RTEMS 6.1
Macros | Variables
registers.h File Reference
#include <stdint.h>
#define MSR_CM   (1<<31) /* Computation mode */
#define MSR_GS   (1<<28) /* Guest state */
#define MSR_UCLE   (1<<26) /* User-mode cache lock enable (e500) */
#define MSR_VE   (1<<25) /* Alti-Vec enable (7400+) */
#define MSR_SPE   (1<<25) /* SPE enable (e500) */
#define MSR_AP   (1<<25) /* Auxiliary processor available */
#define MSR_APE   (1<<19) /* APU exception enable */
#define MSR_POW   (1<<18) /* Enable Power Management */
#define MSR_WE   (1<<18) /* Wait state enable (e500, 4xx) */
#define MSR_TGPR   (1<<17) /* TLB Update registers in use */
#define MSR_CE   (1<<17) /* BookE critical interrupt */
#define MSR_ILE   (1<<16) /* Interrupt Little-Endian enable */
#define MSR_EE   (1<<15) /* External Interrupt enable */
#define MSR_PR   (1<<14) /* Supervisor/User privilege */
#define MSR_FP   (1<<13) /* Floating Point enable */
#define MSR_ME   (1<<12) /* Machine Check enable */
#define MSR_FE0   (1<<11) /* Floating Exception mode 0 */
#define MSR_SE   (1<<10) /* Single Step */
#define MSR_UBLE   (1<<10) /* User-mode BTB lock enable (e500) */
#define MSR_DWE   (1<<10) /* Debug wait enable (4xx) */
#define MSR_BE   (1<<9) /* Branch Trace */
#define MSR_DE   (1<<9) /* BookE debug exception */
#define MSR_FE1   (1<<8) /* Floating Exception mode 1 */
#define MSR_E300_CE   (1<<7) /* e300 critical interrupt */
#define MSR_IP   (1<<6) /* Exception prefix 0x000/0xFFF */
#define MSR_IR   (1<<5) /* Instruction MMU enable */
#define MSR_DR   (1<<4) /* Data MMU enable */
#define MSR_IS   (1<<5) /* Instruction address space */
#define MSR_DS   (1<<4) /* Data address space */
#define MSR_PMM   (1<<2) /* Performance monitor mark */
#define MSR_RI   (1<<1) /* Recoverable Exception */
#define MSR_LE   (1<<0) /* Little-Endian enable */
#define HID0_EMCP   (1<<31) /* Enable Machine Check pin */
#define HID0_EBA   (1<<29) /* Enable Bus Address Parity */
#define HID0_EBD   (1<<28) /* Enable Bus Data Parity */
#define HID0_SBCLK   (1<<27)
#define HID0_TBEN
#define HID0_EICE   (1<<26)
#define HID0_ECLK   (1<<25)
#define HID0_PAR   (1<<24)
#define HID0_DOZE   (1<<23)
#define HID0_7455_HIGH_BAT_EN   (1<<23)
#define HID0_NAP   (1<<22)
#define HID0_SLEEP   (1<<21)
#define HID0_DPM   (1<<20)
#define HID0_ICE   (1<<15) /* Instruction Cache Enable */
#define HID0_DCE   (1<<14) /* Data Cache Enable */
#define HID0_ILOCK   (1<<13) /* Instruction Cache Lock */
#define HID0_DLOCK   (1<<12) /* Data Cache Lock */
#define HID0_ICFI   (1<<11) /* Instruction Cache Flash Invalidate */
#define HID0_DCI   (1<<10) /* Data Cache Invalidate */
#define HID0_7455_XBSEN   (1<<8)
#define HID0_SIED   (1<<7) /* Serial Instruction Execution [Disable] */
#define HID0_BTIC   (1<<5) /* Branch Target Instruction Cache [Enable] */
#define HID0_LRSTK   (1<<4) /* Link register stack enable (7455) */
#define HID0_FOLD   (1<<3) /* Branch folding enable (7455) */
#define HID0_BHTE   (1<<2) /* Branch History Table Enable */
#define HID0_BTCD   (1<<1) /* Branch target cache disable */
#define FPSCR_FX   (1<<31)
#define FPSCR_FEX   (1<<30)
#define _MACH_prep   1
#define _MACH_Pmac   2 /* pmac or pmac clone (non-chrp) */
#define _MACH_chrp   4 /* chrp machine */
