel_context | edma_channel_context |
| void | mpc55xx_edma_init (void) |
| rtems_status_code | mpc55xx_edma_obtain_channel_by_tcd (volatile struct tcd_t *edma_tcd) |
| Obtains an eDMA channel. | |
| void | mpc55xx_edma_release_channel_by_tcd (volatile struct tcd_t *edma_tcd) |
| rtems_status_code | mpc55xx_edma_obtain_channel (edma_channel_context *ctx, unsigned irq_priority) |
| Obtains an eDMA channel and registers the channel context. | |
| void | mpc55xx_edma_release_channel (edma_channel_context *ctx) |
| void | mpc55xx_edma_copy (volatile struct tcd_t *edma_tcd, const struct tcd_t *source_tcd) |
| Copies a source TCD to an eDMA TCD. | |
| void | mpc55xx_edma_copy_and_enable_hardware_requests (volatile struct tcd_t *edma_tcd, const struct tcd_t *source_tcd) |
| Copies a source TCD to an eDMA TCD and enables hardware requests. | |
| void | mpc55xx_edma_sg_link (volatile struct tcd_t *edma_tcd, const struct tcd_t *source_tcd) |
| void mpc55xx_edma_copy | ( | volatile struct tcd_t * | edma_tcd, |
| const struct tcd_t * | source_tcd | ||
The DONE flag of the eDMA TCD is cleared before the actual copy operation. This enables the setting of channel link or scatter/gather options.
This function can be used to start the channel if the START flags is set in the source TCD.
| void mpc55xx_edma_copy_and_enable_hardware_requests | ( | volatile struct tcd_t * | edma_tcd, |
| rtems_status_code mpc55xx_edma_obtain_channel | ( | edma_channel_context * | ctx, |
| unsigned | irq_priority | ||
The done handler of the channel context will be called
An error status value not equal to zero indicates an error.
| RTEMS_SUCCESSFUL | Successful operation. |
| RTEMS_RESOURCE_IN_USE | The channel is already in use. |
| RTEMS_IO_ERROR | Unable to install interrupt handler for this channel. |
| rtems_status_code mpc55xx_edma_obtain_channel_by_tcd | ( | volatile struct tcd_t * | edma_tcd | ) |
