RTEMS 6.1
Data Structures | Macros | Typedefs
mmctrl-regs.h File Reference
This header file defines the MMCTRL register block interface. More...
#include <stdint.h>
struct  mmctrl
 This structure defines the MMCTRL register block memory map. More...
#define MMCTRL_SDCFG1_RF   0x80000000U
#define MMCTRL_SDCFG1_TRP   0x40000000U
#define MMCTRL_SDCFG1_TRFC_SHIFT   27
#define MMCTRL_SDCFG1_TRFC_MASK   0x38000000U
#define MMCTRL_SDCFG1_TRFC_GET(_reg)
#define MMCTRL_SDCFG1_TRFC_SET(_reg, _val)
#define MMCTRL_SDCFG1_TRFC(_val)
#define MMCTRL_SDCFG1_TC   0x4000000U
#define MMCTRL_SDCFG1_BANKSZ_SHIFT   23
#define MMCTRL_SDCFG1_BANKSZ_MASK   0x3800000U
#define MMCTRL_SDCFG1_BANKSZ_GET(_reg)
#define MMCTRL_SDCFG1_BANKSZ_SET(_reg, _val)
#define MMCTRL_SDCFG1_BANKSZ(_val)
#define MMCTRL_SDCFG1_COLSZ_SHIFT   21
#define MMCTRL_SDCFG1_COLSZ_MASK   0x600000U
#define MMCTRL_SDCFG1_COLSZ_GET(_reg)
#define MMCTRL_SDCFG1_COLSZ_SET(_reg, _val)
#define MMCTRL_SDCFG1_COLSZ(_val)
#define MMCTRL_SDCFG1_COMMAND_SHIFT   18
#define MMCTRL_SDCFG1_COMMAND_MASK   0x1c0000U
#define MMCTRL_SDCFG1_COMMAND_GET(_reg)
#define MMCTRL_SDCFG1_COMMAND_SET(_reg, _val)
#define MMCTRL_SDCFG1_COMMAND(_val)
#define MMCTRL_SDCFG1_MS   0x10000U
#define MMCTRL_SDCFG1_64   0x8000U
#define MMCTRL_SDCFG1_RFLOAD_SHIFT   0
#define MMCTRL_SDCFG1_RFLOAD_MASK   0x7fffU
#define MMCTRL_SDCFG1_RFLOAD_GET(_reg)
#define MMCTRL_SDCFG1_RFLOAD_SET(_reg, _val)
#define MMCTRL_SDCFG1_RFLOAD(_val)
#define MMCTRL_SDCFG2_CE   0x40000000U
#define MMCTRL_SDCFG2_EN2T   0x8000U
#define MMCTRL_SDCFG2_DCS   0x4000U
#define MMCTRL_SDCFG2_BPARK   0x2000U
#define MMCTRL_MUXCFG_ERRLOC_SHIFT   20
#define MMCTRL_MUXCFG_ERRLOC_MASK   0xfff00000U
#define MMCTRL_MUXCFG_ERRLOC_GET(_reg)
#define MMCTRL_MUXCFG_ERRLOC_SET(_reg, _val)
#define MMCTRL_MUXCFG_ERRLOC(_val)
#define MMCTRL_MUXCFG_DDERR   0x80000U
#define MMCTRL_MUXCFG_DWIDTH_SHIFT   16
#define MMCTRL_MUXCFG_DWIDTH_MASK   0x70000U
#define MMCTRL_MUXCFG_DWIDTH_GET(_reg)
#define MMCTRL_MUXCFG_DWIDTH_SET(_reg, _val)
#define MMCTRL_MUXCFG_DWIDTH(_val)
#define MMCTRL_MUXCFG_BEID_SHIFT   12
#define MMCTRL_MUXCFG_BEID_MASK   0xf000U
#define MMCTRL_MUXCFG_BEID_GET(_reg)
#define MMCTRL_MUXCFG_BEID_SET(_reg, _val)
#define MMCTRL_MUXCFG_BEID(_val)
#define MMCTRL_MUXCFG_DATAMUX_SHIFT   5
#define MMCTRL_MUXCFG_DATAMUX_MASK   0xe0U
#define MMCTRL_MUXCFG_DATAMUX_GET(_reg)
#define MMCTRL_MUXCFG_DATAMUX_SET(_reg, _val)
#define MMCTRL_MUXCFG_DATAMUX(_val)
#define MMCTRL_MUXCFG_CEN   0x10U
#define MMCTRL_MUXCFG_BAUPD   0x8U
#define MMCTRL_MUXCFG_BAEN   0x4U
#define MMCTRL_MUXCFG_CODE   0x2U
#define MMCTRL_MUXCFG_EDEN   0x1U
#define MMCTRL_FTDA_FTDA_SHIFT   2
#define MMCTRL_FTDA_FTDA_MASK   0xfffffffcU
#define MMCTRL_FTDA_FTDA_GET(_reg)
#define MMCTRL_FTDA_FTDA_SET(_reg, _val)
#define MMCTRL_FTDA_FTDA(_val)
#define MMCTRL_FTDC_CBD_SHIFT   24
#define MMCTRL_FTDC_CBD_MASK   0xff000000U
#define MMCTRL_FTDC_CBD_GET(_reg)
#define MMCTRL_FTDC_CBD_SET(_reg, _val)
#define MMCTRL_FTDC_CBD(_val)
#define MMCTRL_FTDC_CBC_SHIFT   16
#define MMCTRL_FTDC_CBC_MASK   0xff0000U
#define MMCTRL_FTDC_CBC_GET(_reg)
#define MMCTRL_FTDC_CBC_SET(_reg, _val)
#define MMCTRL_FTDC_CBC(_val)
#define MMCTRL_FTDC_CBB_SHIFT   8
#define MMCTRL_FTDC_CBB_MASK   0xff00U
#define MMCTRL_FTDC_CBB_GET(_reg)
#define MMCTRL_FTDC_CBB_SET(_reg, _val)
#define MMCTRL_FTDC_CBB(_val)
#define MMCTRL_FTDC_CBA_SHIFT   0
#define MMCTRL_FTDC_CBA_MASK   0xffU
#define MMCTRL_FTDC_CBA_GET(_reg)
#define MMCTRL_FTDC_CBA_SET(_reg, _val)
#define MMCTRL_FTDC_CBA(_val)
#define MMCTRL_FTDD_DATA_SHIFT   0
#define MMCTRL_FTDD_DATA_MASK   0xffffffffU
#define MMCTRL_FTDD_DATA_GET(_reg)
#define MMCTRL_FTDD_DATA_SET(_reg, _val)
#define MMCTRL_FTDD_DATA(_val)
#define MMCTRL_FTBND_FTBND_31_3_SHIFT   3
#define MMCTRL_FTBND_FTBND_31_3_MASK   0xfffffff8U
#define MMCTRL_FTBND_FTBND_31_3_GET(_reg)
#define MMCTRL_FTBND_FTBND_31_3_SET(_reg, _val)
#define MMCTRL_FTBND_FTBND_31_3(_val)
typedef struct mmctrl mmctrl