#define _MACH_mbx   8 /* Motorola MBX board */
#define _MACH_apus   16 /* amiga with phase5 powerup */
#define _MACH_fads   32 /* Motorola FADS board */
#define _PREP_Motorola   0x01 /* motorola prep */
#define _PREP_Firm   0x02 /* firmworks prep */
#define _PREP_IBM   0x00 /* ibm prep */
#define _PREP_Bull   0x03 /* bull prep */
#define _CHRP_Motorola   0x04 /* motorola chrp, the cobra */
#define _CHRP_IBM   0x05 /* IBM chrp, the longtrail and longtrail 2 */
#define _GLOBAL(n)
#define TBRU   269 /* Time base Upper/Lower (Reading) */
#define TBRL   268
#define TBWU   285 /* Time base Upper/Lower (Writing) */
#define TBWL   284
#define PPC_XER   1
#define PPC_LR   8
#define PPC_CTR   9
#define HID0   1008 /* Hardware Implementation 0 */
#define HID1   1009 /* Hardware Implementation 1 */
#define HID2   1011 /* Hardware Implementation 2 */
#define DABR   1013 /* Data Access Breakpoint */
#define PPC_PVR   287 /* Processor Version */
#define IBAT0U   528 /* Instruction BAT #0 Upper/Lower */
#define IBAT0L   529
#define IBAT1U   530 /* Instruction BAT #1 Upper/Lower */
#define IBAT1L   531
#define IBAT2U   532 /* Instruction BAT #2 Upper/Lower */
#define IBAT2L   533
#define IBAT3U   534 /* Instruction BAT #3 Upper/Lower */
#define IBAT3L   535
#define IBAT4U   560 /* Instruction BAT #4 Upper/Lower */
#define IBAT4L   561
#define IBAT5U   562 /* Instruction BAT #5 Upper/Lower */
#define IBAT5L   563
#define IBAT6U   564 /* Instruction BAT #6 Upper/Lower */
#define IBAT6L   565
#define IBAT7U   566 /* Instruction BAT #7 Upper/Lower */
#define IBAT7L   567
#define DBAT0U   536 /* Data BAT #0 Upper/Lower */
#define DBAT0L   537
#define DBAT1U   538 /* Data BAT #1 Upper/Lower */
#define DBAT1L   539
#define DBAT2U   540 /* Data BAT #2 Upper/Lower */
#define DBAT2L   541
#define DBAT3U   542 /* Data BAT #3 Upper/Lower */
#define DBAT3L   543
#define DBAT4U   568 /* Instruction BAT #4 Upper/Lower */
#define DBAT4L   569
#define DBAT5U   570 /* Instruction BAT #5 Upper/Lower */
#define DBAT5L   571
#define DBAT6U   572 /* Instruction BAT #6 Upper/Lower */
#define DBAT6L   573
#define DBAT7U   574 /* Instruction BAT #7 Upper/Lower */
#define DBAT7L   575
#define DMISS   976 /* TLB Lookup/Refresh registers */
#define DCMP   977
#define HASH1   978
#define HASH2   979
#define IMISS   980
#define ICMP   981
#define PPC_RPA   982
#define SDR1   25 /* MMU hash base register */
#define PPC_DAR   19 /* Data Address Register */
#define DEAR_BOOKE   61
#define DEAR_405   981
#define SPR0   272 /* Supervisor Private Registers */
#define SPRG0   272
#define SPR1   273
#define SPRG1   273
#define SPR2   274
#define SPRG2   274
#define SPR3   275
#define SPRG3   275
#define SPRG4   276
#define SPRG5   277
#define SPRG6   278
#define SPRG7   279
#define USPRG0   256
#define DSISR   18
#define SRR0   26 /* Saved Registers (exception) */
#define SRR1   27
#define IABR   1010 /* Instruction Address Breakpoint */
#define PPC_DEC   22 /* Decrementer */
#define PPC_EAR   282 /* External Address Register */
#define MSSCR0   1014 /* Memory Subsystem Control Register */
#define L2CR   1017 /* PPC 750 and 74xx L2 control register */
#define L2CR_L2E   (1<<31) /* enable */
