#define | NIOS2_CTLREG_INDEX_STATUS 0 |
#define | NIOS2_CTLREG_INDEX_ESTATUS 1 |
#define | NIOS2_CTLREG_INDEX_BSTATUS 2 |
#define | NIOS2_CTLREG_INDEX_IENABLE 3 |
#define | NIOS2_CTLREG_INDEX_IPENDING 4 |
#define | NIOS2_CTLREG_INDEX_CPUID 5 |
#define | NIOS2_CTLREG_INDEX_EXCEPTION 7 |
#define | NIOS2_CTLREG_INDEX_PTEADDR 8 |
#define | NIOS2_CTLREG_INDEX_TLBACC 9 |
#define | NIOS2_CTLREG_INDEX_TLBMISC 10 |
#define | NIOS2_CTLREG_INDEX_BADADDR 12 |
#define | NIOS2_CTLREG_INDEX_CONFIG 13 |
#define | NIOS2_CTLREG_INDEX_MPUBASE 14 |
#define | NIOS2_CTLREG_INDEX_MPUACC 15 |
#define | NIOS2_CONTEXT_OFFSET_R16 0 |
#define | NIOS2_CONTEXT_OFFSET_R17 4 |
#define | NIOS2_CONTEXT_OFFSET_R18 8 |
#define | NIOS2_CONTEXT_OFFSET_R19 12 |
#define | NIOS2_CONTEXT_OFFSET_R20 16 |
#define | NIOS2_CONTEXT_OFFSET_R21 20 |
#define | NIOS2_CONTEXT_OFFSET_R22 24 |
#define | NIOS2_CONTEXT_OFFSET_R23 28 |
#define | NIOS2_CONTEXT_OFFSET_FP 32 |
#define | NIOS2_CONTEXT_OFFSET_STATUS 36 |
#define | NIOS2_CONTEXT_OFFSET_SP 40 |
#define | NIOS2_CONTEXT_OFFSET_RA 44 |
#define | NIOS2_CONTEXT_OFFSET_ISR_DISPATCH_DISABLE 48 |
#define | NIOS2_CONTEXT_OFFSET_STACK_MPUBASE 52 |
#define | NIOS2_CONTEXT_OFFSET_STACK_MPUACC 56 |
#define | NIOS2_ISR_STATUS_MASK_IIC 0xfffffffe |
#define | NIOS2_ISR_STATUS_BITS_IIC 0x00000000 |
#define | NIOS2_ISR_STATUS_MASK_EIC_IL 0xfffffc0f |
#define | NIOS2_ISR_STATUS_BITS_EIC_IL 0x000003f0 |
#define | NIOS2_ISR_STATUS_MASK_EIC_RSIE 0xf7ffffff |
#define | NIOS2_ISR_STATUS_BITS_EIC_RSIE 0x00000000 |
#define | NIOS2_STATUS_RSIE (1 << 23) |
#define | NIOS2_STATUS_NMI (1 << 22) |
#define | NIOS2_STATUS_PRS_OFFSET 16 |
#define | NIOS2_STATUS_PRS_MASK (0x3f << NIOS2_STATUS_PRS_OFFSET) |
#define | NIOS2_STATUS_CRS_OFFSET 10 |
#define | NIOS2_STATUS_CRS_MASK (0x3f << NIOS2_STATUS_CRS_OFFSET) |
#define | NIOS2_STATUS_IL_OFFSET 4 |
#define | NIOS2_STATUS_IL_MASK (0x3f << NIOS2_STATUS_IL_OFFSET) |
#define | NIOS2_STATUS_IH (1 << 3) |
#define | NIOS2_STATUS_EH (1 << 2) |
#define | NIOS2_STATUS_U (1 << 1) |
#define | NIOS2_STATUS_PIE (1 << 0) |
#define | NIOS2_EXCEPTION_CAUSE_OFFSET 2 |
#define | NIOS2_EXCEPTION_CAUSE_MASK (0x1f << NIOS2_EXCEPTION_CAUSE_OFFSET) |
#define | NIOS2_PTEADDR_PTBASE_OFFSET 22 |
#define | NIOS2_PTEADDR_PTBASE_MASK (0x3ff << NIOS2_PTEADDR_PTBASE_OFFSET) |
#define | NIOS2_PTEADDR_VPN_OFFSET 2 |
#define | NIOS2_PTEADDR_VPN_MASK (0xfffff << NIOS2_PTEADDR_VPN_OFFSET) |
#define | NIOS2_TLBACC_IG_OFFSET 25 |
#define | NIOS2_TLBACC_IG_MASK (0x3ff << NIOS2_TLBACC_IG_OFFSET) |
#define | NIOS2_TLBACC_C (1 << 24) |
#define | NIOS2_TLBACC_R (1 << 23) |
#define | NIOS2_TLBACC_W (1 << 22) |
#define | NIOS2_TLBACC_X (1 << 21) |
#define | NIOS2_TLBACC_G (1 << 20) |
#define | NIOS2_TLBACC_PFN_OFFSET 2 |
#define | NIOS2_TLBACC_PFN_MASK (0xfffff << NIOS2_TLBACC_PFN_OFFSET) |
#define | NIOS2_TLBMISC_WAY_OFFSET 20 |
#define | NIOS2_TLBMISC_WAY_MASK (0xf << NIOS2_TLBMISC_WAY_OFFSET) |
#define | NIOS2_TLBMISC_RD (1 << 19) |
#define | NIOS2_TLBMISC_WE (1 << 18) |
#define | NIOS2_TLBMISC_PID_OFFSET 5 |
#define | NIOS2_TLBMISC_PID_MASK (0x3fff << NIOS2_TLBMISC_PID_OFFSET) |
#define | NIOS2_TLBMISC_DBL (1 << 3) |
#define | NIOS2_TLBMISC_BAD (1 << 2) |
#define | NIOS2_TLBMISC_PERM (1 << 1) |
#define | NIOS2_TLBMISC_D (1 << 0) |
#define | NIOS2_CONFIG_ANI (1 << 1) |
#define | NIOS2_CONFIG_PE (1 << 0) |
#define | NIOS2_MPUBASE_BASE_OFFSET 6 |
#define | NIOS2_MPUBASE_BASE_MASK (0x1ffffff << NIOS2_MPUBASE_BASE_OFFSET) |
#define | NIOS2_MPUBASE_INDEX_OFFSET 1 |
#define | NIOS2_MPUBASE_INDEX_MASK (0x0000003e) |
#define | NIOS2_MPUBASE_D (1 << 0) |
#define | NIOS2_MPUACC_MASK_OFFSET 6 |
#define | NIOS2_MPUACC_MASK_MASK (0x7fffffc0) |
#define | NIOS2_MPUACC_LIMIT_OFFSET 6 |
#define | NIOS2_MPUACC_LIMIT_MASK (0xffffffc0) |
#define | NIOS2_MPUACC_C (1 << 5) |
#define | NIOS2_MPUACC_PERM_OFFSET 2 |
#define | NIOS2_MPUACC_PERM_MASK (0x0000001c) |
#define | NIOS2_MPUACC_RD (1 << 1) |
#define | NIOS2_MPUACC_WR (1 << 0) |
| #define | NIOS2_MPU_REGION_DESC_INST(index, base, end) |
| #define | NIOS2_MPU_REGION_DESC_DATA_RO(index, base, end) |
| #define | NIOS2_MPU_REGION_DESC_DATA_RW(index, base, end) |
| #define | NIOS2_MPU_REGION_DESC_DATA_IO(index, base, end) |
