RTEMS 6.1
Command support routines for RTEMS monitor. More...
| struct | rtems_monitor_command_lookup_entry |
| #define | MAX_HELP_LINE_LENGTH (75 - max_cmd_len - 2) |
| void | rtems_monitor_command_usage (const rtems_monitor_command_entry_t *table, const char *command_name) |
| void | rtems_monitor_help_cmd (int argc, char **argv, const rtems_monitor_command_arg_t *command_arg, bool verbose RTEMS_UNUSED) |
| const rtems_monitor_command_entry_t * | rtems_monitor_command_lookup (const char *name) |
| Looks for a command with the name name in the list of registered commands. | |
| const rtems_monitor_command_entry_t * rtems_monitor_command_lookup | ( | const char * | name | ) |
The parameter name must not be NULL.
Returns the corresponding command entry or NULL if no command is found.