#define L2CR_L2I   (1<<21) /* global invalidate */
#define L2CR_L2IO_745x   0x100000 /* (1<<20) L2 Instruction-Only */
#define L2CR_L2DO_745x   0x10000 /* (1<<16) L2 Data-Only */
#define L2CR_LOCK_745x   (L2CR_L2IO_745x|L2CR_L2DO_745x)
#define L2CR_L3OH0   0x00080000 /* 12:L3 output hold 0 */
#define L3CR   1018 /* PPC 7450/7455 L3 control register */
#define L3CR_L3IO_745x   0x400000 /* (1<<22) L3 Instruction-Only */
#define L3CR_L3DO_745x   0x40 /* (1<<6) L3 Data-Only */
#define L3CR_LOCK_745x   (L3CR_L3IO_745x|L3CR_L3DO_745x)
#define L3CR_RESERVED   0x0438003a /* Reserved bits in L3CR */
#define L3CR_L3E   0x80000000 /* 0: L3 enable */
#define L3CR_L3PE   0x40000000 /* 1: L3 data parity checking enable */
#define L3CR_L3APE   0x20000000 /* 2: L3 address parity checking enable */
#define L3CR_L3SIZ   0x10000000 /* 3: L3 size (0=1MB, 1=2MB) */
#define L3SIZ_1M   0x00000000
#define L3SIZ_2M   0x10000000
#define L3CR_L3CLKEN   0x08000000 /* 4: Enables the L3_CLK[0:1] signals */
#define L3CR_L3CLK   0x03800000 /* 6-8: L3 clock ratio */
#define L3CLK_60   0x00000000 /* core clock / 6 */
#define L3CLK_20   0x01000000 /* / 2 */
#define L3CLK_25   0x01800000 /* / 2.5 */
#define L3CLK_30   0x02000000 /* / 3 */
#define L3CLK_35   0x02800000 /* / 3.5 */
#define L3CLK_40   0x03000000 /* / 4 */
#define L3CLK_50   0x03800000 /* / 5 */
#define L3CR_L3IO   0x00400000 /* 9: L3 instruction-only mode */
#define L3CR_L3SPO   0x00040000 /* 13: L3 sample point override */
#define L3CR_L3CKSP   0x00030000 /* 14-15: L3 clock sample point */
#define L3CKSP_2   0x00000000 /* 2 clocks */
#define L3CKSP_3   0x00010000 /* 3 clocks */
#define L3CKSP_4   0x00020000 /* 4 clocks */
#define L3CKSP_5   0x00030000 /* 5 clocks */
#define L3CR_L3PSP   0x0000e000 /* 16-18: L3 P-clock sample point */
#define L3PSP_0   0x00000000 /* 0 clocks */
#define L3PSP_1   0x00002000 /* 1 clocks */
#define L3PSP_2   0x00004000 /* 2 clocks */
#define L3PSP_3   0x00006000 /* 3 clocks */
#define L3PSP_4   0x00008000 /* 4 clocks */
#define L3PSP_5   0x0000a000 /* 5 clocks */
#define L3CR_L3REP   0x00001000 /* 19: L3 replacement algorithm (0=default, 1=alternate) */
#define L3CR_L3HWF   0x00000800 /* 20: L3 hardware flush */
#define L3CR_L3I
#define L3CR_L3RT   0x00000300 /* 22-23: L3 SRAM type */
#define L3RT_MSUG2_DDR   0x00000000 /* MSUG2 DDR SRAM */
#define L3RT_PIPELINE_LATE   0x00000100 /* Pipelined (register-register) synchronous late-write SRAM */
#define L3RT_PB2_SRAM   0x00000300 /* PB2 SRAM */
#define L3CR_L3NIRCA   0x00000080 /* 24: L3 non-integer ratios clock adjustment for the SRAM */
#define L3CR_L3DO   0x00000040 /* 25: L3 data-only mode */
#define L3CR_PMEN   0x00000004 /* 29: Private memory enable */
#define L3CR_PMSIZ   0x00000004 /* 31: Private memory size (0=1MB, 1=2MB) */
#define THRM1   1020
#define THRM2   1021
#define THRM3   1022
#define THRM1_TIN   (1<<(31-0))
#define THRM1_TIV   (1<<(31-1))
#define THRM1_THRES   (0x7f<<(31-8))
#define THRM1_TID   (1<<(31-29))
#define THRM1_TIE   (1<<(31-30))
#define THRM1_V   (1<<(31-31))
#define THRM3_SITV   (0x1fff << (31-30))
#define THRM3_E   (1<<(31-31))
#define PPC_SR0   0
#define PPC_SR1   1
#define PPC_SR2   2
#define PPC_SR3   3
#define PPC_SR4   4
#define PPC_SR5   5
