RTEMS 6.1
clockdrv.c File Reference
#include <bsp/irq.h>
#include <bsp.h>
#include "yamon_api.h"
#include "../../../shared/dev/clock/clockimpl.h"
#define CLOCK_VECTOR   TX4938_IRQ_TMR0
#define TX4938_TIMER_INTERVAL_MODE   1
#define TX4938_TIMER_MODE   TX4938_TIMER_INTERVAL_MODE
#define TX4938_TIMER_INTERRUPT_FLAG   TIIS
#define Clock_driver_support_initialize_hardware()    Initialize_timer0_in_interval_mode()
#define Clock_driver_support_install_isr(_new)
#define Clock_driver_support_at_tick(arg)
#define Initialize_timer0_in_interval_mode()
#define CLOCK_DRIVER_USE_DUMMY_TIMECOUNTER
void new_brk_esr (void)
t_yamon_retfunc esr_retfunc = 0
t_yamon_ref original_brk_esr = 0
t_yamon_ref original_tmr0_isr = 0
Instantiate the clock driver shell.
◆ Clock_driver_support_at_tick
#define Clock_driver_support_at_tick (   arg)
Value:
do { \
uint32_t interrupt_flag; \
do { \
int loop_count; \
TX4938_REG_WRITE( TX4938_REG_BASE, TX4938_TIMER0_BASE + TX4938_TIMER_TISR, 0x0 ); /* Clear timer 0 interrupt */ \
loop_count = 0; \
do { /* Wait until interrupt flag is cleared (this prevents re-entering interrupt) */ \
/* Read back interrupt status register and isolate interval timer flag */ \
interrupt_flag = TX4938_REG_READ( TX4938_REG_BASE, TX4938_TIMER0_BASE + TX4938_TIMER_TISR ) & TX4938_TIMER_INTERRUPT_FLAG; \
} while (interrupt_flag && (++loop_count < 10)); /* Loop while timer interrupt bit is set, or loop count is lees than 10 */ \
} while(interrupt_flag); \
} while(0)
◆ Clock_driver_support_install_isr
#define Clock_driver_support_install_isr (   _new)
Value:
do { \
rtems_interrupt_handler_install( \
CLOCK_VECTOR, \
"clock", \
0, \
_new, \
NULL \
YAMON_FUNC_REGISTER_IC_ISR(17,(t_yamon_isr)_new,0,&original_tmr0_isr); /* Call Yamon to enable interrupt */ \
} while(0)
◆ Initialize_timer0_in_interval_mode
#define Initialize_timer0_in_interval_mode ( )
Value:
do { \
uint32_t temp; \
TX4938_REG_WRITE( TX4938_REG_BASE, TX4938_TIMER0_BASE + TX4938_TIMER_TCR, 0x0 ); /* Disable timer */ \
TX4938_REG_WRITE( TX4938_REG_BASE, TX4938_TIMER0_BASE + TX4938_TIMER_CCDR, 0x0 ); /* Set register for divide by 2 clock */ \
TX4938_REG_WRITE( TX4938_REG_BASE, TX4938_TIMER0_BASE + TX4938_TIMER_ITMR, TIMER_CLEAR_ENABLE_MASK ); /* Set interval timer mode register */ \
TX4938_REG_WRITE( TX4938_REG_BASE, TX4938_TIMER0_BASE + TX4938_TIMER_CPRA, 0x3d090 ); /* Set tmier period ,10.0 msec (25 MHz timer clock) */ \
TX4938_REG_WRITE( TX4938_REG_BASE, TX4938_TIMER0_BASE + TX4938_TIMER_TCR, 0xC0 ); /* Enable timer in interval mode */ \
temp = TX4938_REG_READ( TX4938_REG_BASE, TX4938_TIMER0_BASE + TX4938_TIMER_ITMR ); /* Enable interval timer interrupts */ \
temp |= TIMER_INT_ENABLE_MASK; \
TX4938_REG_WRITE( TX4938_REG_BASE, TX4938_TIMER0_BASE + TX4938_TIMER_ITMR, temp ); \
} while(0)
