RTEMS 6.1
This group contains the MMCTRL interfaces. More...
Modules | |
| FT boundary address register (FTBND) | |
| This group contains register bit definitions. | |
| FT diagnostic address register (FTDA) | |
| FT diagnostic checkbits register (FTDC) | |
| FT diagnostic data register (FTDD) | |
| Mux configuration register (MUXCFG) | |
| SDRAM configuration register 1 (SDCFG1) | |
| SDRAM configuration register 2 (SDCFG2) | |
Files | |
| file | mmctrl-regs.h |
| This header file defines the MMCTRL register block interface. | |
| struct | mmctrl |
| This structure defines the MMCTRL register block memory map. More... | |
Typedefs | |
| typedef struct mmctrl | mmctrl |
| This structure defines the MMCTRL register block memory map. | |