#define PPC_SR6   6
#define PPC_SR7   7
#define PPC_SR8   8
#define PPC_SR9   9
#define PPC_SR10   10
#define PPC_SR11   11
#define PPC_SR12   12
#define PPC_SR13   13
#define PPC_SR14   14
#define PPC_SR15   15
#define BOOKE_DECAR   54
#define PPC405_MCSR   0x23C
#define PPC405_ESR   0x3D4
#define PPC405_DEAR   0x3D5
#define BOOKE_DEAR   61
#define PPC405_TSR   0x3D8
#define BOOKE_TSR   336
#define BOOKE_TSR_ENW   (1<<31)
#define BOOKE_TSR_WIS   (1<<30)
#define BOOKE_TSR_DIS   (1<<27)
#define BOOKE_TSR_FIS   (1<<26)
#define PPC405_TCR   0x3DA
#define BOOKE_TCR   340
#define BOOKE_TCR_WP(x)   (((x)&3)<<30)
#define BOOKE_TCR_WP_MASK   (3<<30)
#define BOOKE_TCR_WRC(x)   (((x)&3)<<28)
#define BOOKE_TCR_WRC_MASK   (3<<28)
#define BOOKE_TCR_WIE   (1<<27)
#define BOOKE_TCR_DIE   (1<<26)
#define BOOKE_TCR_FP(x)   (((x)&3)<<24)
#define BOOKE_TCR_FIE   (1<<23)
#define BOOKE_TCR_ARE   (1<<22)
#define BOOKE_TCR_WPEXT(x)   (((x)&0xf)<<17)
#define BOOKE_TCR_WPEXT_MASK   (0xf<<17)
#define BOOKE_TCR_FPEXT(x)   (((x)&0xf)<<13)
#define BOOKE_TCR_FPEXT_MASK   (0xf<<13)
#define BOOKE_PID   48 /* Process ID */
#define BOOKE_CSRR0   58 /* Critical Save/Restore Register 0 */
#define BOOKE_CSRR1   59 /* Critical Save/Restore Register 1 */
#define BOOKE_ESR   62 /* Exception Syndrome Register */
#define BOOKE_IVPR   63 /* Interrupt Vector Prefix Register */
#define BOOKE_SPRG4_W   260 /* Special Purpose Register General 4 (WO) */
#define BOOKE_SPRG5_W   261 /* Special Purpose Register General 5 (WO) */
#define BOOKE_SPRG6_W   262 /* Special Purpose Register General 6 (WO) */
#define BOOKE_SPRG7_W   263 /* Special Purpose Register General 7 (WO) */
#define BOOKE_PIR   286 /* Processor ID Register */
#define BOOKE_DBSR   304 /* Debug Status Register */
#define BOOKE_EPCR   307 /* Embedded Processor Control Register */
#define BOOKE_EPCR_EXTGS   (1 << 31)
#define BOOKE_EPCR_DTLBGS   (1 << 30)
#define BOOKE_EPCR_ITLBGS   (1 << 29)
#define BOOKE_EPCR_DSIGS   (1 << 28)
#define BOOKE_EPCR_ISIGS   (1 << 27)
#define BOOKE_EPCR_DUVD   (1 << 26)
#define BOOKE_EPCR_ICM   (1 << 25)
#define BOOKE_EPCR_GICM   (1 << 24)
#define BOOKE_EPCR_DGTMI   (1 << 23)
#define BOOKE_EPCR_DMIUH   (1 << 22)
#define BOOKE_EPCR_PMGS   (1 << 21)
#define BOOKE_DBCR0   308 /* Debug Control Register 0 */
#define BOOKE_DBCR1   309 /* Debug Control Register 1 */
#define BOOKE_DBCR2   310 /* Debug Control Register 2 */
#define BOOKE_IAC1   312 /* Instruction Address Compare 1 */
#define BOOKE_IAC2   313 /* Instruction Address Compare 2 */
#define BOOKE_IAC3   314 /* Instruction Address Compare 3 */
#define BOOKE_IAC4   315 /* Instruction Address Compare 4 */
#define BOOKE_DAC1   316 /* Data Address Compare 1 */
#define BOOKE_DAC2   317 /* Data Address Compare 2 */
#define BOOKE_DVC1   318 /* Data Value Compare 1 */
#define BOOKE_DVC2   319 /* Data Value Compare 2 */
#define BOOKE_GSRR0   378 /* Guest Save/Restore Register 0 */
#define BOOKE_GSRR1   379 /* Guest Save/Restore Register 1 */
#define BOOKE_GEPR   380 /* Guest External Proxy Register */
#define BOOKE_GDEAR   381 /* Guest Data Exception Address Register */
#define BOOKE_GPIR   382 /* Guest Processor ID Register */
#define BOOKE_GESR   383 /* Guest Exception Syndrome Register */
