RTEMS 6.1
part.h
2
11/*
12 * Copyright (C) 2020, 2021 embedded brains GmbH & Co. KG
13 * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37/*
38 * This file is part of the RTEMS quality process and was automatically
39 * generated. If you find something that needs to be fixed or
40 * worded better please post a report or patch to an RTEMS mailing list
41 * or raise a bug report:
42 *
43 * https://www.rtems.org/bugs.html
44 *
45 * For information on updating and regenerating please refer to the How-To
46 * section in the Software Requirements Engineering chapter of the
47 * RTEMS Software Engineering manual. The manual is provided as a part of
48 * a release. For development sources please refer to the online
49 * documentation at:
50 *
51 * https://docs.rtems.org
52 */
53
54/* Generated from spec:/rtems/part/if/header */
55
56#ifndef _RTEMS_RTEMS_PART_H
57#define _RTEMS_RTEMS_PART_H
58
59#include <stddef.h>
60#include <stdint.h>
61#include <rtems/rtems/attr.h>
62#include <rtems/rtems/status.h>
63#include <rtems/rtems/types.h>
64#include <rtems/score/cpu.h>
65
66#ifdef __cplusplus
67extern "C" {
68#endif
69
70/* Generated from spec:/rtems/part/if/group */
71
81/* Generated from spec:/rtems/part/if/alignment */
82
93#define RTEMS_PARTITION_ALIGNMENT CPU_SIZEOF_POINTER
94
95/* Generated from spec:/rtems/part/if/create */
96
236 rtems_name name,
237 void *starting_address,
238 uintptr_t length,
239 size_t buffer_size,
240 rtems_attribute attribute_set,
241 rtems_id *id
242);
243
244/* Generated from spec:/rtems/part/if/ident */
245
317 rtems_name name,
318 uint32_t node,
319 rtems_id *id
320);
321
322/* Generated from spec:/rtems/part/if/delete */
323
381
382/* Generated from spec:/rtems/part/if/get-buffer */
383
439
440/* Generated from spec:/rtems/part/if/return-buffer */
441
484
485#ifdef __cplusplus
486}
487#endif
488
489#endif /* _RTEMS_RTEMS_PART_H */
This header file provides Classic API directive attributes.
This header file provides types used by the Classic API.
uint32_t rtems_attribute
This type represents Classic API attributes.
Definition: attr.h:96
rtems_status_code rtems_partition_return_buffer(rtems_id id, void *buffer)
Returns the buffer to the partition.
Definition: partreturnbuffer.c:87
rtems_status_code rtems_partition_delete(rtems_id id)
Deletes the partition.
Definition: partdelete.c:45
rtems_status_code rtems_partition_create(rtems_name name, void *starting_address, uintptr_t length, size_t buffer_size, rtems_attribute attribute_set, rtems_id *id)
Creates a partition.
Definition: partcreate.c:82
rtems_status_code rtems_partition_get_buffer(rtems_id id, void **buffer)
Tries to get a buffer from the partition.
Definition: partgetbuffer.c:50
rtems_status_code rtems_partition_ident(rtems_name name, uint32_t node, rtems_id *id)
Identifies a partition by the object name.
Definition: partident.c:45
rtems_status_code
Definition: status.h:85
uint32_t rtems_name
This type represents Classic API object names.
Definition: types.h:226
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
This header file provides the status codes of Classic API directives and support functions.