#define BOOKE_IVOR0   400 /* Interrupt Vector Offset Register 0 */
#define BOOKE_IVOR1   401 /* Interrupt Vector Offset Register 1 */
#define BOOKE_IVOR2   402 /* Interrupt Vector Offset Register 2 */
#define BOOKE_IVOR3   403 /* Interrupt Vector Offset Register 3 */
#define BOOKE_IVOR4   404 /* Interrupt Vector Offset Register 4 */
#define BOOKE_IVOR5   405 /* Interrupt Vector Offset Register 5 */
#define BOOKE_IVOR6   406 /* Interrupt Vector Offset Register 6 */
#define BOOKE_IVOR7   407 /* Interrupt Vector Offset Register 7 */
#define BOOKE_IVOR8   408 /* Interrupt Vector Offset Register 8 */
#define BOOKE_IVOR9   409 /* Interrupt Vector Offset Register 9 */
#define BOOKE_IVOR10   410 /* Interrupt Vector Offset Register 10 */
#define BOOKE_IVOR11   411 /* Interrupt Vector Offset Register 11 */
#define BOOKE_IVOR12   412 /* Interrupt Vector Offset Register 12 */
#define BOOKE_IVOR13   413 /* Interrupt Vector Offset Register 13 */
#define BOOKE_IVOR14   414 /* Interrupt Vector Offset Register 14 */
#define BOOKE_IVOR15   415 /* Interrupt Vector Offset Register 15 */
#define BOOKE_IVOR42   436 /* Interrupt Vector Offset Register 42 */
#define BOOKE_IVOR32   528 /* Interrupt Vector Offset Register 32 */
#define BOOKE_IVOR33   529 /* Interrupt Vector Offset Register 33 */
#define BOOKE_IVOR34   530 /* Interrupt Vector Offset Register 34 */
#define BOOKE_IVOR35   531 /* Interrupt Vector Offset Register 35 */
#define BOOKE_IVOR36   532 /* Interrupt Vector Offset Register 36 */
#define BOOKE_IVOR37   533 /* Interrupt Vector Offset Register 37 */
#define BOOKE_IVOR38   432 /* Interrupt Vector Offset Register 38 */
#define BOOKE_IVOR39   433 /* Interrupt Vector Offset Register 39 */
#define BOOKE_IVOR40   434 /* Interrupt Vector Offset Register 40 */
#define BOOKE_IVOR41   435 /* Interrupt Vector Offset Register 41 */
#define BOOKE_GIVOR2   440 /* Guest Interrupt Vector Offset Register 2 */
#define BOOKE_GIVOR3   441 /* Guest Interrupt Vector Offset Register 3 */
#define BOOKE_GIVOR4   442 /* Guest Interrupt Vector Offset Register 4 */
#define BOOKE_GIVOR8   443 /* Guest Interrupt Vector Offset Register 8 */
#define BOOKE_GIVOR13   444 /* Guest Interrupt Vector Offset Register 13 */
#define BOOKE_GIVOR14   445 /* Guest Interrupt Vector Offset Register 14 */
#define BOOKE_GIVPR   446 /* Guest Interrupt Vector Prefix Register */
#define BOOKE_MCSRR0   570 /* Machine Check Save/Restore Register 0 */
#define BOOKE_MCSRR1   571 /* Machine Check Save/Restore Register 1 */
#define BOOKE_MCSR   572 /* Machine Check Status Register */
#define BOOKE_DSRR0   574 /* Debug Save/Restore Register 0 */
#define BOOKE_DSRR1   575 /* Debug Save/Restore Register 1 */
#define PPC440_INV0   880 /* Instruction Cache Normal Victim 0 */
#define PPC440_INV1   881 /* Instruction Cache Normal Victim 1 */
#define PPC440_INV2   882 /* Instruction Cache Normal Victim 2 */
#define PPC440_INV3   883 /* Instruction Cache Normal Victim 3 */
#define PPC440_ITV0   884 /* Instruction Cache Transient Victim 0 */
#define PPC440_ITV1   885 /* Instruction Cache Transient Victim 1 */
#define PPC440_ITV2   886 /* Instruction Cache Transient Victim 2 */
#define PPC440_ITV3   887 /* Instruction Cache Transient Victim 3 */
#define PPC440_CCR1   888 /* Core Configuration Register 1 */
#define PPC440_DNV0   912 /* Data Cache Normal Victim 0 */
#define PPC440_DNV1   913 /* Data Cache Normal Victim 1 */
#define PPC440_DNV2   914 /* Data Cache Normal Victim 2 */
#define PPC440_DNV3   915 /* Data Cache Normal Victim 3 */
#define PPC440_DTV0   916 /* Data Cache Transient Victim 0 */
#define PPC440_DTV1   917 /* Data Cache Transient Victim 1 */
#define PPC440_DTV2   918 /* Data Cache Transient Victim 2 */
#define PPC440_DTV3   919 /* Data Cache Transient Victim 3 */
#define PPC440_DVLIM   920 /* Data Cache Victim Limit */
#define PPC440_IVLIM   921 /* Instruction Cache Victim Limit */
#define PPC440_RSTCFG   923 /* Reset Configuration */
#define PPC440_DCDBTRL   924 /* Data Cache Debug Tag Register Low */
#define PPC440_DCDBTRH   925 /* Data Cache Debug Tag Register High */
#define PPC440_ICDBTRL   926 /* Instruction Cache Debug Tag Register Low */
#define PPC440_ICDBTRH   927 /* Instruction Cache Debug Tag Register High */
#define PPC440_MMUCR   946 /* Memory Management Unit Control Register */
#define PPC440_CCR0   947 /* Core Configuration Register 0 */
#define PPC440_ICDBDR   979 /* Instruction Cache Debug Data Register */
#define PPC440_DBDR   1011 /* Debug Data Register */
#define PPC440_TLB0_EPN(n)   ( (((1<<22)-1)&(n)) << (31-21)) /* Etended Page Number */
#define PPC440_TLB0_EPN_GET(n)   ( ((n) >> (31-21)) & ((1<<22)-1))
#define PPC440_TLB0_V   ( 1 << (31-22)) /* Entry valid */
#define PPC440_TLB0_TS   ( 1 << (31-23)) /* Translation space */
#define PPC440_TLB0_TSIZE(n)   ( (0xf & (n)) << (31-27)) /* Page size */
#define PPC440_TLB0_TSIZE_GET(n)   ( ((n) >> (31-27)) & 0xf)
#define PPC440_TLB0_TPAR(n)   ( (0xf & (n)) << (31-31)) /* Tag Parity */
#define PPC440_TLB0_TPAR_GET(n)   ( ((n) >> (31-31)) & 0xf)
#define PPC440_PID_TID(n)   ( (0xff & (n)) << (31-31)) /* Translation ID */
#define PPC440_PID_TID_GET(n)   ( ((n) >> (31-31)) & 0xff)
#define PPC440_TLB1_RPN(n)   ( (((1<<22)-1)&(n)) << (31-21)) /* Real Page Number */
#define PPC440_TLB1_RPN_GET(n)   ( ((n) >> (31-21)) & ((1<<22)-1))
#define PPC440_TLB1_PAR1(n)   ( (0x3 & (n)) << (31-23)) /* Parity for TLB word 1 */
#define PPC440_TLB1_PAR1_GET(n)   ( ((n) >> (31-23)) & 0x3)
#define PPC440_TLB1_ERPN(n)   ( (0xf & (n)) << (31-31)) /* Extended Real Page No. */
#define PPC440_TLB1_ERPN_GET(n)   ( ((n) >> (31-31)) & 0xf)
#define PPC440_TLB2_PAR2(n)   ( (0x3 & (n)) << (31- 1)) /* Parity for TLB word 2 */
#define PPC440_TLB2_PAR2_GET(n)   ( ((n) >> (31- 1)) & 0x3)
#define PPC440_TLB2_U0   ( 1 << (31-16)) /* User attr. 0 */
#define PPC440_TLB2_U1   ( 1 << (31-17)) /* User attr. 1 */
#define PPC440_TLB2_U2   ( 1 << (31-18)) /* User attr. 2 */
#define PPC440_TLB2_U3   ( 1 << (31-19)) /* User attr. 3 */
#define PPC440_TLB2_W   ( 1 << (31-20)) /* Write-through */
#define PPC440_TLB2_I   ( 1 << (31-21)) /* Cache-inhibited */
#define PPC440_TLB2_M   ( 1 << (31-22)) /* Memory-coherence req. */
#define PPC440_TLB2_G   ( 1 << (31-23)) /* Guarded */
#define PPC440_TLB2_E   ( 1 << (31-24)) /* Little-endian */
#define PPC440_TLB2_UX   ( 1 << (31-26)) /* User exec. */
#define PPC440_TLB2_UW   ( 1 << (31-27)) /* User write */
#define PPC440_TLB2_UR   ( 1 << (31-28)) /* User read */
#define PPC440_TLB2_SX   ( 1 << (31-29)) /* Super exec. */
#define PPC440_TLB2_SW   ( 1 << (31-30)) /* Super write */
#define PPC440_TLB2_SR   ( 1 << (31-31)) /* Super read */
#define PPC440_TLB2_ATTR(x)   ( ((x) & 0x1ff) << 7 )
#define PPC440_TLB2_ATTR_GET(x)   ( ((x) >> 7) & 0x1ff )
#define PPC440_TLB2_PERM(n)   ( (n) & 0x3f )
#define PPC440_TLB2_PERM_GET(n)   ( (n) & 0x3f )
#define FSL_EIS_BUCSR   1013
#define FSL_EIS_BUCSR_STAC_EN   (1 << (63 - 39))
#define FSL_EIS_BUCSR_LS_EN   (1 << (63 - 41))
#define FSL_EIS_BUCSR_BBFI   (1 << (63 - 54))
#define FSL_EIS_BUCSR_BALLOC_ALL   (0x0 << (63 - 59))
#define FSL_EIS_BUCSR_BALLOC_FORWARD   (0x1 << (63 - 59))
#define FSL_EIS_BUCSR_BALLOC_BACKWARD   (0x2 << (63 - 59))
#define FSL_EIS_BUCSR_BALLOC_NONE   (0x3 << (63 - 59))
#define FSL_EIS_BUCSR_BPRED_TAKEN   (0x0 << (63 - 61))
#define FSL_EIS_BUCSR_BPRED_TAKEN_ONLY_FORWARD   (0x1 << (63 - 62))
#define FSL_EIS_BUCSR_BPRED_TAKEN_ONLY_BACKWARD   (0x2 << (63 - 62))
#define FSL_EIS_BUCSR_BPRED_NOT_TAKEN   (0x3 << (63 - 62))
#define FSL_EIS_BUCSR_BPEN   (1 << (63 - 63))
#define FSL_EIS_SVR   1023
#define FSL_EIS_TENSR   437
#define FSL_EIS_TENS   438
#define FSL_EIS_TENC   439
#define FSL_EIS_PPR32   898
#define FSL_EIS_MAS0   624
#define FSL_EIS_MAS0_TLBSEL   (1 << (63 - 35))
#define FSL_EIS_MAS0_ESEL(n)   ((0xfff & (n)) << (63 - 47))
#define FSL_EIS_MAS0_ESEL_GET(m)   (((m) >> (63 - 47)) & 0xfff)
#define FSL_EIS_MAS0_NV   (1 << (63 - 63))
#define FSL_EIS_MAS1   625
#define FSL_EIS_MAS1_V   (1 << (63 - 32))
#define FSL_EIS_MAS1_IPROT   (1 << (63 - 33))
#define FSL_EIS_MAS1_TID(n)   ((0xff & (n)) << (63 - 47))
#define FSL_EIS_MAS1_TID_GET(n)   (((n) >> (63 - 47)) & 0xfff)
#define FSL_EIS_MAS1_TS   (1 << (63 - 51))
#define FSL_EIS_MAS1_TSIZE(n)   ((0xf & (n)) << (63 - 55))
#define FSL_EIS_MAS1_TSIZE_GET(n)   (((n)>>(63 - 55)) & 0xf)
#define FSL_EIS_MAS2   626
#define FSL_EIS_MAS2_EPN(n)   ((((1 << 21) - 1)&(n)) << (63-51))
#define FSL_EIS_MAS2_EPN_GET(n)   (((n) >> (63 - 51)) & 0xfffff)
#define FSL_EIS_MAS2_EA(n)   FSL_EIS_MAS2_EPN((n) >> 12)
#define FSL_EIS_MAS2_EA_GET(n)   (FSL_EIS_MAS2_EPN_GET(n) << 12)
#define FSL_EIS_MAS2_X0   (1 << (63 - 57))
#define FSL_EIS_MAS2_X1   (1 << (63 - 58))
#define FSL_EIS_MAS2_W   (1 << (63 - 59))
#define FSL_EIS_MAS2_I   (1 << (63 - 60))
#define FSL_EIS_MAS2_M   (1 << (63 - 61))
#define FSL_EIS_MAS2_G   (1 << (63 - 62))
#define FSL_EIS_MAS2_E   (1 << (63 - 63))
#define FSL_EIS_MAS2_ATTR(x)   ((x) & 0x7f)
#define FSL_EIS_MAS2_ATTR_GET(x)   ((x) & 0x7f)
#define FSL_EIS_MAS3   627
#define FSL_EIS_MAS3_RPN(n)   ((((1 << 21) - 1) & (n)) << (63-51))
#define FSL_EIS_MAS3_RPN_GET(n)   (((n)>>(63 - 51)) & 0xfffff)
#define FSL_EIS_MAS3_RA(n)   FSL_EIS_MAS3_RPN((n) >> 12)
#define FSL_EIS_MAS3_RA_GET(n)   (FSL_EIS_MAS3_RPN_GET(n) << 12)
#define FSL_EIS_MAS3_U0   (1 << (63 - 54))
#define FSL_EIS_MAS3_U1   (1 << (63 - 55))
#define FSL_EIS_MAS3_U2   (1 << (63 - 56))
#define FSL_EIS_MAS3_U3   (1 << (63 - 57))
#define FSL_EIS_MAS3_UX   (1 << (63 - 58))
#define FSL_EIS_MAS3_SX   (1 << (63 - 59))
#define FSL_EIS_MAS3_UW   (1 << (63 - 60))
#define FSL_EIS_MAS3_SW   (1 << (63 - 61))
#define FSL_EIS_MAS3_UR   (1 << (63 - 62))
#define FSL_EIS_MAS3_SR   (1 << (63 - 63))
#define FSL_EIS_MAS3_PERM(n)   ((n) & 0x3ff)
#define FSL_EIS_MAS3_PERM_GET(n)   ((n) & 0x3ff)
#define FSL_EIS_MAS4   628
#define FSL_EIS_MAS4_TLBSELD   (1 << (63 - 35))
#define FSL_EIS_MAS4_TIDSELD(n)   ((0x3 & (n)) << (63 - 47))
#define FSL_EIS_MAS4_TSIZED(n)   ((0xf & (n)) << (63 - 55))
#define FSL_EIS_MAS4_X0D   FSL_EIS_MAS2_X0
#define FSL_EIS_MAS4_X1D   FSL_EIS_MAS2_X1
#define FSL_EIS_MAS4_WD   FSL_EIS_MAS2_W
#define FSL_EIS_MAS4_ID   FSL_EIS_MAS2_I
#define FSL_EIS_MAS4_MD   FSL_EIS_MAS2_M
#define FSL_EIS_MAS4_GD   FSL_EIS_MAS2_G
#define FSL_EIS_MAS4_ED   FSL_EIS_MAS2_E
#define FSL_EIS_MAS5   629
#define FSL_EIS_MAS6   630
#define FSL_EIS_MAS6_SPID0(n)   ((0xff & (n)) << (63 - 55))
#define FSL_EIS_MAS6_SAS   (1 << (63 - 63))
#define FSL_EIS_MAS7   944
#define FSL_EIS_MAS8   341
#define FSL_EIS_MMUCFG   1015
#define FSL_EIS_MMUCSR0   1012
#define FSL_EIS_PID0   48
#define FSL_EIS_PID1   633
#define FSL_EIS_PID2   634
#define FSL_EIS_TLB0CFG   688
#define FSL_EIS_TLB1CFG   689
#define FSL_EIS_L1CFG0   515
#define FSL_EIS_L1CFG1   516
#define FSL_EIS_L1CSR0   1010
#define FSL_EIS_L1CSR0_CFI   (1 << (63 - 62))
#define FSL_EIS_L1CSR1   1011
#define FSL_EIS_L1CSR1_ICFI   (1 << (63 - 62))
#define FSL_EIS_L2CFG0   519
#define FSL_EIS_L2CSR0   1017
#define FSL_EIS_L2CSR0_L2FI   (1 << (63 - 42))
#define FSL_EIS_L2CSR0_L2FL   (1 << (63 - 52))
#define FSL_EIS_L2CSR1   1018
#define FSL_EIS_ATBL   526
#define FSL_EIS_ATBU   527
#define FSL_EIS_MCAR   573
#define FSL_EIS_DSRR0   574
#define FSL_EIS_DSRR1   575
#define FSL_EIS_EPR   702
#define FSL_EIS_SPEFSCR   512
#define FSL_EIS_SPRG8   604
#define FSL_EIS_SPRG9   605
#define FSL_EIS_DBCR3   561
#define FSL_EIS_DBCR4   563
#define FSL_EIS_DBCR5   564
#define FSL_EIS_DBCR6   603
#define FSL_EIS_DBCNT   562
#define PPC_INTERRUPT_DISABLE_MASK_DEFAULT   MSR_EE
 Default value for the interrupt disable mask.
#define _CPU_MSR_GET(_msr_value)
#define _CPU_MSR_SET(_msr_value)   { __asm__ volatile ("mtmsr %0" : "=&r" ((_msr_value)) : "0" ((_msr_value))); }
#define _CPU_ISR_Disable(_isr_cookie)
#define _CPU_ISR_Enable(_isr_cookie)    ppc_interrupt_enable(_isr_cookie)
#define _CPU_ISR_Flash(_isr_cookie)    ppc_interrupt_flash(_isr_cookie)
char _PPC_INTERRUPT_DISABLE_MASK []
 A global symbol used to disable interrupts in the MSR.
◆ _CPU_ISR_Disable
#define _CPU_ISR_Disable (   _isr_cookie)
Value:
do { \
_isr_cookie = ppc_interrupt_disable(); \
} while (0)
◆ _CPU_MSR_GET
#define _CPU_MSR_GET (   _msr_value)
Value:
do { \
_msr_value = 0; \
__asm__ volatile ("mfmsr %0" : "=&r" ((_msr_value)) : "0" ((_msr_value))); \
} while (0)
◆ _GLOBAL
#define _GLOBAL (   n)
Value:
.globl n;\
n:
◆ HID0_TBEN
#define HID0_TBEN
Value:
(1<<26) /* 7455:this bit must be set
* and TBEN signal must be asserted
* to enable the time base and
* decrementer.
◆ L3CR_L3I
#define L3CR_L3I
Value:
0x00000400 /* 21: L3 global invaregisters.h.orig
lidate */
◆ PPC_INTERRUPT_DISABLE_MASK_DEFAULT
The interrupt disable mask is stored in the global symbol _PPC_INTERRUPT_DISABLE_MASK.
Variable Documentation
◆ _PPC_INTERRUPT_DISABLE_MASK
char _PPC_INTERRUPT_DISABLE_MASK[]
extern
A one bit means that this bit should be cleared.
